Addiction LXXIX
#3727
Liked 5,306 Times
Feels good here.I had a cold brewed iced pumpkin cream coffee yesterday. It was refreshing.
#3728
Liked 3,780 Times
I'm literally overweight and wear a 33" waist
IKR?
But at what cost?
Red is at the very bottom of my list of preferred colors.
#thatsjustlikemyopinionman
Likes For abshipp:
#3729
So it is
Liked 4,924 Times
#3730
Liked 3,780 Times
2. I do the same as you, hold the nozzle in my teeth and swap positions with the full seat tube bottle.
#3731
Bikes: Factor O2, Caad10, Caad2
Liked 123 Times
It turns out I have a toothache/dental problem that is caused by my cycling. I was considering posting my question/concern in the 41, but I will start here.
Several months ago I developed a mild but annoying toothache in my right lower bicuspid tooth. Within a few weeks, one of the causes became apparent, it's my water bottle switch technique: I am VERY comfortable drinking from the DT water bottle (for now, I will call this the "front" bottle), but not at all comfortable drinking from the ST bottle (the "rear" bottle). So my technique over the years while riding is drink from the front bottle, and when that bottle is empty, switch bottles by holding front empty bottle in mouth between teeth (and biting pretty hard so as to not lose bottle), reach down and switch rear bottle to front, then place empty bottle in rear cage. I realized that the hard biting on the right side of my mouth was aggravating if not causing the toothache.
So now I have switched sides and hold front empty bottle on the LEFT side of my mouth when I do the bottle switcheroo. However, I am starting to notice some minor toothache on THAT SIDE!
I suspect the best solution is to get used to drinking from the rear bottle once the front is empty and not bother with the switcheroo, but it feels VERY awkward and unnatural, akin to writing with my left hand (and I am a rightie).
So my long-winded question really has two pieces, which are likely opposite sides of the same coin:
1. What's the best solution to this problem?
2. How do most road cyclists deal with an empty front water bottle?
However, no need to use teeth. When the front bottle is empty, just hold it in your hand with that hand resting on the handlebar and use the other hand to switch bottle locations. Then place the empty bottle in the other cage. You only need a finger or two on the bars if going straight.
Likes For mvnsnd:
#3732
VFL For Life
Bikes: Velo Volmobile
Liked 1,942 Times
abshipp gets it.
#3733
VFL For Life
Liked 1,942 Times
#3734
Liked 5,306 Times
I leave my bottle open, so I dont even have to mess with my while riding.
#3735
Should Be More Popular
Liked 9,205 Times
#3736
Liked 9,205 Times
Likes For datlas:
#3737
Liked 9,205 Times
#3738
Liked 9,456 Times
Multi-part answer:
American brands are vanity sized, so a 34" may measure out to 36" or more.
I'm actually big boned? I measured yesterday, and I'm right at 34" at the waist (well, what most men would consider their waist) and no amount of weight loss is going to move the needle much lower. I'm also the guy for whom they make the 155mm saddles; narrower don't provide any support.
That said, the thighs and glutes are usually the limiting factor for me. American 34" pants are loose around the waist but snug/slim from hips to knees.
#3739
Bikes: Shmikes
Liked 5,972 Times
On another subject, crazy HRV numbers this morning. Looks like ectopic beats. I think I can feel them, but they go away when I stop relaxation and hold a finger on an artery. I also think they're only happening in the exhalation phase of the respiratory cycle. I had planned 2 hrs of sweet spot, but I'm going to take it easy today and rip it up tomorrow.
#3740
Liked 5,306 Times
Before cycling I had gotten all the way up to 38. I’m back down to 32/33. Some 32 fit some don’t.
#3741
VFL For Life
Liked 1,942 Times
It's been a long time since I've needed one bottle, much less two. But they can be easily swapped whenever you stop. It's not like there's an emergency requiring sudden use of the rear one.
#3742
Liked 5,306 Times
[QUOTE=Velo Vol;21663407]It's been a long time since I needed one bottle, much less two. But they can be easily swapped whenever you stop. It's not like there's an emergency requiring sudden use of the rear one.[/QUOTE]
How do you know this?
#3743
Bikes: Shmikes
Liked 5,972 Times
Multi-part answer:
I wear 30" waist pants and have thigh issues too, now that they're making them so skinny.
#3744
Liked 9,205 Times
When I am riding solo, it's fine. A non issue. But I do ride with my friends, and believe it or not, we often will ride for 1-2 hours STRAIGHT without a stop. I suppose I can stop and switch, then snap back to the others but that's hard work. Some of my friends are serious cyclists.
#3745
Liked 9,456 Times
If I have two bottles, both filled with water, I'll switch, but I'll do it at mvnsnd suggests, but I'll hold the empty (it's lighter/easier to hold on to with forefinger and thumb) with a hand that's resting on the tops while switching the DT to the ST position.
Likes For WhyFi:
#3747
Liked 9,456 Times
There are some out there, but they're few, far between and are more often for shirts rather than pants. Years ago, I had bookmarked a website/blog that had recommendations for people with big thighs/glutes (I think that the author was a powerlifter), but everything needed to be ordered online, anyway, which is just too much of a faff (unless it's Rapha )
#3748
Liked 3,780 Times
Likes For abshipp:
#3749
VFL For Life
Liked 1,942 Times
#3750
Liked 3,780 Times
abshipp gets it.
Checked most of my boxes in what I want in a frame, but the paint was red with tiny gold flake in it.
Hideous. Such a shame they ruined what could have been a great bike.
