Day Time Running Lights
Bikes: Tracer T275, Salsa Vaya 2
Hi Everyone,
Kind of new here, but I thought I would pose the question: How many of you are running lights during the day for added visibility/safety?
I've seen (from a car) a bunch of people in my area start to do it an I think its a great idea. A lot of them are using flashing mode in both front and rear probably to conserve battery and also increase attention during the daytime. To me I feel like I notice the cyclists with day time lights much sooner than ones without. My thinking this could be a great trend for bicycle safety. Thoughts?
Liked 4,321 Times
I don't use them. I'm no fan of cyclists using bright lights during the daytime on a MUP.
24-Speed Machine
Bikes: 2003 Specialized Allez 24-Speed Road Bike
Hi Everyone,
I just made the leap to a dynohub and B&M Eyc Senso light with a Toplight line brake plus on the rear. I think it is good. The light does not have a flashing mode (german regulations), but has a photo cell which switches to a daytime driving light. When it is daylight it chooses a beam which directed up to attract the attention of drivers. The brake light has a capacitor for storage and a chip monitoring the current. When it senses the current slowing down, it emits a brighter light briefly. It works quite well, but who knows if a driver perceives it for what it is. I put all this on my dedicated commuter and really like it so far.
Marc
Marc
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Liked 274 Times
I don't use any front lights during the day unless it's raining or foggy, the same is true for the rear with the added exception of riding on a busy city street or highway then I set it for flash and I only use the brightest main rear light. At night I have one head light on steady and the other on flash which is mounted to my helmet and I can flash it into car windows and it attracts attention faster, but when I get out into pitch dark paths or roads it goes into steady mode. For the rear my main and brightest tail light is on steady and my other two are on flash at night. The reason I mix my rear lights between steady and flash at night is due to two different studies, a Euro study showed steady to the be the safest yet a Canadian study showed flashing to be the safest, so not knowing who is correct I do both! Steady has been proven to help motorists to determine how far they are away from you much more accurately than a flash mode, but flash attracts their attention faster.
I've never been hit from behind even when I was riding with the first Xenon flashers that were dim to the point of being about as bright as a candle with a red lens covering it, so not sure how well all this bright stuff works, but the technology is there at reasonable costs so I use it.
I also wear reflective Home Depot mesh neon green reflective safety vest at night, and there is a reflective strip on my saddle bag and on my shoes as well as ankle bands I wear, but I don't count on that stuff because unless the car headlights are directly on it reflective stuff isn't all that effective until the car is up close. So I count more on active lighting rather than passive, but some additional way of lighting me up isn't a bad if it helps even 1% which is better than 0%.
Yes, I run lights 24-7. Great for shade to light areas when trees block out the sun on parts of the road. Also helpful when biking below overpasses.
Liked 3,474 Times
I run front (white) and rear (red) blinking lights at all times. Add steady front white at night.
IMHO visibility is the single best safety factor for cyclists.
Running blinking lights is the single best way to create visibility. (second daytime is fluorescent green clothing and second night time is reflective material)
People don't see what they don't expect to see, even in bright daylight (psychology of vision). Blinking lights help break through this and make a cyclist more visible.
Life is too short not to ride the best bike you have, as much as you can.
LET'S ROLL
I use lights that have different settings; I probably wouldn't buy a light if it only turned on and off.
Flashing during the daytime in traffic, off on bike paths during the day, low on bike paths at nite,
unfamiliar street at night - highest steady setting looking out for potholes, etc.
https://www.youtube.com/watch?v=_G74...6zPoymgKaIoDLA
Rain - flashing or high steady depending if it's day or night:
https://www.youtube.com/watch?v=MLeZ...IoDLA&index=19
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Yes, I run lights day and night. It used to be dyno front & rear and an additional flashing rear during the day, but now I have a B&M Luxos U which I use for charging during the day and use a lezyne zecto front and a couple of battery flashing rears. At night, nearly everything is on, except the horizontally-aimed 1W flasher which is reserved for bad conditions (fog, rain etc).
Living 'n Dying in ¾-Time
Bikes: Bacchetta Giro, Strada
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Liked 9 Times
I do. I started after this happened:
https://youtu.be/UOwv_IXZdIk
Then this happened just a few weeks later:
https://youtu.be/-hiZgxpWNlQ
I started running front and rear daylight lights and it hasn't happened since.
Work: the 8 hours that separates bike rides.
I do, powered by my generator hub. Also two bright blinky battery lights (Radbot 1000) on toward the rear, except for the rare times I ride in town in traffic. They get my attention when I see them on other bicyclists, when I'm driving my car, so I figure they might get other people to notice me on my bike. I haven't been run over so far.
I run lights day and night. Blinking red in the back, blinking white during the day, steady white after dark.
Other than having to recharge or replace batteries more frequently, what would be the reasoning behind having lights on your bike and not turning them on? Mine are easily seen during the daylight, which makes me more visible. Can there possibly be a downside to that?
Seems like the advocacy and safety crowd is pretty set on riding with lights during the day. I wonder what the response would be if I had posted this thread in one of the more general boards. Doesn't seem to be anyone against it here.
Do you guys encourage others to ride during the day with lights? How have they taken the suggestions?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Liked 1,279 Times
Fred "The Real Fred"
Liked 3,474 Times
If you have any personal questions as to how much visible they make a bike, then just compare how easy it is to see bikes with and without lights. El Camino, Central express way, Miramonte, Grant road, castro street, foothill expressway.....all should give you a pretty good sample set.
fwiw I run light on my car all the time too.
High Plains Luddite
I always run a flashing red light in the back.
I almost always run a solid white light in the front.
Sometimes if it's the middle of the day, sunny, clear, no long shadows, etc. I'll turn off the headlight but I'm always ready to click it back on if I feel the need to be seen - approaching a busy intersection, etc.
I'm sold on daytime lights. I am waiting for my Designshine DS-500 to arrive. The main highway where I live is a two lane 110Kph number with no shoulder. Texting while driving has changed everything.
DancesWithSUVs
Bike share bikes in DC and NYC run constant blinkies,FYI.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
