Resonance danger
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 13007 Post(s)
Liked 7,921 Times
Hey guys, have you ever had your bike start to vibrate rhythmically? Normally I’ve seen this when riding without hands, and the handlebars start to shake and can quickly escalate into something dangerous. I think of this as resonance, and was very happy that my carbon road bike doesn’t seem to exhibit it, but after a few trips to the shop it now has developed a resonance.
Can someone who knows what I’m talking about expand on the phenomenon and suggest recourse, other than holding onto the handlebars?
Bikes: everywhere
Liked 7,921 Times
Scariest ones I've ever had were on skateboards. Luckily we didn't have video back then
Gimme a sec to reach for my big can opener to open this industrial-size can of worms...
Let's start simple. All bikes (except experimental ones probing this subject) have trail/caster; Caster is the perpindicular distance from the steering axis to the center of the tire/road contact point. Trail is the similar measurement from the steering axis/road intersection to the center of the tire/road contact point, parallel with the road. Both pretty much mean the same thing. Henceforth I will mostly use the term trail, except when talking about caster angle on cars, which is analogous to the steering axis (head tube) angle on bikes.
The reason for trail is to have some centering effect on the steering when the bike is moving, i.e., stability, even so much as to be able to ride no-handed. With most bike geometry, having the fork straight and inline with the steering axis, results in too much trail, this can make the steering feel heavy, and also wheel-flop, where, at rest, weight on the bike causes the steering to flop one way or the other, unstable. So, the fork is either curved forward, or kept straight but inclined forward, to reduce the trail to a reasonable amount, which on most bikes is about 40-70mm.
A longer trail provides more steering centering force at speed, generally a good idea, unless excessive. Let me digress for a moment:
The Chevy Monte Carlo, I think second generation so 1973 I believe, GM's goal was for it to behave on the highway, especially high speed interstates, like Mercedes-Benz sedans, designed for autobahn speeds. 'Benzes had a lot of caster angle (for a car) so long trail. GM copied this caster spec for the Monte Carlo. And, the Monte's larger tire diameter meant that for the same caster angle, the trail value was longer, so a longer moment arm from the steering axis, that was the first mistake. The second problem was, the steered mass of the suspension (knuckles, brakes, wheels, tires, steering linkage) of the Monte weighed a ton compared to the carefully designed and svelte 'Benz components. Third, the front-end mass of the whole car, was much heavier than the 'Benz, so once moving, acts as an additional forcing imput. A freeway speeds, you turned the wheel a bit on the 'Benz and it recentered itself positively, with little to no overshoot. The same move on the Monte (as originally designed), hands off the wheel, the heavier steered mass and longer moment arm and heavier car mass, gave the correction more momentum, and it overshot center and went the opposite way, further than original steering input, then went the other way in an even greater overshoot, etc, and you had "divergent oscillation", the car, um, "departing from controlled flight", to borrow an aviation term. At this point the design was fairly sealed, expensive tooling was already complete, so no time to redesign, so GM added a damper, essentially a shock absorber with equal forces in compression and extension, mounted horizontally under the front end and connected to the lateral steering linkage, and this was sufficient to "critically damp" the oscillation to achieve steering centering without overshoot. So regarding that copied caster value, to quote my father, "A little knowledge is a dangerous thing."
This problem became further complicated with the debut of front-wheel-drive cars, so under engine load, the forces on the steering could get reversed, the tire contact patch, behind the steering axis, but being pulled *forward*, unstable, just like backing up a car or bicycle with positive trail. And, they hadn't mastered torque-steer, caused by "spindle offset", the horizontal distance from wheel center at wheel spindle height, to the steering axis. So the same thing happened on cars with much smaller and lighter steered mass and smaller trail. Some added steering dampers, some solved with better suspension design to eliminate spindle offset.
How're we doing? Are you with me so far?
Getting back to bicycles...
So... steering oscillation on a bicycle is a complex matter, involving trail, steered mass and polar moment (not just mass but how far the mass is offset from the steering axis), and, an additional complicator, that the bike and steered wheel can tilt left and right much more than on a car, so additional forces like camber thrust come into play, as well as the tilting inertia of the bike, cargo, and rider, and the rigidity/elasticity of the rider with the bike.
Trail can be a good thing, a stabilizing effect, if not excessive.
Steered mass and polar moment can be a good thing, a stabilizing effect, if not excessive. Notably, small-wheel bikes, less gyroscopic inertia due to smaller wheels so less steering stability due to that (more "agile/twitchy" steering depending on your personal preferance), can benefit from an increase in steered mass and polar moment, to help "calm" the steering, this is known as a "mass damper", which exist in many forms. The location of that mass, forward or behind the steering axis, also matters a lot.
(to be continued, I want to post the above before lost)
It's very late, I'm tired. I will try to continue this tomorrow or the next day.
Likes For Duragrouch:
It used to happen with my (now long gone) touring bicycle when full front panniers were attached AND I held the butterfly handlebars at the sides (parts that run parallel to the wheels and frame). It would take maybe three to four seconds for vibrations to become dangerously strong and very unpleasant, and all it took to stop the vibrations was moving at least one hand to a different spot on the handlebars.
Panniers had to be full and closed tight, because any movement inside them would dampen the oscillations and prevent them from becoming too strong.
707s had a nasty tendency of dutch roll oscillations if the yaw damper (directional autopilot) was out of calibration. Early pilots struggled to control it for terrifying minutes. Rapid, small but sharp aileron inputs would upset the natural frequency of the oscillations and the plane would straighten out. Like if you have a swinging pendulum on a wire, grabbing the wire midpoint and rapid small shakes in the direction of the oscillations, and it breaks the natural frequency and the oscillations die out.
Damp. Not dampen. One is dissipating energy, one is moisture.
"Chino is a style, khaki is a color." - Jamie Buchman (Helen Hunt), Mad About You, 1990s.
English is not my native language so I definitely don't want and intend to argue, but I had to check this because I have used "dampen" in that context many times over many years.... which doesn't make it any more correct, of course, and could mean that I made the same mistake many times over many years. So I went to the all knowing internet, and it told me this (so it must be true):
to check or diminish the activity or vigor of : deaden
to become deadened or depressed
dampen someone's enthusiasm
https://www.merriam-webster.com/dictionary/dampen
https://dictionary.cambridge.org/us/...english/dampen
Likes For cyclomath:
Randomhead
Liked 3,802 Times
Quoted: 6357 Post(s)
Liked 4,959 Times
Just curious LarrySellerz , Does the bike you get this on have a much longer head tube compared to the others? I've had death wobble when going at high speed down hills. The bikes I experienced it on all had very long head tubes. They were also steel bikes from BITD. Haven't had it on the few steel bikes I've had from BITD that had shorter head tubes.
The resonance you talk about does seem to be in the front doesn't it? If you are talking about the resonance you get at higher speeds and higher power into the pedals when in the 12 or 11 sprocket, then I get that too sometimes on most any bike. However that is never perceived by me as dangerous. Just a interesting feeling that lets me know I'm in the "zone".
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 526 Times
I had it happen to me when I had a loose headset. Tightening the headset fixed it.
Likes For mtnbud:
pan y agua
Quoted: 1483 Post(s)
Liked 767 Times
and balance your front wheel. Wheel balancing is easy. Put your bike in a stand and rotate your front wheel, let it turn freely, and see if the same side always comes to the bottom. Take a bicycle computer magnet, the kind which attaches to a spoke, and put it on a spoke on the opposite end. You can move the magnet up or down the spoke to change its effect on balance. The wheel is in balance when you can spin it, and it stops in any position randomly.
I think many people intuit a need to balance bicycle tires from the fact that car tires need balanced. However cars with 40 plus times the mass of a bike and rider are subject to much different forces.
I have wheels that obviously were out of balanced and wobbled very noticeably if you turned the bike upside down and spun the tires. However, the effect was imperceptible when riding and didn’t lead to a speed wobble. As Jobst pointed out we don’t ride our bikes turned upside down or in a work stand.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Likes For 13ollocks:
Liked 4,959 Times
I think what you're describing is chordal action - a vibration or "thrum" you get through the drivetrain when pushing a small (11t or 12t) sprocket - not dangerous
But perhaps you are just using my comments to bolster the posting of the link. (which I've seen many times)
pan y agua
Liked 767 Times
Few more thoughts on tire balancing: 1) all wheel/ tire combos come from the manufacturer out of balance due to the weight of the valve stem, yet we don’t see all new bikes wobbling around (and good forbid new bikes with wheel reflectors); 2) if you’re riding tubeless you would need to constantly rebalance due to shifting and uneven distribution of sealant sticking inside the tire, and 3) if you’re balancing by adding weight, there is going to be a small efficiency disadvantage.
A quick search reveals no actual data to support a benefit from wheel balancing. With power meters being ubiquitous, any efficiency advantage would be pretty easy to show. A reduction in vibration might be a bit more difficult to measure but could be done with an accelerometer. Yet I see no such data.
So if you want to balance your wheel by placing the speed magnet opposite the valve stem, knock yourself out. But if you’re doing it by adding weight realize there is a price in efficiency albeit small, for no advantage that has been documented or can be perceived while actually riding by the vast majority of riders.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 351 Post(s)
Liked 199 Times
Likes For Viich:
Bikes: Shmikes
Quoted: 10233 Post(s)
Liked 5,957 Times
Yup, a major factor in my hesitancy to do long rides in cold weather. Shivering is in the 8-11 Hz range, the activity is synchronized across muscles, and the bike always seems to find a nice harmonic for its death dance. Just terrifying.
Likes For MoAlpha:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1267 Post(s)
Liked 341 Times
My tour bike sure has a shimmy with the full load on the back, so no riding without a hand on the bar. Doesn't stop me from doing anything else though. Maybe the head angle is too slack, 70/ 70d.
And unloaded doing my downhill speed runs to 45 mph, it has a weird hum from the front somewhere at about 22 to 33 mph, tires likely.
With my old Raleighs I would use my knees against the TT the few times they went fast.
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 148 Post(s)
Liked 324 Times
Maybe a variation on what you're experiencing, but I have a bike with a shock-absorbing stem that amplifies a paving irregularity as I descend a nearby bike-pedestrian bridge. First time I experienced this it nearly had me crashing into the bollard at the end of the ramp. Very sketchy.
I feel the undulation on other bikes but they don't amplify it. Learned to use back brake only when slowing my descent and that lets the stem travel but not transmit as much vibration to the entire bike. The whole thing is very weird, and site-specific.
Have experienced oddities on long descents with other bikes and just had to cope in real time, usually getting off the saddle and moving my weight back. Sometimes, rural roads will have periodic irregularities that a road bike will resonate to. Exhausting to ride. IDK how folks race cobbles.
Motorcycles with bad suspensions and whippy frames are a whole other level of "fun." Some were even given a shock to stabilize the steering, which to me was always a sign to "stay away."
Quoted: 4887 Post(s)
Liked 4,052 Times
My 20" folder on fast descents, I either need to sit, or if standing for more air drag, clamp thighs around seat, to prevent speed wobble.
Similarly, dampener is something that can make something wet or quell enthusiasm like noted above, whereas damper is a device to reduce motion or energy, or flow, like a furnace damper.
No worries. I was one of those people who referred to casual cotton twill slacks as "khakis", until I heard the enlightening quote I mentioned. I hope you took my comment in a friendly way. But I can definitely understand issues with language translation; Though I have an ear for accents, I have a terrible mind for vocabulary in a foreign language, that has prevented my achieving any level of fluency in any of them.
And listen, the USA has had leaders in government who pronounced "nuclear" (new-clee-ur) as "nucular". So I'm very impressed with your knowledge and command of english, compared to my zero knowledge of your language (from your profile, Serbian?).
Quoted: 920 Post(s)
Liked 2,112 Times
My 60cm steel Soma Fog Cutter rando build wobbles if ridden no-hands, somewhere around 15 mph. I don't usually ride no-hands but sometimes zipping a jacket or peeling a banana happens. A knee on the TT takes care of it. Different tires maybe changes the speed, but it seems a permanent feature of the bike.
I love how the FC looks and rides aside from the wobble.
This compelled me to buy a new rando bike, so it's not entirely a bad thing
Likes For downtube42:
