Bike Packing Camp Stoves
#201
Liked 1,589 Times
Yep, just like jetting in a carb.
I have read of folks claiming they actually preferred the results with the white gas jet when burinng kero. Some claimed less sooting and a bluer flame. Pretty easy to chalk up any advantage to just being their personal impression, but at least it can be assumed that they were successful in burning it. Elevation will have some effect on it too. So that could be a factor in comparing folks results.
Smaller jets for higher elevation is the rule if I remember correctly. So that would make using the smaller kero jet more important at higher elevations. At sea level you would be more likely to get by with the larger white gas jet. Or am I getting something backwards?
I know jetting isn't super critical on a camp stove, but if you were already marginal and went from sea level to 14k feet I bet it could make a real issue.
I do not recall the situation on the photo, but I have only had yellow flames like that from kerosene. This is my Omnifuel stove. This was clearly too rich. But that was over five years ago so exactly what happened here I do not remember. That probably was before I started mixing some white gas into my kerosene.
As far as elevation, I think you were thinking jetting in a carburetor, not on a stove.
On a carburetor, the fuel comes out of the jet as a liquid. Stove, the fuel comes out as a gas (vapor phase). So, with a stove you are mixing fuel (a gas) with air (a gas), elevation should not change the ratio.
My Optimus 111T in the photo below, nice blue flame, I think this was on coleman fuel. The stove is rated to burn either that or kerosene with the same jet, but the kerosene flame is more yellow. I have used kerosene in this stove too.
Photo below, my Optimus 111B, photo from this past Oct on my canoe trip. This is the first camp stove I ever bought. It is only rated for coleman fuel (or white gas) which is all I ever used in it.
One cold morning in northern Minnesota in the late 1970s, this was the only stove we had in our group that would work, it was minus 36 degrees (F) that morning according to our thermometer. It took a while to get it lit, a puddle of white gas in the priming cup was too cold to ignite, had to use paper matches like a wick to get the priming cup gas warm enough to burn. But once lit, it was our only functioning stove out of three stoves on that trip. I re-sprayed it a couple years ago, now looks as good as new.
This is quite off topic from the thread which is on bikepacking stoves, the 111T and 111B are a bit heavy and big for bikepacking. Sorry.
#202
Palmer
Liked 1,978 Times
Butane in 1972 was represented by the Bluet S-200 piercing cartridge stove.
Like most young men involved in the bike boom lifestyle, the editorial staff of Second Bicycle Two Wheel Travel Camping and Touring were enamored with all things European. They don't even recognize the existence of the American Coleman company. In 1972 you could still pick up inexpensive M1950 Coleman stoves at Army-Navy surplus stores.
#203
Mad bike riding scientist
Liked 4,537 Times
Just to be clear we are talking two different things entitrely if comparing ronson/zippo lighter fluid and charcoal lighter fluid. The ronson /zippo stuff is naptha and pretty much the same a white gas. The charcoal lighter is something else and pretty much the same as or at least very similar to kerosene. At least that is my understanding.
The mineral spirits you mention are closer to the latter, right? My understanding is that I ought to use the kerosene jet if burning mineral spirits in the whisperlite and it probably is a bad idea to burn them in the SVEA 123 at all. So correct me if I am wrong, but mineral spirits should be considered a 1-K Kerosene substitute. Everything I have read indicates they are not a white gas substitute.
Also, if you are at a place that sells mineral spitits there is a good chance they also sell naptha which should be fine as a white gas substitute, right? If resorting to buying a quart of someting from a big box store, hardware store, or paint store a quart of VM&P naptha typically costs about the same as a quart of mineral spirits and is pretty much the same as white gas as far as I know. Is there any reason why you'd prefer mineral spirits?
“Mineral spirits” is a somewhat broad range of materials. Odorless…which is the most commonly available now…is a C9 to C16 mix of hydrocarbons with a boiling range of 150°C to 290°C. Kerosene (C9 to C16) has a slightly higher boiling range of 180°C to 300°C. Naphtha, which “odored” or low flash mineral spirits and is a C7 to C12 hydrocarbon mixture, has a slightly lower boiling range than odorless mineral spirits of 90° to 230°C.
This only scratches the surface of a rather complicated range of products. You can see that there is a lot of overlap in terms of boiling ranges (a key to volatility) and carbon chain length. Mineral spirits is just a suggestion as it is widely available in smaller quantities than Coleman fuel and large quantities than cigarette lighter fluid. Again, it would be best to test any of these at home before leaving. A jet change may not be necessary for some and not for others.
Since my reason for looking for an alternative is for smaller than quart sizes I am out of luck with either the naptha or the mineral spirits any way, but the ronson/zippo stuff comes in several sizes ranging from 4-12 ounces so it remains the only naptha product I have found that I can buy 12 ounces or less. The other possible option is to burn auto gasoline, which I'd do in a pinch. That may be awkward to get a tiny bit, but possible.
Zippo lighter fluid is probably just a bit less volatile (being able to be converted to a gas) than Coleman fuel or white gas (which is not car gasoline and would make a car run very, very poorly). Charcoal lighter fluid is probably slightly less volatile than naphtha (aka type one mineral spirits or “odored” mineral spirits). Mineral spirits is slightly less volatile than naphtha and kerosene is less volatile still. In terms of decreasing volatility I’d rank the fuels as
Gasoline>>>>>>Coleman fuel (white gas)>Zippo>charcoal lighter fluid≥naphtha>mineral spirits>kerosene.
Gasoline isn’t a bad fuel but it is just too volatile to be used safely.
Switching jets and using something like kerosene or mineral spirits would be okay for my whisperlite, but since I have not found a source for less than a quart at a time I'll rule that out for anything other than an unforeseen emergency. I might have a different perspective if I travelled in different countries. I wouldn't put it in my SVEA 123 though.
I am looking at this like a chemist and just looking at the volatility and some composition. The various fuels are different but those aren’t necessarily huge differences. Most of them would work in a pinch and any of them from Coleman fuel to kerosene would be a far better alternative than gasoline.
Stuart Black
Stuart Black
#204
Liked 1,589 Times
My bike-boom era published-in-1972 Second Bicycle Two Wheel Travel Camping and Touring book recommends (remember, this is in 1972!) the 111B for group tours of four to six riders. For groups of two to three, they suggest the similar but much smaller and lighter Optimus 8R. For one or two, they recommend the Svea 123 with provisos on its sometimes cantankerous start-up:...
I do not recall exactly when I bought my Sveas, but it was soon after that. There was a tiny little store on the edge of downtown Minneapolis that was moving. Their store was on the second floor of a small building, maybe a thousand square feet of showroom space. They had a box of stuff that did not work, I offered them some small pittance for all of their Sveas, there were four, they accepted it. I got them all to work but needed to buy a few parts. Someone else in the store saw that and then offered them even less for all of their 8R stoves, and they took that. I should have made my offer for the Sveas and 8Rs.
I last used one of my Sveas for backpacking in Grand Canyon in 2014. Still works.
Likes For Tourist in MSN:
#205
I can attest to the fact that a well worn 1965 chevy van will in an emergency start and run very poorly on coleman fuel. It will knock and ping and rattle for at least a week after it is filled with real gasoline. Also it will throw a rod tight through the side of the block within a year if my experience is typical. Yes I know that from first hand experience.
#206
Liked 4,537 Times
People often say that “white gas” is “pure gas” but, as you found out, it isn’t. It’s not even that closely related to gasoline. Given the high proportion of straight hydrocarbon, “white gas” would make an okay diesel substitute because it has a cetane number of about 60 which is the same as diesel fuel. But diesel engines are far more robust and less sensitive to fuels than gasoline engines.
Stuart Black
Stuart Black
#207
My bike-boom era published-in-1972 Second Bicycle Two Wheel Travel Camping and Touring book recommends (remember, this is in 1972!) the 111B for group tours of four to six riders. For groups of two to three, they suggest the similar but much smaller and lighter Optimus 8R. For one or two, they recommend the Svea 123 with provisos on its sometimes cantankerous start-up: "This is the stove that drives men to butane."
#208
Liked 1,589 Times
I preferred the older version that did not have the built in jet cleaning needle, it primed faster. But I recall camping with someone that had a clogged jet, I asked her where her jet cleaning needle was, she said that there was some silver thing that she did not know what it did to she chucked it. Needless to say her stove did not work very well.
I camped a lot with a friend that had an 8R, we liked that over the Svea and he had the external pump for it too.
That said, the Svea with a Sigg Tourist cookset was better than the 8R.
#209
I agree that the key on the chain is a pain. I considered pitching the chain, but I just live with it
I use a craft foil screen if there is much breeze in addition to the one that the stove comes with, but take care to not allow it to overheat the stove. I used to just improvise some kind of wind break, but found the craft foil was worth a tiny bit of extra weight and bulk.
#210
Liked 1,589 Times
This thread started over four years ago. I was not sure if I should start a new thread or add to some of the discussion from last month. Decided not to start a new one, as this might not be of interest to very many people.
Quoting from two posts above, first by TCS, second by me:
At the time that I saw those on the shelf, the first thing I thought of was that I should be prepared to use those in a pinch if I had to.
I researched those a bit more when I got home from that tour where I saw them in summer 2019. There are fittings you can use to transfer fuel from one of those skinny canisters to the short threaded canisters most of use use, and I bought some of those fittings, but my experience with those was that I had to be really careful or I would lose more gas in the transfer than I would like.
I would hate to be on a bike tour and be out of butane, then see one of those tall skinny canisters for sale and not be able to use it. The posting by TCS reminded me of that.
So I did another search for options. And I bought an adapter that will take a threaded type butane stove like many of us use onto a tall skinny cannister. This is what I bought. Shipping from Asia took over a month.
https://www.ebay.com/itm/353231854406
Ebay links disappear before these forum posts do, so I pasted the Ebay ad title here in case in a couple years someone wants to search Ebay to buy one:
Outdoor Camping Hiking Tripod Gas Stove Adapter Long Gas Tank Conversion Head
It looks like this.
On my scale it weights 97 grams.
Photo below is that adapter attached to a fuel tank and one of my stoves, an old Primus, I do not recall the model name. Works pretty good. Disregard the snow in the photo, it is February and I wanted to try it, the tank was warm and the stove worked fine for the half minute I tried it outside for the photo, but it was too light outside to see the flame.
There were no instructions with it, but it was easy to figure out. There are two tabs on the round mounting plate on the adapter. And the fuel canister has a disc on top with a cut out on part of the disc. You hold the canister approximately horizontal so that the cutout in the disc is up on top, you put the lower part of that disc behind the lower tab on the mounting plate, press the canister onto the adapter so that the cutout in the canister disc goes behind the upper mounting plate tab, you then twist the canister clockwise to lock it on.
Note that these tall skinny cannisters are butane, not a mix with iso-butane or propane. Thus, these tall skinny cannisters would be expected to perform poorly in cool weather. I assume that a wet towel or rag that is soaked in warm water and wrapped around the canister might be enough to warm up the fuel in the canister? I have not tried that but I know from experience that when it is cool, the butane/iso-butane/propane mix canisters work much better if they sit in a warm (not hot) water bath.
I plan to carry this adapter on future tours where I am using butane type stoves as a contingency in case I can only find the tall skinny butane cannisters in stores or for sale at campgrounds. I still plan to primarily use the short squat cannisters that most of us use, but this gives me a contingency plan if I can't find what I want.
Note that a few stoves will not work on this adapter, ones like the MSR Superfly that grip onto the big ring on top of the squat canisters will not work on this adapter. But most other stoves that thread onto the cannister should work fine without any difficulty.
... I've seen butane packaged in aerosol cylinders with twist-click connections
In the USA these are used in car camping (NTTAWWT!) stoves
although in Japan and other locales they make nifty hiking/cycletouring stoves that use the twist click cylinders
My local Walmart, Acadamy and REI have a shelf full of these aerosol butane canisters, but I haven't seen them anywhere in the hinterland.
There are Lindal-to-Aerosol and Aerosol-to-Lindal adapters available.
I was really surprised to see those tall skinny butane cannisters for sale in some of the RV campgrounds that I stayed in on my last bike tour. ....
It really surprised me that the tall skinny cannisters were for sale ... but the short threaded ones that our campstoves are designed for were not available for sale at those campgrounds.
It looks like this.
#211
Those tall butane canisters are very widely available, just from a different set of sources. They are pretty cheap and if you are willing to buy a case from a wholesale kitchen supply store you can probably find then for under $2 a piece for 8 ounce ones. Single ones can be found for $3 pretty widely. If I were to stick with gas stoves I might consider switching to these at least for some trips in warmish weather. It is about twice as much fuel as I'd usually carry when solo and using iso-butane
There are also adaptors for stoves with remote iso-butane tanks.
#212
Liked 1,589 Times
#213
Palmer
Liked 1,978 Times
Some of the adapters just mentioned were pictured back in post no. 188.
Likes For tcs:
