Downtube folding bike
Old 05-21-14, 08:07 AM
  #2076
BruceMetras
Quoted: 113 Post(s)
Liked 8 Times in 6 Posts
Originally Posted by HK 45
Couldn't see anything about the pivot itself, only saw him adding a piece of rubber to the spring section.
8FS suspension springs are beefier so I don't really have a problem there.
This is the area that I'm referring to.
Maybe you missed the Bushing Fix
BruceMetras is offline
Old 05-21-14, 12:33 PM
  #2077
bhkyte
bhkyte's Avatar
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
Liked 3 Times in 3 Posts
I have had a creak also. The adjusting ring had come off the thread.
I have since loosen the adjusting ring on the spring and this has gpt rid of the noise. Need to tension the spring so I can thread thw ring back on. hopefully tread intact still.
bhkyte is offline
Old 05-21-14, 03:36 PM
  #2078
HK 45
Ah thanks, didn't notice that's what it was since it's already disassembled and I could see plastic parts. He also goes on about some other parts in the minis suspension.
I've been trying to disassemble mine for a while now but every time I try to loosen the bolt it wont budge an inch, just makes a lot of creaking noise when I apply counterclockwise force with a 10mm and 6mm allen wrench
Any special trick to removing it? I'd rather not break it if there's no way to get replacement parts easily
Already checked that and rode around with the suspension set to a stiffer setting, no change other than a rougher ride and faster speed. The creak only happens if I apply force to one side more than the other and I can see the rear end moving at the pivot.
It moves so much that the kickstand actually rubs my fat rear tire.
HK 45 is offline
Old 06-05-14, 04:51 PM
  #2079
HK 45
Well I finally managed to remove the pivot bolt today after heating it up with a butane torch before applying pressure, looks like they dip them in loctite at the factory.
It's identical to what Jur posted (with the exception of the 2 washers )so I assume that I'll be looking at similar sizes to what he posted for replacements.
First, the lateral play/slop does not come from this bolt; it must come from the suspension hinge. In my case, the 2 spindles were of different size, 19.92mm and 19.97mm, and the bushes being molded were both 20.00mm. So one of the spindles rattled around in its bush, and this cause the lateral play in the hinge.
HK 45 is offline
Old 09-26-14, 02:32 PM
  #2080
downtube
downtube's Avatar
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times in 17 Posts
We just posted new mini's at Downtube 2015 16" wheel 8sp mini and 8H's at Front suspension internal hub folding Bike 2015 . Both have Shimano Nexus 8sp hubs and Gates carbon belt drives.
I will post the 8H's on kickstarter in the next few days for $699+ship ( kickstarter prices have to be the lowest ).
I also have samples of some really nice kids bikes arriving.
Please share your thoughts.....
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
downtube is offline
Old 11-02-14, 09:47 AM
  #2081
JosephLMonti
JosephLMonti's Avatar
Quoted: 16 Post(s)
Liked 5 Times in 3 Posts
Has the Nova been discontinued, or simply out of stock at the moment?
JosephLMonti is offline
Old 11-02-14, 05:39 PM
  #2082
downtube
downtube's Avatar
Quoted: 282 Post(s)
They are sold out until next season.
Thanks,
Yan
downtube is offline
Old 11-04-14, 07:47 PM
  #2083
JosephLMonti
Quoted: 16 Post(s)
What would you consider to be next season? Any planned changes to the next gen of Novas?
Old 11-04-14, 08:02 PM
  #2084
downtube
downtube's Avatar
Quoted: 282 Post(s)
The season starts in April. The biggest change is a replaceable chainring, and adding fenders.
Thanks,
Yan
downtube is offline
Old 02-27-15, 12:57 PM
  #2085
Bikeman58
Bikes: Giant Defy, 1977 LeJeune #1 French Team Bike, Geoffrey Butler custom, Specialized Stumpjumper, Gary Fisher SuperCaliber, Bianchi Volpe, Melon Slice folding bike, Genesis folding bike, etc.
Looking for a new folding bike as my Downtube frame tubing cracked. Anyone have any suggestions for an affordable folder? I'm looking for a company that gives a lifetime warranty on the frame. Leaning towards Hasa, but am open to other ideas.
Bikeman58 is offline
Old 03-01-15, 06:08 PM
  #2086
BikeKraft
BikingYupik
BikeKraft's Avatar
Quoted: 9 Post(s)
yawn
I won't even waste a capital y.
BikeKraft is offline
Old 03-02-15, 10:44 AM
  #2087
downtube
downtube's Avatar
Quoted: 282 Post(s)
Originally Posted by BikeKraft
yawn
Is this comment directed at me? Bikeman58 purchased his bike used in 2007 (warranty was already expired ). It was produced in 2005 and sold in 2006 on ebay with a 90 day warranty (we used roman numeral names in 2005 & 2006). He rode the bike between 2,000-4,000 miles ( according to him ), and his frame cracked in 2014. He has decided to post the defamatory statements about us on this forum about 10 times. The last thread he posted was closed to due his comments.
He claims that we changed the bike frame due to his problem. Actually we widened and lengthened the frame many times over the last 9 years. Nearly every year I made the frame taller to accommodate taller riders. In 2010 I made the seat tube over an inch taller to match our 9FS frame, and we added support to strengthen the frame (the old frames were 2"+ shorter than the current models).
Thanks,
Yan
downtube is offline
Old 03-02-15, 10:54 AM
  #2088
BikeKraft
BikingYupik
BikeKraft's Avatar
Quoted: 9 Post(s)
NO.
You are Yan not yawn.
"Is this comment directed at me?"
Old 03-02-15, 10:56 AM
  #2089
downtube
downtube's Avatar
Quoted: 282 Post(s)
FYI when I was a kid growing up many kids actually called me yawn
Thanks,
Yan
downtube is offline
Old 03-08-15, 09:32 AM
  #2090
Rivle
Bikes: Raleigh Twenty, Cannondale Comfort 400, Montague Paratrooper
I'm thinking about getting a folding bike to keep in my car. Not many folders in my area, so I can't take any test rides of reasonably priced bikes. I like the Gates carbon belt drive. Does anyone have any experience with that system? I'm a little concerned about the bike's size also. I'm just under 6'3", with a 34" inseam. From what I've read, maybe the IXFS is the better fit. Any help is appreciated.
Rivle is offline
Old 03-08-15, 12:12 PM
  #2091
FlowerPedal
You should start a new thread for your inquiry with an appropriate subject. More people will see it and be able to help you.
Good luck with your search.
kathy
FlowerPedal is offline
Old 03-08-15, 03:55 PM
  #2092
tds101
55+ Club,...
tds101's Avatar
Bikes: 9+,...
Quoted: 1153 Post(s)
Liked 896 Times in 628 Posts
All I know is that the Downtube 8H seems pretty solid to me. I likely!
tds101 is online now
Old 04-03-15, 09:56 AM
  #2093
westgl
I am looking at either the Downtube 9FS or the Nova, looking at buying two of either one,
How long is the sale on for for all Downtube bikes.
I was wondering how much the Full Suspension Makes a a difference on ride comfort.
westgl is offline
Old 04-03-15, 10:20 AM
  #2094
downtube
downtube's Avatar
Quoted: 282 Post(s)
Folding bikes have smaller frames with smaller triangles which are stiffer. Smaller wheels are also stiffer hence suspension is more of a requirement on a folding bike.
That's my 2 cents.
Thanks,
Yan
downtube is offline
Old 04-03-15, 10:24 AM
  #2095
westgl
I just pulled the trigger on two 2014 Downtube 9FS bike's Hope my wife and i like them, with the suspension.
westgl is offline
Old 04-03-15, 11:00 AM
  #2096
invisiblehand
Part-time epistemologist
invisiblehand's Avatar
Bikes: Jamis Nova, Bike Friday triplet, Bike Friday NWT, STRIDA, Austro Daimler Vent Noir, Hollands Tourer
Quoted: 122 Post(s)
Congratulations! I hope you two enjoy them for years.
A narrative on bicycle driving.
invisiblehand is offline
Old 04-03-15, 03:14 PM
  #2097
westgl
Quite happy and surprised to see that Downtube shipped the same day i ordered them.
I bought the 2014 9FS what Rear Racks and Fenders fit this bike?
Not sure if it came with a kick stand or not, but what kick stand fits this bike?
westgl is offline
Old 04-03-15, 04:12 PM
  #2098
westgl
Would the downtube 9FS fit someone 4'11" tall as my wife is small.
What is the height range for the 9FS.
westgl is offline
Old 04-03-15, 05:48 PM
  #2099
mirfi
mirfi's Avatar
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 170 Post(s)
Liked 195 Times in 122 Posts
Yan would know, but you should see if someone has one near you and have her try it on for size.
mirfi is offline
Old 04-03-15, 06:05 PM
  #2100
westgl
I have read that some parents that own the 9FS let their 10 -11 year old kids ride them but how tall are they?
westgl is offline
