How far under your tire's inflation rating will you go?
Curious as to what folks might do. I'm currently running Conti GP regulars right now and typically run 110psi rear and 100psi front (700 x 23). I do that cuz I feel it's best for speed for me. (I think mine are rated up to 130 but would never run them that high for comfort's sake)
I recall one shop I test rode a few bikes at this summer always had mushy tires. I *think* they wanted the test rides to be "cushy" so if I had to guess, I'd say they were at around 80psi. But this was all the typical race bikes from C'dale, Spesh, Fuji, Giant, etc.
No way those tires were rated at that so wonder if they'd expect folks to ride like that regularly.
Anywho....I know we've talked a lot about going over but wondered how far "under" folks might go.
TIA
TIA
Quoted: 5 Post(s)
I find with 25 and 28mm tires that the minimum pressures are a few psi high for the actual weight on the front tire of my bike. The rear doesn't have the same issue.
Allez means go.
I usually fill my 700 x 23's up to 120 and ride it all week. By the next time I fill them up, they might be as low as 80 if there was a lot of temperature changes. I would say 90-100 rides the best for me (no speed difference, more comfortable) but I'd rather not fill them up twice a week.
Bikes: Wheelbarrow
Quoted: 19 Post(s)
My Bontrager clinchers are rated at about 100psi-115psi. I run them at 125psi-130psi rear (depending on how hot it is and how fat I feel that morning) and 125psi front. Upgrading to tubulars and you can bet I'll be in the 150-160psi range. I don't know what comfort is.
Oh how LOW will I run them ... excuse me while I show myself out the door.
Bikes: 2014 Cervelo R5 Dura Ace,2014 Specialized S-Works Roubaix
I ride 100-105 psi, I weigh 160 pounds. No issues with flats or anything. WHen I started riding last year I was running 120 or so but the lower pressure is definitely much more road friendly.
Actually, if you haven't ready already (and I know it feels like it's got to be counterintuitive) there's lots on how a larger, wider, lower pressure tires has less rolling resistance than the opposite. It does seem weird, but apparently it's true. (Thus mfgrs' move to 25mm tires for roadies)
Even so, I still have days I want to pump up to about 150psi just to feel like I'm riding on uncompromising balloons but......
Bikes: Wheelbarrow
Quoted: 19 Post(s)
LOL.....
I currently run 700x23 clinchers ... I stopped taking them up to 140psi when a tire exploded on me once. It was a long walk to an alternative source of transport. Now I keep it at 130psi maximum.
What you'll learn from engineering is that the suggested range of tolerances are very different from actual range of tolerances and stresses many compounds are capable of sustaining.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
at ~180, running 95f, 98r on schwalbe ultremos zx.
Quoted: 86 Post(s)
at 160 pounds i ride my 20 thru 25mm tires at anywhere from 75 to 80 PSI.
they are mainly 700c Vittoria Corsa's and Continental Supersonics. two bike ahve some very old and very narrow NOS 27 inchers. i have a pair of touring 28mm Continental Ultra something or other's. i run them at 65PSI. then on my 1x1/4 MTB's, about 60PSI.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1109 Post(s)
Liked 2,220 Times
LOL.....
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 557 Post(s)
Liked 732 Times
I put a new wheelset on a few years ago and accidentally went out with 60psi in both (25c GP4000s usually 85/90ish).
Best ride ever.
Best ride ever.
Bike rider
I usually run the pressure at around 100 psi, but some times for comfort i do 70-80psi.
I don't usually go under the MINIMUM recommended pressure. I've done it some just to see if it improved the ride.
My MTB is running ~18psi on 26x2.35in tubeless.
My road bike is usually 75/85 f/r on 700x23 road tubeless. If I were on 700x25, I'd definitely be under the minimum pressure.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12996 Post(s)
Liked 7,915 Times
I've had some with a 160 max. Took em up to 120 a couple of times but usually just 95 f, 100 r.
Quoted: 660 Post(s)
Liked 601 Times
Never. One stone and you are snakebit.
don't try this at home.
Quoted: 989 Post(s)
Liked 536 Times
Do a search of the tests and you'll find all of what you said isn't quite right. Wider tires do have less rolling resistance at the SAME pressures as narrower tires. That's key. Then rolling resistance doesn't decrease with less pressure. Youll find tests showing how resistance starts to go up with less pressure in the same tire. So what you do with less pressure is make tradeoffs between comfort and resistance.
Here's a test with Continental GP4000 tires in different sizes. The 25c tires are still lower rolling resistance at "comparable" pressures, for instance: 115 psi for 23c and 100 psi for 25c.
I posted this in another 25c thread.
From slowtwitch.com
Continental's rolling resistance chart is interesting. The 25c rolling resistance is almost 20% worse (.49) at 80 psi than at 116 psi (.41) What units are they using in the chart? It appears to be Crr x 50 kg?
But: the 25c rolling resistance at 87 psi is equivalent to their 23c at about 112 psi. So larger tires can run at lower pressure and still be efficient.
My tire pressures. I weigh 170 pounds.
23c: 95-100 psi front, 110 rear.
25c: 90 front, 105 rear. So the rear is actually comparably harder than my old 23c was, but it's still comfortable.
25c on rough roads: 85 front, 95-100 rear. Then I'll try to be careful on potholes or rough railroad crossings to avoid pinch flats. And the tires feel a little slower on steering response at these pressures.
Quoted: 6556 Post(s)
Liked 58 Times
I think some tire tests run the wheels on spinning metal cylinders. That might not be a good substitute for a rough, flat road surface. But anyway:
From slowtwitch.com
Passista
Quoted: 890 Post(s)
Liked 754 Times
At 152, I use 95-100 on 23s, but I've tried as low as 80-85, comfortable ride, no problems except for a "soft" feeling.
Quoted: 2953 Post(s)
Liked 3,106 Times
I have some Vittoria tubulars that have a 200psi max rating but I typically ride at 60% of that.
