Close call, winter maintenance
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I just wanted to clean off a front brake pad, and due to recent neglect and a comedy of errors it sort of cascaded to the rear derailleur. I'll spare the details but after finally getting everything in shape and back together I noticed that the pulleys were needle-sharp. Thinking why put $9 pulleys in a well-used $18 DR, just buy a new one. Then upgrade fever struck. I was looking at lists on the weight weenie site, checking off gear wrap capacity and thinking about the relationship of bearings vs bushings to watts wasted, not to mention how nice anodized surfaces and an actual model name would look back there ... but in the nick of time reason prevailed and my natural cycling parsimony asserted its ascendancy.
I didn't realize how dangerous neglecting routine maintenance might be in provoking the fever. Is it a lost cause? Are you still holding out against unnecessary upgrades, or is it inevitable? Maybe constant maintenance and replacing cheap parts before temptation builds is the only cure?
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
Pulley and bearing watts are pretty dang small. I wouldn't worry about them unless they're thoroughly gunked up. Friction facts did a report on it.
Bikes: Too many to list
I firmly believe that the best upgrade you can do to your drivetrain is achievable using bottle of degreaser and a bucket filled with warm soapy water. Of course Dura Ace shifters, 11 speed cassette and chain are a close second
Bikes: Nashbar Road
Liked 341 Times
Right you are - that's how insidious the upgrade fever can be. A watt or two, why not, and then having said "A", ceramic wheel bearings don't seem that unreasonable. I think it must be a slippery slope once you get started on that path.
Bikes: Nashbar Road
Liked 341 Times
I was there with the bucket and degreaser on my way to the back DR, and I know that after the DR upgrade a new chain would have been next, but I would have had to decide on a cassette simultaneously, most likely. And then whether I really wanted at least a 9 speed, or 10, or 11 speed and all that that implies ... it feels like dodging a bullet. Starting with a brake pad.
Quoted: 4227 Post(s)
Liked 2,489 Times
IMHO the best upgrade is to go FG/SS and then you don't have to worry about any special maintenance. I love the simplicity and fun I get out of my FG/SS drivetrains.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
Oh, absolutely! So many things to fuss with and yet it will never be novel.
Genesis 49:16-17
Genesis 49:16-17
Bikes: 1997 Kona Hahana Race Light, 2010 Surly LHT(deceased), 1999 Rocky Mountain Turbo
Quoted: 86 Post(s)
I also just pulled myself back twice from costly unnecessary upgrades.
It was the rear dérailleur most recently also. Hmm why not move to ten speed? Cause I don't need it.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
A derailleur is about the last thing I'd consider upgrading. Replace when necessary, yes.
Lower end D's work wonderfully even with a minimum of maintenance, and the weight difference is negligible.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
I feel that retrogrouchism, much like our beneficial gut bacteria, can aid in keeping diseases such as this "upgrade fever" you speak of at bay.
Registered User
Bikes: NA
Quoted: 9 Post(s)
Liked 7 Times
LOL!
Upgrading derailleurs makes a huge amount of sense to me because:
1) I have purchased all 3 ultegra 10 speed derailleurs I currently use for less than $50.
2) The stock ultegra rd has fluorine-coated pivots which weareducer (and friction).
3. The stock ceramic/composite bearings/bushings are more durable than those in low end or medium range rds.
3) Ultegra drive trains shift like butter.
5) A low end sora 9 speed rd weighs ~40 gms more than a ~189 gm ultegra 6700. paying $10-20 extra for a 40 gms weight reduction (with pulleys that retail for $15-20) seems like a very good deal to me.
just ride
Bikes: specialized roubaix, dawes sst ( steel single speed)
Quoted: 5 Post(s)
Believe that the only way to resist this malady is to constantly add bikes to the stable with whatever features your current ride might be lacking. Then replacing a part is simply replacing a part - because the other bike that you have purchased (or will in the future) already has/will have that other feature and the proper spare can be called upon when the conditions or mood dictate.
Pretty sure this isn't what you wanted to hear but sometimes the doctor has to deliver bad news.
Bikes: Nashbar Road
Liked 341 Times
Even if the parts remain there in the box until they're hopelessly obsolete, they still facilitate the retrogrouch defense that ThermionicScott so kindly pointed out.
Bikes: Nashbar Road
Liked 341 Times
LOL!
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
If one piece of advice such as "go single speed" worked for everyone, there would only be one kind of bike in the world.
Work: the 8 hours that separates bike rides.
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
FWIW, I am planning to move down to a cheaper derailleur when I wear out my drivetrain (again). It'll probably be another 10,000 miles or so. I only got a 10 speed rear because that's all I could find on a road bike. It's ridiculous overkill for me - I was happy with 8 speed and there are shifts on the 10 speed that I have now where I can hardly tell that anything changed, and I always wind up shifting again.
I can buy 8 speed chains for < $10 and 8 speed cassettes for < $20. Move up to 10 speed and I have to spend > $20 for chains and > $50 for cassettes. For something I don't have any use for.
I will have to come up with a cable pull adapter but that should be fun to design and make.
Registered User
Bikes: NA
Quoted: 9 Post(s)
Liked 7 Times
just run a 9 speed cog with your 10 speed derailleur.
PS: i have a drawer-full of 10 speed chains i purchased for $11-15 and tiagra 10-speed cassettes can be purchased for ~$17-30.
I've been happy with the Tacx Shimano 9/10 Stainless Derailleur Pulleys. About $15.
I couldn't get home from the grocery store it that's all that they sold. A neighbor down the road couldn't believe that I ride up the hill by the new animal doctor up the road. He said that he couldn't do it when he was in his teens.....had to push his bike up it. Then it comes out that he had a Schwinn Sting-Ray type from the hardware store!!!
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
I am more susceptible to the N+1 Virus than Upgrade Fever. Perhaps I should have gotten the vaccine. Upgrade Fever is much less debilitating in the long-run than the N+1 Virus because it has a natural stopping point, when your bike is decked out with the best possible components. However, N+1 seems to keep replicating and replicating ...
Quoted: 169 Post(s)
I'm contemplating obeying the complete nouvo record gruppo off my old bike in order to fund a new veloce gruppo for the modern bike, actually. Or N+1, ideally. Then just make the frame a FG/SS just to keep it rolling.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,469 Times
Drive train upgrades are a slippery slope. The minute you decide you want an extra speed then you essentially will have to buy a new chain, shifter(s) and a possibly a rear mech. Even running a larger cassette of the same speed can mean getting a new chain & mech if you have a short arm derailleur. I'm always in favor of putting off upgrades until they are inevitable.
And that leaves me contemplating a drivetrain downgrade from 9sp to 5sp; do they make 5sp cassettes with a 11-34 spread?
I came to the realization that, on my 2x9 drivetrain, I pretty much always shift the back two gears at a time. I'm consciously trying to spend most of my time lately using my even cogs, to even out the wear with the odd ones I had been favoring.
