Origami Swift - Thoughts, Ideas For a New Version of a Classic
#251
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 463 Post(s)
Liked 413 Times
I'm wondering if the wheels were black for all trims, they would work well and look consistent. Plus make production easier across all the trims.
For the all black, if the Origami logo and minor highlights were in a red, that might pop. Possible alternative with the rear arms in a matching red. Two tone. That could convey the speed of this machine.
Or you could go stealth with gloss dark grey lettering over the matte black.
I like the simplicity of colors. It gives owners the chance to customize. I'm wondering if it would be possible to replace the front stem with a folding stem from Dahon or Tern on our own to reduce the fold but am guessing it would affect the feel of the ride.
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Likes For Pinigis:
#253
Quoted: 463 Post(s)
Liked 413 Times
Pinigis the bike looks great, good job with it all!
What is the projected pricing for the bike?
Will there be a frame only option?
What is the likely pricing for frame only if there will be?
We will do a frame-only option as well, but pricing isn't determined yet.
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
#254
Any plans to produce the clamp on front derailleur hanger? Is the down tube the same size as the Xootr version because some existing owners might be interested in buying those as well.
#255
Quoted: 463 Post(s)
Liked 413 Times
The tube is not the same diameter as the original Swift because we have employed a larger seat post. We will braze on a front hanger.
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
#256
Been missing this thread. Just wanted to add that it's looking very, very nice.
Personally, I like more understated paint job...but I'm an old fart
#257
Quoted: 463 Post(s)
Liked 413 Times
We will offer the Swift in black, white, green, and maybe silver. So we will have some old-fart color choices.
Paul Pinigis
Paul Pinigis
#259
Quoted: 381 Post(s)
Liked 145 Times
From the Instagram page 1 week ago, "We are beginning a production run now and should have the bikes available in early May. We are going to offer some pre-production pricing in March."
#260
The seatpost diameter looks much more narrow than the original Swift, does this translate into more seatpost flex and ride comfort? My only real complaint about the original was how stiff everything felt, with some of the bigger bumps feeling like I was punched in the undercarriage. This was with schwalbe marathons.
#261
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
A few pages ago when we asked about it, it was still 33.9mm
Genesis 49:16-17
Genesis 49:16-17
#262
Also, I suspect that the seatpost diameter is extra wide to give more surface area for the two quick releases to hold onto. I think that the stiffness of the bike is one of its best attributes. This new Origami version is going to be made of steel rather than aluminium, so it might feel a bit more comfortable and compliant to you. Wider tyres could help further dampen the bumps on the ride. It's possible Xootr might still have some Thidbister seatposts in stock. None of this is my preference though. I find that my aluminium Xootr is just about right for the bike rides I love to do. It's light, fun to ride and comfortable in the saddle over long distances. But then I ride perched on my saddle over the bars like a roadie.
#264
Quoted: 463 Post(s)
Liked 413 Times
33.9, mm is a very large diameter seat post for better rigidity. There is a quick release that allows you to either rotate the handlebar 90 degrees to minimize the folded width, or pop the whole thing off and nest it over the frame.
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
#265
Quoted: 463 Post(s)
Liked 413 Times
We did modify the design of the rear rack so that the bike will stand upright when in its folded position. Of course you can leave the seat post in and pop off the handlebar for a more compact package.
The new rack allows the Origami Swift to stand in its folded positon.
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
#266
Quoted: 381 Post(s)
Liked 145 Times
More specs from the instagram page,
20" folding frame of chromoly steel
20" chromoly fork
580 mm aluminum handlebar
33.9 x 580 mm seat post
Sealed bearing headset for easier packing for travel
Sensah RX10 10-speed derailleur and gear selector
Kamros hydraulic disc brakes
double-wall aluminum rims
Alloy rack for panniers and as a stand when folded
58T aluminum chainring
11-42T 10-speed cassette (26 to 99 gear-inch range)
Also, from the instagram page, "Pre-order now for a special discounted price.. email or DM us!! "
20" chromoly fork
Likes For BikeLite:
#267
Quoted: 463 Post(s)
Liked 413 Times
I just looked at the old Swift spec and it shows the seat post at 34mm, our new version is the more-standard 33.9mm. Not much of a difference.
Paul Pinigis
Paul Pinigis
#268
Disco Infiltrator
Liked 2,116 Times
What do you want to bet...
Anyhow, I think that guy was hoping for smaller. Maybe he can get a thudbuster or a redshift. Or not use Marathons, which IME are like rocks
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
#269
Quoted: 381 Post(s)
Liked 145 Times
The original xootr swift had full length cable housing for the rim brake and shifter. This new one has the partial housing for the shifter (no housing under the top tube and seat stay). Does anyone consider that a negative or step back?
#270
I am potato.
Quoted: 1826 Post(s)
Liked 1,704 Times
On a general level: Galvanized cables exposed to the elements are gonna look corrosion grey & swell up sooner. So, there is that. But after years of service life cables should be replaced anyway.
It's a non-issue.
Car dependency is a tax.
#271
Quoted: 463 Post(s)
Liked 413 Times
We finally have production underway and will be delivering bikes in May (barring any unforeseen Covid issues). I decided to do just two colors for this initial run: the green you see above, and a medium grey metallic for the old farts. Both will have black rims in lieu of the color-matched option since that didn't seem to go over very well with the members of the forum. We did add bottle mounts to the top tube as well as on the handlebar mast (thanks to the forum for this suggestion). Thanks also to the forum for the reminder about taller riders; we will have a taller handlebar mount and longer stem for folks over 6'0". As of last night the bike is available on our site at a preorder discount (this will end either when we have enough orders or we get close to May).
Thank you all for your input, suggestions, scrutiny, and honesty. Just because we may not have employed one of your suggestions doesn't mean that we have dismissed it either. This is just the beginning, we have the option to make make just about any variation you can think of as we proceed.
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
#272
Schwinnasaur
#273
Quoted: 463 Post(s)
Liked 413 Times
With the wider tires, larger gear set and chainring, rear rack, and folding pedals we are at 28 lbs. The weight-weenies out there are welcome to remove the rack, use skinny tires, etc. but there is a definitely a trade off in terms of performance and convenience.
Paul Pinigis
Paul Pinigis
Likes For Pinigis:
#274
Quoted: 534 Post(s)
Liked 646 Times
I wonder why you didn't go for the FSIR (Litepro Leo) design instead. Similar double-clamp 33.9mm seat-post design, but with a quicker, if not smaller fold. The FSIR's have been out for several years now and the design has stood the test of time.
#275
55+ Club,...
Bikes: 9+,...
Quoted: 1146 Post(s)
Liked 889 Times
Because people wanted the Swift resurrected, that's why. The ride quality is the most like a full size bike of any folder I've ever been on. With 20" wheels of course. There's Swift fans all over the world.
