Crashed... Dented my rim... Safe?
I let the dogs out
Bikes: 2011 Fuji Roubaix 1.0, 2003 Ti Merlin Solis, & 1994 Raleigh MT200
I just moved to Boulder Colorado and decided to go on a night ride... Long story short, I hit a curb that I thought was a ramp because I have depth perception issues at night... I was going between 20 and 25mph and I hit the curb pretty much head on. My bike is fine except I threw my rear wheel out of true, tore my new GP4000S that I had on the front (around 300 miles on it), and dented the braking surface of the rim. When I brought my bike into my dorm I inspected the front wheel and I could see stress crazing around the dent.. My wheels are Mavic cosmos (eyeleted spoke holes, double wall alloy rims that closely resemble mavic open sports).. I work in a bike shop so I brought my rear wheel to work and trued it in the truing stand there. When I got home from work I took an old cone wrench and hammer and banged out the dent from the inside surface of the rim (where the rim tape is) and got it fairly flat. The stress crazing seems a little worse than it did before I banged it out...
Here are my two concerns: if I put on a new tire and inflate it to 100psi, is the hook likely to catastrophically fail? (ie will the rim explode?) And if the rim can hold the pressure, can it hold my weight?
Fwiw I'm prepared to replace the wheel/rim but I'd like to avoid it if at all possible
Quoted: 5907 Post(s)
Liked 2,776 Times
99% of the time the answer is yes. Of course it's always a matter of degree, and the specific alloy used, but the odds favor you if you don't see any visible cracking. The rim shouldn't split from air pressure because the damage is limited to a very small zone, and there's plenty of support to either side. Likewise it shouldn't collapse from your weight because spoke tension/rim compression is much more than that.
The acid test, especially in a front wheel is how the braking is. Minor pulsing is OK and will probably resolve with time, but any serious pulsing in a front brake can cause modulation issues and a sudden grab or lockup in an emergency stop. So that's the 1%. If the braking modulation isn't good enough for you to feel it's reliable and predictable, rebuild the front. BTW- equally grabby brakes in back aren't as serious a safety issue.
FB
Chain-L site
FB
Chain-L site
I let the dogs out
Anyone know an eyeleted 24h rim that matches the 605ish mm erd of the mavic cosmos?
Liked 2,776 Times
aren't you jumping the ***?
FB
Chain-L site
FB
Chain-L site
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
You're jumping the hand-carried projectile-throwing device.
You can always buy another Mavic. Maybe a Cosmos, even? It is silly, but I am anal about having my rims match.
I let the dogs out
Mavic discontinued Cosmos rims at least 8 years ago. The cosmos is basically the same as the Open Pro (605mm erd vs 603mm erd, same profile, same double eyelets).... I'd lace it up with an open pro if Open Pros came in 24h varieties... The Cosmos is basically an Open Pro that came in 24h/28h varieties. The Open Pro only comes in 28/32/36h.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
I let the dogs out
Went and got a new GP4000S2 and threw it on the rim. Trued up the wheel and inflated the tire to 110psi. It's been holding pressure with no signs of impending doom for the past 2 hours. I'll ride it and test the brakes tomorrow
Big Picture question - why are you riding 20-25mph at night if you have depth perception issues at night/
I let the dogs out
My garmin says I lied. I hit the curb at about 13mph and rapidly decelerated to 0mph
Bikes: Lynskey Twisted Helix Di2 Ti, 1987 Orbea steel single speed/fixie, Orbea Avant M30, Trek Fuel EX9.8 29, Trek Madone 5 series, Specialized Epic Carbon Comp 29er, Trek 7.1F
Quoted: 12 Post(s)
You didn't lie that speed exageration is the average % of inflation for any speed described on the internet forums.
Bikes: Cervelo Soloist, Trek Hifi Pro, Kona Dew, Raleigh Tomahawk
It may be possible to hunt down a cosmos rim, I'm sure there are one or two shops in boulder
My Cosmic rear exploded when I backed into a car at 40km/h. I was able to get a replacement at my LBS, but that was 6 years ago. It's a pain, and more costly due to the fact that it's a special drilling compared to a regular CXP33 rim, just as your's is a special drilling of an open pro.
SuperGimp
You have skills I wasn't even aware existed.
What does the brain trust say about replacing spokes if you replace the rim? I was under the impression that was generally a good practice and would open up some additional rim options for you.
