New to Moisture - XL KHS Flite 720
#76
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Liked 193 Times
Most road bikes are very similar in fit, components and frame geo. I would have opted for an endurance road bike if I found one for sure.
I dont think there's anything wrong with the frame fit, unless I just don't fit on any road bike that's ever been designed for people my size.
#77
Clark W. Griswold
Liked 4,566 Times
#78
Liked 9,462 Times
Likes For WhyFi:
#79
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Liked 621 Times
Likes For Badger6:
#80
Liked 9,462 Times
#81
Maybe we're being too hard on the OP. We know he's a tall fellow... Maybe he's oddly proportioned? Might be tough to get the right fit.
Who here remembers "Stringbean" from the old Hee haw show? I wonder what kind of bike would fit him.
#83
Sunshine
Liked 8,075 Times
Based on things you have said, you are in your mid-20s and a body builder so you are clearly both young and in good shape. You dont have some extreme fitment issue due to age or injury that is keeping you from fitting on a road bike.
Instead of trying to go for a look(which you mention you are going for on this bike), try to go for fit first.
- Just use the crankarms that are on the bike and set the saddle at the appropriate height. Ignore all your temptation to slap a goofy long crankset onto the bike and just get your leg extension set properly.
- Next, set your saddle angle and placement on the seatpost. Get it so it is in a neutral level position since when it tilts down that places weight on your wrists and makes you constantly counter the sliding by pushing back.
- Then, set your bars in a comfortable height and reach. If you need, get a 17deg rise 80mm stem so it is crazy high and short. Start there and work your way both out in length and down in angle. Stop when it is comfortable.
Thats really it- nothing magical. Notice that I didnt suggest you slam the stem for a look and then figure out fit from there. Your bike isnt built with aggressive race geometry.
Likes For mstateglfr:
#84
If y'all enjoy Moisty's fit advice, he and the other one are handing it out pretty freely in Fitting Your Bike.
#86
Drip, Drip.
Liked 193 Times
Thank you guys, I will adjust my saddle a little and get some help with some pictures.
I'm not sure why you guys think I care about aesthetics with this bike? Not important to me at all. Only fit is. This is why I posted pictures.
I just ordered some surly truck stop bars in 48cm size. The reach and drop is on the fairly conservative side which should work well with the long stem and top tube.
[MENTION=385973]mstateglfr[/MENTION] obviously you understand that everyone has awkward proportions? My inseam is 46% of my total height which isn't wildly disproportionate, but I certainly do feel that is messes with my bike fit a bit. I also have very long arms which makes things a bit more complicated still as my torso is relatively shorter, but I need extra space for my arms to stretch out anyways.
I've tried a 90mm stem +7° and it felt too short. With some small tweaks to saddle position, stem length and the new handlebars I should get into a much more effective position. I am not far off - just need to make the position more comfortable so I can sustain great performance even when im starting to become fatigued.
The bottom bracket is 267mm, which like I said will cause striking around turns even with 175mm arms. No way I'm going longer than that.
#87
Drip, Drip.
Liked 193 Times
hazetguy no pictures on fantastic KHS as of yet. Fit pictures coming. Unfortunately no more riding until the roads are dry and clean.
Likes For Moisture:
#89
Drip, Drip.
Liked 193 Times
shelbyfv the Surly bars are literally almost the exact same in sweep and drop/reach, just 2cm wider. So you prefer the 12° sweep over typical straight drop bars?
#90
#91
Liked 9,462 Times
In fairness, it does look like he's got some big honking platforms on there - maybe they do strike rather easily
#92
Likes For Koyote:
#93
Sunshine
Liked 8,075 Times
I've got it all planned out now with my KHS.
Eventually, id like to settle with 100mm angled aggressively downwards with the degrees and at a pretty low stack with both my bikes.
I am sure you still won't understand why I think you are going for look vs fit, but its there plain as day.
If reach is all that's an issue, Amazon a few cheap stems of varying length and return the ones that don't work on initial fitting.
Grab a cheap dumb trainer from almost anywhere and use it to dial in fit at home. It's all sitting on a trainer so you will feel a poor fit relatively easily.
#94
#95
Drip, Drip.
Liked 193 Times
[MENTION=385973]mstateglfr[/MENTION] interesting, it looks like we are proportioned about the same, you are like a bigger version of me xD
Like I said, aesthetics is totally irrelevant to me? Said it again.
[MENTION=90165]shelbyfv[/MENTION] I compared the drop and reach on both those bars and they were within like 2 or 3 mm of each other despite the 30mm rise.
the rise wasn't really all that important for me - I was just looking for a drop and reach at or less than stock (125,80)... I realized that going from 44 to 46cm wouldn't be worth the effort and only settled once I found something that was 48cm. Looks like I actually bought the last pair in that size from the website I found.
I'm looking forward to trying out the 12° sweep! That should feel nice.
Ultimately I'm still looking for a slight upward angle on the stem because this frame has an aggressively low stack. I think those bars will work great for me anyways because they are almost exactly my shoulder width.
#96
Drip, Drip.
Liked 193 Times
shelbyfv the surly bar is 3mm less drop and 1mm closer reach despite the 30mm rise, just checked.
I just read somewhere that the width in the drops is 535mm or something like that? Was hoping to stay closer to shoulder width, would there be any issues with that on such a road bike?
#97
I guess you could geometry the width at the ends since you know two sides and an angle. Or wait until you get them and measure. Either way, I think you would scrape the pedal before the bar end.
#98
Liked 3,933 Times
Alos .... I don;'t care how long your cranks are, if you are hitting pavement then you are doing it wrong. (Your bike does not have 170 mm BB drop .... the pictures show that.)
Just a note---if you are leaned way over, you will be more stable with the outside pedal down and all your weight on it. And don't pedal---hitting the ground is, like pain and badly positioned parts, a sigh that you need to make changes.
Here's a tip---90 percent of the people you pass think anyone on a bike is stupid and looks stupid, and of the rest, the ones who judge will think you look like a Fred unless you have the same brand of bike, wheels, drive train, and clothing they do ... in which case they will find you threatening. Ride your yourself, set up the bike for yourself.
Or don't.
I think the bike looks okay on a website.... but to me, any real-life bike which hurts to ride is broken and needs fixing, and I don't think broken bikes look good. Again ..... whatever.
Likes For Maelochs:
#99
Liked 621 Times
You provide a meaningless number about your inseam...how about you provide a metric or imperial length of your inseam length? That would be a really useful thing to know, to get a baseline sizing, not a percentage. If you walked into my shop and said, "Hey, I have a wonky inseam, it is 46% of my total height," I'd just look at you and say, "Okay." And then the conversation would turn to "give me a number I can use to relate to a bike frame size." Like, how long is your inseam standing on the floor barefoot? I don't actually own or work in a shop, but you get the idea, I think.
Your approach to the bar position is disastrous as well, but you've already been given solid advice on getting it right, so I will summarize in a simple to follow step-by-step: (1) by changing out stems, and removing/adding spacers if necessary, find the right position for the bar tops, then (2) evaluate the drops, if they still don't work for you, consider a different bar with a different bend and drop. Oh, and rotate the bar so the tops make a level (0° deflection from the ground) transition to the hood. You can adjust this a bit later if necessary, but I strongly advise against it. And, level your saddle, if you need a little bit of tilt on it, fine, tip the nose down 2-3°, which is not very much.
You need to stop this changing everything all at once business. Get methodical, one thing at a time in a logical order (most of your issues would be solved by figuring out: saddle position relative to crank axle (or pedal top), then bar tops relative to saddle, then make minor tweaks from there as you ride and figure out what works better). And if the bike doesn't fit, get a new bike. If you don't know what size bike you need (which seems like a real possibility), go talk to a shop. And DO NOT under any conditions start prattling on about your inseam percentage relative to height and short torsos with orangutan arms.
#100
How many bikes does he have now? I hope he isn't endlessly tinkering with fitment on them all at the same time. No wonder none of our advice sticks. If I tried that I'd probably end up with one bike with five wheels, mismatched crank lengths and a 300mm stem...
