For the love of English 3 speeds...
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
It's locked through the rear wheel, so you can't even get that? Pah. There's a fine rotting target for wheel confiscation a few blocks from where I live but it's directly outside the heavily patrolled Long Island Railroad terminal so I don't dare.
Quoted: 1299 Post(s)
Liked 103 Times
Hi fellows. The derelict fell through. It is slim pickings around here for Raleigh models (frankly any vintage bicycles of interest). I am in need of the clips for the chain guard since the bike came with the original guard unattached. As well as some newer brake specimens to make it road ready. Is there an online place where I could find these sort of items? There's another derelict locked up downtown that has sat for ages...but it is u-locked.
https://www.ebay.com/itm/Vintage-Ral...frcectupt=true
Quoted: 350 Post(s)
Liked 24 Times
Amen. I can save the hubs from the derelict bikes I find sometimes, but indicators, fulcrum clips, pulleys, other bits are rusted no-hopers.
Quoted: 1869 Post(s)
Liked 666 Times
Other threads here have discussed how good Everust is at removing rust with a soak. Can this help with the small parts you mention?
Liked 666 Times
Liked 103 Times
I've been using Evapo-Rust for small parts. It's much faster than vinegar, but not as nasty as working with OA. Works great on lightly rusted chrome. If you keep it waxed, the chrome will look great for years. Small exterior parts with that dull gray finish are more of a problem because the rust totally destroys the protective finish and will rust again quickly.
Liked 103 Times
Nortons are back. Crazy expensive though. I checked out the new Bonneville. They did a great job with the styling, but the thing is huge and HEAVY. Big radiator hanging on the front. 1200cc. All kinds of silly gagets, but at least it doesn't look like the Bat Cycle with a rear tire that looks like it came off a garbage truck. Keep in mind, this is coming from a guy that rides around on 3 speed bicycles. But now, there is a new bike on the market that I'm actually excited about. For years they have been making Royal Enfield bikes in India. Pretty much the old single cylinder Comet. Nice bike, but I need a bit more swat than a Comet. So they are a well established manufacturer with experience. They just introduced their new Interceptor. Beautiful bike! A classic 650cc air cooled vertical twin roadster. Simple, clean design, rather lightweight. I'm going to find a dealer and give it a try.
Bikes: 1951-2 BSA 900E Roadster, 1961 Triumph Sports, 1953 Raleigh Sports, 1981 Raleigh Superbe, 1976 Raleigh Twenty, 1951 Taxandria, ±1950 The Gold Lion Tandem
Quoted: 40 Post(s)
Liked 14 Times
No need to think twice when riding the motorbike...
Peter
Liked 103 Times
I used modern Tektro brake calipers on my Rudge scorcher. Those have the cable connections on the right side, so I have the cables routed right/rear to keep the neater looking cross out front.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,451 Times
This is what you need to resolve the dilemma. Just get two of these, one for the right side and one for the left and run both brakes from each. Ta da!!!
Quoted: 350 Post(s)
Liked 24 Times
It is cool those exist for riders who have the use of one arm. And possibly for a tandem fitted with rim and hub brake at rear?
Liked 2,451 Times
That one is at the co-op and I did not buy it. Yet.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 495 Times
If you only need the later style pinch bolt calipers and clips for the earlier style 2 point chainguard, it might be more economical to buy parts on eBay rather than a whole parts bike. Most any parts bike worth salvaging parts from will cost at least 75 dollars and at that, it would have to be an older one that has the 2 point chainguard. Took a quick look at eBay...here's some pinch bolt calipers.
Quoted: 70 Post(s)
Liked 29 Times
Removing Raleigh Lock Cylinder?
While I'm waiting for better weather to finish my paint touch-up on my '52 Raleigh, I've been trying to get the lock cylinder out of my fork to find the key code. (It's not on the face of the lock the way it is in some photos, so I assume it is on the body of the cylinder.
I can't get the plug out opposite the lock, even by heating the fork in the oven and putting ice in the plug, but I was, with great patience and a series of improvised tools, able to remove the screw from the back of the lock by working through the bottom of the fork and the holes for the brake bolt.
So now that screw is out.
I also found it very easy to pick the lock, and I was able to raise the pin. (I had a moment of panic when it locked in the upright position, but I was able to pick it again, and I now have it in the middle position, ready to lower all the way if I have to give up.)
But, I can't get the lock cylinder to come out, and I can't find any instructions. There's a thread about removing the lock from a Rudge that mentions turning the pin to remove it, but the pin doesn't seem to want to turn. I know better than to try to force anything when I don't have a clear set of instructions.
Does anyone know where I should go from here to get the lock barrel out and find the key number?
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
From memory when I removed the lock from my DL-1 fork, once I removed the retaining screw, the barrel was just friction fitted into the crown. I'm fairly sure I remember prying it out gently with a screwdriver. I used some online instructions, I'll see if I've still got them when I get home from work
Quoted: 70 Post(s)
Liked 29 Times
Here is a link to an image that might help... https://oldroads.com/mn0.jpg
Liked 103 Times
Take a look at post #23 in this thread. From what I understand, a standard Ilco BN1 K1122D blank will work. Without a number on the lock, I suppose you stuck finding a locksmith to ink and file the blank by hand. I know this can be done as long as you have the right blank.
https://www.bikeforums.net/classic-v...-lock-key.html
Liked 2,451 Times
Quoted: 149 Post(s)
Liked 30 Times
Well that's frustrating - I couldn't find the info at home but it was something I'd found googling around diligently. It wasn't hard to do but I hope someone else replies with something fresher than my memory... I do remember very clearly soaking the barrel in rust remover and everything getting quite foamy and then realizing that the barrel is made of a cast zinc alloy...so don't do that.
Quoted: 70 Post(s)
Liked 29 Times
Liked 103 Times
I clearly remember my father doing this. He had a small file. This one had teeth on the sides as well as the broad surface, so it could cut a V shape. This was a tool and die shop so we had a can of ink we used to lay out shapes on steel. I suppose any ink would do. He would paint the ink on the blank, wiggle it in the lock and file away the spots where the ink was scratched off. I don't think it was 20 minutes before he had a working key. But, he was the kind of guy who could make anything out of metal.
Old fart
Quoted: 3617 Post(s)
Liked 3,447 Times
Quoted: 70 Post(s)
Liked 29 Times
If only it were that easy. The face of my lock cylinder is completely blank, not even the suggestion of a number. I'm assuming that maybe older bikes, mine is a '52, might not have had the number stamped on the face like that, but then, I feel like I've seen some photos where they are. I am going off the assumption that I will find the number stamped on the cylinder somewhere hidden, if I am ever able to remove it.
Liked 666 Times
Just for future reference, I'll describe my plan B for this situation. So far, I've never had to go beyond this to be successful, but who knows? I may someday need a plan C but I haven't yet. If I see the threaded end of the cotter start to bend from pressure from the press, I file a small flat on top. Then I center punch the pin by eye. Then, starting with a small drill and working up in size as I go, I drill down into the threaded end of the cotter. The last drill I use is almost the size of the clearance hole around the cotter. I drill down until I'm well below the edge of the crank arm. Now, the drill leaves a nice countersink perfectly in line with the cotter. Then I find the biggest punch I have that fits neatly into the countersink. Then I lower the bike stand until the wheels are on the ground. Then I drill a hole in the end of a 2x4 big enough to clear the cotter. Then I fit the 2x4 so it fits snugly between the cement floor and the crank arm. Since the spindle and crank arm is being supported by the cement floor and the 2x4 and the force of the hammer blows is being directed exactly where it's needed, I have a lot more power on hand then I did with the press pushing against the threaded end.
Next: Remove the spindle, bearings and cups, soak and inspect, and clean the BB shell, also headset, frame cleaning and assessment, hub bearings, rim assessment, SKS Blumels fenders. I need to multi-task the work on this frame in parallel, otherwise it'll be three years before I can ride it!
I'd like to use a TA spindle with the original Raleigh cups and install my old TA Pro Vis crankset with a 48 tooth sprocket, but that's probably part of the hot-rodding phase, along with replacing the rims with aluminum. I don't think I want to re-tap the BB shell but I would be willing to cut down the BB shell ends to 68 mm, if it's necessary to make the BB bearings line up correctly.
I haven't seriously dealt with handling the finish. The frame certainly needs a good wash and some Evaporust treatments, but I don't know if I'm going to repaint. The original "livery" is mostly intact, with some nice white trim-lining over the original deep blue. A friend washed her mom's 1954 Schwinn three-speed, and some of the painted white vintage trim (wings painted on the DT) came off on the sponge!
The bike came to me with a carefully installed original Pletscher kickstand which is still intact, but I think I would put on a Sanyo BB dyno. Lights undecided. I have an FG hub (four-speed with dyno), but it's not ready.
Old fart
Liked 3,447 Times
It appears the stock cylinder is held in place by a bolt on the back of the cylinder. You may be able to access it by removing the thimble on the opposite side of the crown:
