Ask your small, random, track-related questions here
#5801
stripped threads on hub lock ring side
I bought a used Miche Primato track hub (only fixed on one side, nothing on the other) and I foolishly built it on some Mavic Open Pro's before checking the threads.
The threads for the lock ring are striped. I can get only 1 rotation on it before the lock ring slips. Any advice on this? Is there a way I can chase the threads or retap them? (And yes I have been tightening the lock ring anti-clockwise)
It would be a shame to deconstruct the wheel and the cog threads are fine.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/img_0600_f0be5c873eed9470539a6c425adadd2f09b85b46.jpg)
the initial thread on the lock ring side are stripped on this hub
#5802
Unfortunately not a good way I know of to recover that.
If the wheel is track only... you could run it without a lockring, a fair amount of people do that.. and once it's on tight (a few good pedalstrokes) it will take some consistent backpressure or skid type maneuver to unscrew it.
Once, for a mountain biker we used a bottom bracket lockring we had laying around and screwed it onto the hub (same threads as the cog) now obviously in that scenario the cog and the lockring would both have the same directional threads, but with no directional force on the lockring (like the chain puts on the cog) it would be tough to spin it off.
Likes For Morelock:
#5803
Sorry Morelock if I am responding improperly to your last post. Couldn't find out how to change the subject. I was reading about pedals in the earlier thread (2014 ish) and am in need of getting a new pedal system Ultra or Dura Ace level is ok by me. it seemed the old PD-7810s were highly recommended over some of the others but have been discontinued for a while now. I will be riding more of the enduro stuff at a Masters level (if we ever get out of this mess of a Covid 19) so standing start in the 500 and pursuit and mostly just general riding. So all who are we liking for all around Track pedals available today? Thanks in advance.
#5804
Moke Honestly all (big brand) pedals in the current day/age are fine for track for the vast majority of us. For everyone else, there are plenty of strap systems/diy solutions to make sure you don't pull a pedal. All the major brands have been used (successfully) by pro's/top sprinters.
Shimano, Look, Speedplay and (eww) Time are all acceptable
![Big Grin](images/smilies/biggrin.gif)
#5805
Bike recommendation for njs build?
Hi, new here, not sure if right thread or way of posting. Could someone please recommend me a nice japanese frame for an NJS type build? I know the 3 rensho, Nagasawa and Anchor but the well know companies are too expensive for frames. Is there a great steel frame I can get cheaper? Like maybe something vintage (nishiki, sekai) but with high quality steel? Steel and price are important, not pedigree. Also brake holes in the forks are needed. It doesn't have to be a track frame per se. Thanks in advance. Cheers
#5806
8pilgrim8 and Phil the power Taylor are 2 eBay sellers selling used Kieren gear from Japan, Phil does more frames. A lot of the frames will be dented but it might be worth looking there, just check the frames carefully.
#5807
#5808
Just curios; why do you want such a bike?
#5809
You won't find an actual NJS bike with brake holes, but Panasonic does make a road training version of their NJS track frame you can fit F&R brakes to. Prices are going up on those and I think they are now around $1000 for a new one. And they will make them to order for you. Last I checked there were some western vendors who sold them to non-Japanese speakers.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/800x400/1589240994_755f9b9af7fa27c66ee3600a0982543dbca7e960.jpeg)
#5811
Is there a good app for lap counting? I'm not a track cyclist, but going to be doing some laps at my local outdoor velodrome (because it's so close to my house). Ideally, I'd listen to a podcast, but get audio interruptions every 10 laps or so. Is there anything like that?
Likes For Minion1:
#5813
Elitist
2: Audio signals are common on the track, like "STICK!", "STAY!", "RAILS!", or "BOARDS!". Headphones are prohibited because you wouldn't be able to hear such commands.
The two rules above can be summed up as: It's not just about you out there.
#5814
1: Take a certification course. It's not just about teaching you how to stay upright on the track. It's also about keeping you safe so you know what to expect and what's expected of you.
![Smilie](images/smilies/smile.gif)
#5816
Hi Carleton,
I'm on the fence between Dura Ace 7710 and Sugino DD2 cranksets. Seeing how the DD2 are relatively new, is the Dura Ace becoming "outdated" even though it's still considered very high quality? Which would you go with?
#5817
Elitist
The Dura Ace has been used at the highest levels of the sport. They are the cranks to which all others are compared. If you get a set now, they will last longer than the typical track career. The only down side is price. A new set of arms and bottom bracket can be expensive. That being said, they hold a really high resale value and can be sold very quickly.
The DD2 may be just as good, I just don't know anything about them. I do now that they've been out for a few years now and for some reason they aren't popular. Not sure why. It could simply be that SRAM Omniums own the lower end of the race market and Dura Ace own the higher end (power meter cranks aside).
#5819
That would be gain ratio, which is obviously personal depending on your crank length and also your wheel size and tyre size. The gearing charts are a nice basic way to compare gears to gears. If you're picky, most of the available tables reflect a nominal 27" wheel rather than the now most widely used 700C wheel. Gain ratio only really matters if you're comparing one person's gears to another person's. If you're looking at your own, the other factors outside of chainring/cog cancel each other out
#5820
Having ridden bikes with like or higher gearing and short cranks there is definitely a noticeable 'easiness' from riding shorter cranks (even 5mm)..
#5821
Taper week: less intensity, duration or both?
G'day all
I've been training for a short time trial on the track. 3 laps from a standing start. If I had to put a label on it, this is typical 'pursuiter' profile, less than three minutes flat chat. Spent the past few months doing weights and stretches mixed with endro and lately power sessions on the bike. Training times are coming down nicely. I'm in the Master age group (recovery takes sooooo much longer than it used to!) The big day is 2 weeks away...
This is my first serious attempt at a track training plan. I'm curious as to how best manage my final week. Taper seems sensible (fresh and loaded for the big day). From what I can gleen, there are three choices: 1. Keep the duation of the bike workouts but wind the intensity back to 50-70%; 2. Keep the intensity but drop the duration by a similar amount; or 3) drop intensity and duration for the final week - spin short and easy.
My confusion mainly stems from the advice I've seen being aimed at endurance athletes. Can't seem to find a lot on power/sprint training.
Sage council of the hive mind gratefully appreciated![Smilie](images/smilies/smile.gif)
Cheers
W
Cheers
W
#5822
From what I know and what I've seen.......it's personal. A taper is widely prescribed, but I know a few high level masters riders that either do minimal taper, or no taper at all. It's something you will need to test on yourself to see what works best for you. Unless you've done some testing on yourself already, perhaps just pick an option and see how you go. You could get 10 different answers on here, but you won't know what works best for you until you try something out and see what the results are.
I would go back and look at your training. If you're knocking out quality training sessions 2-3 times a week and your numbers are constantly going up, why would you go and do a soft taper week? Maybe give yourself 2-3 days break prior to comp rather than a whole week. Alternatively, I know a masters guy who can only really manage 1 all out session per week, yet he is also hands down the fastest rider that I know (almost WR fast) and he would do a managed taper of up to 2 weeks prior to competition. Different strokes for different folks
#5823
Thanks Brawlo. Yeah, it's that overwhelming desire not to stuff a few solid months of training by getting it 'wrong' at the end!
Times are headed in the right drection but I wouldn't say the legs felt "fresh". I suppose you're right though. Pending further input, I'll go with instinct and see how it ends up.
Cheers
W
Cheers
W
#5824
Elitist
In the roadie/enduro world, nothing is a maximum strength effort. So, there isn't really a need to maintain peak maximum strength going into a big event. It's all about having a healthy and vibrant fuel system (red blood cells, nutrients, etc...). "Blood Doping" is a cheat because it replaces "fatigued" blood with fresh blood rich in red blood cells extracted when the athlete was fully recovered some time in the past. Red blood cells carry oxygen. More means more efficient energy transfer.
Speaking generally about strength training and peak performance:
Growth comes from a mix of Intensity and Volume. One without the other won't yield much overall growth.
Intensity is how hard something is. Volume is how much you do. Programming is adjusting the levels of Intensity and Volume depending on the goals and time period.
For example, when training for strength sports not only do you want to lift progressively heavier weights, you also want to induce a "training effect" by adding more sets and/or reps. This is a stimulation and overcompensation pattern. Basically, trick your body into thinking you need it to be stronger in order for you to survive (or die) and your body will respond (e.g. subsistence farming for a literal living...as in to eat)
When peaking for strength sports, even in the 2 weeks leading up to your big event, you want to keep the intensity as high as you are currently in your program, but you want to cut the Volume.
The way this looks in practice is:
- If you are in the gym: do your normal warmup routine for, say, squats or deadlift and do one working set then shut it down.
- If you are on the track: do your normal warmup routine and a handful of full-gas efforts (standing starts, standing half-laps, flying 100s) with full recovery between efforts, then shut it down.
These will result in abnormally short workouts and abnormally short recovery periods (you won't need as much food or sleep).
It's not uncommon, and actually quite common, for sprinters to hit PBs in the gym during the week leading up to their big event of the year while their enduro teammates are "tapering" and doing very light work on the bike.
Just be aware that there will be a couple of weeks of peak performance followed by a deep trough of lack-luster performance.
Many sprinters will record PBs the week of Nationals only to fall flat when they race at home a two weeks later, maybe even logging season-low numbers. That's normal.
#5825
Many sprinters will record PBs the at Nationals only to fall flat when they race at home a two weeks later, maybe even logging season-low numbers. That's normal.
Re strength, I've got good results following hypertrophy (build muscle) and strength (what to do with it) path. Highly recommended. Google it
