Totally Tubular
#2676
If I own it, I ride it
Quoted: 594 Post(s)
Liked 666 Times
I have been using Miyata rim tape for nearly a decade. Search those words and you will get plenty of results. There is a 20M roll that is the best buy, but there are shorter lengths available if you want to make sure you like it.
Likes For CV-6:
#2677
Quoted: 2588 Post(s)
Liked 4,827 Times
Wow - those sound right up my alley
DD
DD
Likes For Drillium Dude:
#2678
Liked 4,827 Times
DD
#2679
Quoted: 253 Post(s)
Liked 223 Times
Not really familiar with tubuluars, but thought I'd ask: Isn't tire pressure of 100+ psi suuuper rough to ride on? Like, you feel every buzz and bump? Sounds like the opposite of comfort.
#2680
Liked 4,827 Times
Anyway, some of us like lots of feedback from the road, as long as it isn't too harsh. 145psi and up (on decent wheels mated to an equally decent frame) with high-quality tires isn't harsh, but definitely transmits the feel of the road - which is what I want my tires to do.
Lots of moving parts in the equation, it's hard to be more specific. Body and bike work as one, but only if they interact well, correct? Higher pressures also mean lower rolling resistance, to toss out yet another variable.
DD
Last edited by Drillium Dude; 03-06-23 at 02:07 PM. Reason: Added some clary-ficashon...
#2681
Quoted: 253 Post(s)
Liked 223 Times
Yea, i guess that makes sense.
Does this still hold true? I've read that lower pressure actually rolls faster. I think Rene Herse/Compass did some testing on that - not tubulars afair though.
#2682
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1303 Post(s)
Liked 958 Times
Thanks. I double-checked and it says "tubular (vs clincher) pressure 90-180psi". These are modern tires, I think they only stopped making them within the last five or ten years.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
#2683
Standard Member
Liked 958 Times
Is the 18mm Jantex tape suitable for 25mm width tires? (The listing says up to 23mm, but another listing for the 18mm says up to 25mm tires.)
There is a new-but-dirty pair of the 25's for sale right now on my favorite online auction house site. Bontrager R4 hard case lite Tubular. They only go to 180psi.
"Anyway, some of us like lots of feedback from the road, as long as it isn't too harsh."
Exactly. This is the #1 characteristic that I look for in a ride. For me, this means hard tires, compliant frame.
#2685
Freewheel Medic
Quoted: 1473 Post(s)
Liked 2,247 Times
I've used Tufo tape in the past with good results, but for the past couple of years I've been using effetto Mariposa Carogna Tubular Tape. It also comes in shop sized rolls for better economy. When I've needed to remove a tire for replacement or repair, I've not had any issues.
I also use their glue or mastic remover, when cleaning old, glue laden rims, back to their original condition.
Bob
Bob
Likes For pastorbobnlnh:
#2686
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3308 Post(s)
Liked 1,916 Times
Glue. An uncommon brand I found on Amazon. I can't remember the name of it at the moment. I wanted to try the traditional way too. But now that it's pretty much unobtanium, in these parts, I'll be happy to switch to tape.
Likes For seedsbelize2:
#2687
Standard Member
Liked 958 Times
Thank you to all who helped me through this mind-warp. I peeled the tire off, re-installed and it worked perfectly. I just needed the right advice/perspectives and some experience. I think what I learnt is; go slowly and carefully on installation, use your hands, not spoons and allow some drying time before installing the tire. Also, the tire benefited from having a second stretching after the installation with glue, because I was able to put it on with my fingers, just like as-recommended.
In one youtube video, the guy does a second stretching, after the second coat has dried, but he said the reason is to let the cotton bed (I forget the correct word) open up to absorb the final coat of glue at installation.
I might re-install the front tire, now, since the conditions have changed for the better. (I tried to upload a video, but AVI files need to be converted, apparently). Anyway, it was all good. Thanks again.
Likes For 1989Pre:
#2688
Liked 4,827 Times
Think about it: you may recall the old Shell 'driving tips' pamphlets (they may have done TV spots, too) from the 80s; if not, these were PSA pamphlets ranging in topics from when to change your oil, to the proper time/manner to rotate your tires. One tidbit which has always stuck: keep your tires inflated to the correct pressure; too low causes lower gas mileage due to increased rolling resistance, while too high can cause the center of the tread to overheat, resulting in premature tire wear.
You can test this yourself. Ride the bike at your normal operating pressure. Then, let out 10psi. Does it feel as though you need to make a bit more effort to ride as fast as you did when running at normal pressure?
DD
#2689
Liked 4,827 Times
You asked about whether 18mm tape would work with 25mm tubulars, and I must admit: I don't know. Jantex might well have some information regarding size compatibility, so I'd check around on the Interwebz, see what you can find from the manufacturer.
As with most anything, advice is best given after we've either gained knowledge or experience. Since I've not taped anything larger than 23s with Jantex 18mm tape, I can't in good conscience advise further.
Enjoy the ride - I bet those Bontragers will feel great!
DD
#2690
Bikes: Eddy Merckx EX & Bob Jackson R:753 tubing
Quoted: 15 Post(s)
Liked 44 Times
Great discussion! FWIW: I use Tufo tape....love it. Glue was the only way in the 70's. Mom hated it....stunk up the apartment. So the tape width is determined by the inner dimension of the rim shy of the braking surface. I ride Conti.Gators. 25mm. My rim Id. is 19mm soTufo 18-22mm tape....works great. Lots of hills and miles...all good.
#2691
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 308 Post(s)
Liked 723 Times
I've used Tufo tape too - on 2 sets of tubulars so far.
Just checked and I got Tufo 19mm x 2m tape: "Rim Width Compatibility: 19-22mm".
That's from Wiggle.co.uk
I've used it on 28mm tyres and it's working fine.
Actual rims are outer width 22mm (Mavic Monthlery Route)
Likes For Aardwolf:
#2692
Quoted: 253 Post(s)
Liked 223 Times
DD
If you puncture on the road, what do you do? tape?
Likes For Positron400:
#2693
Standard Member
Liked 958 Times
I need some info on this, too. I bought a bottle of Stan's Sealant and valve-core remover, and they say that will seal up a puncture, but I have never done this before.
#2694
Quoted: 253 Post(s)
Liked 223 Times
this i might be able to add my 2 cents to. You basically wanna remove the valve core and add some amount of Stan's sealant (dunno how much, but i recon 40 mL would suffice), put in the valve core again and pump the tyre up. If you you were to get a puncture on the road, the sealant would clog up the hole w/o you even noticing. So it effectively reduced the chance of your puncturing at all (to a degree, since massive sidewall slahses wont usually seal)
#2695
Standard Member
Liked 958 Times
#2696
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 353 Post(s)
Liked 186 Times
Eventually, I will attempt to patch almost any tire before I pitch it for the sake of practice if nothing else.
#2697
Quoted: 253 Post(s)
Liked 223 Times
Regarding the valve core, that is up to you really. If you remove the valve core, all the air will be let out anyways. So you can either deflate it beforehand, or just remove the valve core right away.
I think the amount of sealant is also dependent on the size of the tire. Stan's might have a reccomendation, but imma say go with 40 mL (since i presume you run a 25 mm tire at most)
#2698
Wheelman
Quoted: 308 Post(s)
Liked 723 Times
I'm using Orange Seal.
Got a 1mm puncture on my new Vittoria Rubinos last year after 93 miles.
Did some research and installed Orange Seal, now another 1100 miles with no punctures (that I noticed).
Likes For Aardwolf:
#2699
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4381 Post(s)
Liked 3,046 Times
1. Pre-emptory sealant... the way tubeless tire riders do it. Statistically works pretty well but you never know if you would've flatted or not without it unless you pull out a goat head or something and watch it work... so most people pack a spare tire anyway. With smaller road tires though, you might lose enough air before the plug happens that you have to press the tire up again even if the sealant does work.
2. Repair sealant... keep a bottle in your pocket and after you flat on the road, inject the sealant and hope it works. It reportedly does work often enough that people find it worth trying... not well enough that people don't pack a spare tire also. Before sealants got as good as they are now, people would sometimes bring something like Vittoria Pitt Stop that had sealant and pressurized air in the same can... I estimate that has about a 50% chance of working.
3. Both
Summary: if you have a flat on the road and you're not in a hurry and you want to avoid swapping on your spare and throwing away the flatted one... worth a shot to try and seal it in place.
You need a spare anyway because some flats are absolutely unsealable, and success with the easier punctures isn't guaranteed.
Likes For DiabloScott:
#2700
Quoted: 1976 Post(s)
Liked 2,093 Times
I don't normally use sealant. I prefer to use the spare and patch the punctured tire when I get home. Sealant can dry into a clump inside the tube if you don't ride that tire regularly and you need to remember t store the bike/wheel with the valve near 12 o'clock so you don't clog it up. In the event that the sealant won't seal a puncture, you need to patch it anyway and the sealant makes a mess that I'd rather avoid.
I will use sealant in tires used for a timed $$$ event for a better chance I won't have to stop for tire changes.
(btw, this is all in earlier posts.)
Likes For Classtime:
