Show Your Vintage MTB Drop Bar Conversions
#7326
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Liked 479 Times
i find top tube length varies a lot by era, brand and even model. By 1990, TT lengths got incredibly long. But during the early to mid 1980s, many weren’t. I’ve had the same size frame, same brand, where one top tube was two inches longer. Same year, same brand, different model.
Now I own a 1999 Peugeot Dune mtn. bike which I've had to add some elevation to the stem just to make it feel normal. I really want to try a drop bar conversion but I just don't think the geometry on this bike would be very comfortable after a while.
#7328
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Liked 220 Times
Here's a recent iteration of my '89 Stumpjumper Comp, though a few changes since I took this pic:
#7330
Must be symmetrical
1992 Corratec 2005
Still a few things left to sort out, but basically there.
Corratec 2005 (from 1992). Tange MTB Triple-Butted tubing, 1-inch threaded steerer with NOS CrMo quill stem, ITA bottom bracket. XTR M951 rapid-rise derailleur controlled by an Ultegra/600 barend shifter. Tektro RL-520 long-pull levers controlling XTR M951 Vs. I modified the cable routing out of the levers to decrease friction and installed barrel-adjusters in the noodles.
I decided to preserve the patina of the cracking decals with some minor touch-up and a brushed-on clear coat over the art.
They just don't paint 'em like this anymore. Modified Xtasy QR and original Kalloy seatpost.
#7331
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Liked 90 Times
Love this!!! What bars are those? They look pretty awesome!
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
Likes For RobertUI:
#7332
Bikes: TRIMMED DOWN THE HERD
Liked 958 Times
#7333
Likes For BocaJr:
#7334
Must be symmetrical
Ha! Was wondering of i would get away with that.
Yup, will take one tomorrow morning.
The side shots of db conversion always strike me as a bit awkward looking, though. I have been trying to figure out the best angle for these bikes, still haven't yet. This angle highlights the brake levers, of all things, which is the part i am least happy with on this build--would rather they be more period correct, still aero, but smaller.
Since this one has fairly thin tubing and with the 1 inch quill, it looks a bit insubstantial from the side. But yes, will oblige.
Likes For Frkl:
#7335
Eccentric Old Man
Liked 173 Times
Likes For eom:
#7336
Must be symmetrical
Corratec is a German brand better known for its bow bikes, crazy anodizing, and neon color schemes.
#7338
Must be symmetrical
That was the idea, at least optically. They had a continuous arching double top tube that bowed into the seat stays. The seat tube was braced between them and extended up a lot. The design looks cool, but i think the engineering is not quite on the same level as the bling. I would worry they would crack.
This example isn't mine, but shows early adoption of disc brakes using adapters.
My examples are from the period before this became their main design theme.
I can put up some more catalog screenshot tomorrow.
Likes For Frkl:
#7339
Liked 2,101 Times
Who's used on of these to good effect?
I picked up a 92 Schwinn Impact Pro without thinking about steerer tubes. While the stock stem might work, I have a Nitto dirt drop stem ...
Shin for 25.4 to 28.6
#7340
Must be symmetrical
I am sure there are look-alikes out there that don't work as well, though...
#7341
Must be symmetrical
On it's way
Pressure and expectations!
So here are some more photos. I was unfortunately not able to get out to my favorite graffiti wall, but the local park will have to suffice. I think I am getting better at taking these pictures, they turned out ok.
Just to quickly address the unique choice of cranks--I run really short cranks (here 152mm), due to knee problems--which the cranks have solved. One of my go to cranks is this not-so-pretty Suntour. I wrote more about the whole crank thing here, if you are interested.
Yes, you counted right, I am running the original 14-32 7-speed cassette. That is one of the "almost done" parts of the build. I will either swap an 8-speed freehub assembly on, or build an 11-32 7-speed cassette.
Original splatter-painted water bottle cage. Here you can also see the cracked and incredibly intricate decals. The brushed on clear coat worked surprisingly well and the decals are now completely sealed. I plan to use this bike a lot--it's not for display purposed only. The clear coat should keep the decals from deteriorating further, and they also capture what was actually a turning point in how Corratec finished its frames: in 1993, they switched to vinyl stickers instead of wet transfer decals.
I repacked the bearings on the XTR Vs (these are one of the few--maybe only--brakes that have bearings, not bushings, at the post interface; and they can be completely serviced). You can also see how the splatter paint adds texture to the finish.
A bit about the company--Corratec is a German brand that outsourced its production until the mid 1990s to Italy, as did a number of German and Swiss bike makers (e.g., Kotter and Titan). This explains why the frame had an ITA bottom bracket. The company took a lot of technological risks--you could either say they were really brave and innovative, or they liked to charge blindly into dead end allies. For example this bike in 1991:
There is probably a reason we don't see many of these anymore . . . They produced both road bikes and mountain bikes in the "premium" segment, so their offerings were always priced high but with attention to detail. The 2005 that was the basis for my build was their "mid range" mountain bike. But things like slack angles make for really good drop bar conversions, in my opinion, since the drops remain further behind the front axle, and since they are overall more comfortable for longer rides.
The really became known for their bow bike designs, which appeared in 1993, for their inverted "dropped" bullhorn bars (1992, my 2005 came with the first production run of these bars; they are going to go on my comp-level 2004, which i am going to keep closer to spec), their super-bright-even-for-the-1980s paint jobs, and or their early adoption (1995) of disc brakes:
Why go disc? Well, if you anodize your rims bright red, then you can't use rim brakes, so you need to settle for discs . . . sorry.
Likes For 2cam16:
#7343
Must be symmetrical
Likes For Frkl:
#7345
Must be symmetrical
Nice looking conversion, and superb choice on the stem, Grant would be proud!
A question about how you oriented the bar end shifters. Since those bars are flared, right? Do you prefer them to shift in the vertical plane, despite the flare, or on the plane of the flare? I've never used flared drops so was wondering what feels better.
#7347
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Liked 1,304 Times
#7348
Must be symmetrical
Likes For Frkl:
#7349
Must be symmetrical
But if you want a colorful anodized frame for display with historical significance, a Corratec is a bargain.
Likes For Frkl:
#7350
