Just started training with Power? Post your questions/comments here!
#2526
going roundy round
It's lookin' to be a little moist up in here tomorrow. I've got 80 miles planned. Do I need to do anything if I run my PT through a bunch of rain or are they somewhat moderately waterproof?
mattm - I hear you all have rain over your way some.
#2527
Throw the stick!!!!
What software is everyone using to view their data? I have Cycling Peaks WKO+ on my old computer but I don't believe I can transfer it to my current laptop.
Here is the garmin information from my first ride with the new powertap. This should make everyone here feel really good about their numbers.
https://connect.garmin.com/activity/44357738
I may be fat but I'm slow enough to make up for it.
#2528
Throw the stick!!!!
I ran my old one in severe storms and snow, never had any issues.
#2529
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
tough climb? that 55 cadence looked painful
#2531
Throw the stick!!!!
The climb is one of the easier ones around here, I'm just really, really, really out of shape.
#2532
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Code:
Entire workout (132 watts): Duration: 1:47:27 Work: 854 kJ TSS: 44.3 (intensity factor 0.498) Norm Power: 140 VI: 1.05 Pw:HR: -5.84% Distance: 32.064 mi Elevation Gain: 902 ft Elevation Loss: 872 ft Grade: 0.0 % (30 ft) Min Max Avg Power: 0 332 132 watts Heart Rate: 83 143 115 bpm Cadence: 19 115 86 rpm Speed: 1.3 38.2 17.9 mph Altitude: -60 102 19 ft Crank Torque: 0 395 133 lb-in
#2533
Since we were talking about this recently, Negative decoupling for my entire ride today.
Code:
#2536
I know that someone on here works on GC. Just a recommendation, it would be cool if it calculated decoupling for each interval. That would be really useful for longer (10', 20', 30') intervals, IMO.
My ride today ended up with negative decoupling as well, but it was not a recovery ride.
Code:
Code:
Metrics* xPower (watts): 170 Relative Intensity: 0.804 BikeScore™: 143 Daniels Points: 93 Daniels EqP (watts): 171 Aerobic Decoupling (%): -2.79
#2537
Just to see if im having issues getting my HR up or issues with it comming down between efforts...
Lets tell you one thing, power says another, HR tells you if one is lying
![Smilie](images/smilies/smile.gif)
#2538
Throw the stick!!!!
As aside note, the program isn't nearly as nice as Cycling Peaks WKO but it's free so I can't complain.
![Big Grin](images/smilies/biggrin.gif)
#2540
Throw the stick!!!!
Thanks, so just get it straight off of the unit I guess. That works for me.
#2541
Bikes: Cannondale 2.8 R700 circa 1997; 2009 Cervelo S2; Trek 930 mountain bike; various others
Whenever I wear my HR strap with my PM it only picks up randomly. It'll go 10 minutes without reading, and then read it for a minute, and then cut out again for a bit. So I never actually get real readings, hence I don't wear it anymore. Is there something that I'm doing wrong to cause this? Do you have to calibrate the strap to the computer somehow? I never really put much thought in to it, but I've considered wearing it lately so I guess I should figure it out. I have a wired PT and the standard cycleops computer as well.
#2545
My idea of fun
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Liked 59 Times
OK.. the GC 705 import error bug is really starting to aggravate me. I'm sitting here with a tcx for a 5:15 ride from today and it insists it was 6:05, so a lot of the metrics are screwed up. This is not the only one, but it's the most recent.
The bug is basically that GC tries to be "smart" and "fill in" blank data because it's just assuming the tcx file is wrong.
Does anyone know an easy way to cut out sections of the ride?
This is to the point where I'm thinking of the parallels / wko route...
#2546
#2547
Easy is relative... I use First Object XML Editor to edit out sections of TCX files.
#2548
Are you using a version of GC with an editor tab? I haven't used it but it looks like you can easily delete portions of the ride. You would still be left with time gaps but the ride time should be correct.
#2549
My idea of fun
Liked 59 Times
this behavior only started with 1.2...
