V break spring housing warped
Hello,
I have a problem with the spring housing on my V break. You can clearly tell that the housing has become warped by comparing these 3 pictures:
Broken unscrewed
Broken screwed in
Normal (other side)
I would like some advice on how to remedy this. I think I will have to order a new part, as it's nylon and cant just be pushed back into shape. Can anyone give me some good advice or a link to that part/tutorial on how to change it? Thanks for any help.
Broken unscrewed
Broken screwed in
Normal (other side)
Quoted: 5899 Post(s)
Liked 2,762 Times
Does it affect function? If not forget about it.
FB
Chain-L site
FB
Chain-L site
Pass/fail if it doesnt work replace the whole thing .. bike parts are at their lowest range . .. cheap.
It definitely affects function, as I can't use the front brakes because of this. The spring does not get pushed on by the bolt at all - the bolt just goes over the top of it. Do you have a link to the part that I will need to replace?
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
