Post Your Titaniums
#2751
Liked 398 Times
Alter stem. I'm planning on swapping the bar for something with a traditional bend in the near future. And it's actually a Tiagra groupset, but close enough to fool em from far away.
#2753
Bikes: 2012 Moots VaMoots-74 Peugeot Mixtie U018-73 Peugeot U018
Liked 9 Times
Moots Vamoots Grail Bike
Over the years, I've had several titanium bike (buy and sell), but the Moots is my current favorite! I weighed the Moots 16.2 lbs, and it weighs nearly the same as my Colnago C40 16.1 lbs, with nearly the same equipment!
Moots VaMoots 2012-Peugeot Mixte 1974-Peugeot Mixte 1973
Likes For gioscinelli:
#2755
Gave her a bit of a makeover.
New headset, got rid of the pink and blue bits.
Built her some new wheels (Bicycle Hub store hubs laved to Pacenti Forza rims, 28h rear, 24 spoke front with CX Sprint spokes).
Aerozine skewers, and top spacer.
Ceramic hub bearings, front and rear.
Considering changing out the bars to a traditional shape, but not sure.
#2756
Administrator
Liked 6,856 Times
#2757
This is my Guru Praemio R... I have posted this here before, but have recently made some upgrades.
Swapped out the Fizik saddle for a Brooks Team Pro in honey and matching honey Brooks Microfiber bar tape, and finishing the Brooks theme off their Isle of Wight saddle bag. Ditched the compact bars and put in some more traditional drops. Comes with Ultegra Di2
Still breaking the saddle in and have 3.5 weeks to get it comfy for the NZ Lake Taupo 160km cycle challenge.
#2759
Weight wise, I keep meaning to put it on the scales. ill do that over the next couple of days, but... a lot heavier since the saddle went on. They're not that light!
#2760
I actually bought it second hand new/unused. It's 62cm frame and i'm 6'... I like a more Eddie/French fit and have always liked a large frame. I also prefer to do more distance cycling and am not looking to break any speed records. So is all good for me.
Well done. The bike looks so nice with short stack and proper stem. I have owned tons of Brooks saddles throughout my earlier cycling life and ride plastic now but Brooks saddles do weigh a lot. That bike isn't about weight as you rightly imply. Beautiful.
Enjoy it. Had to ask about the unique geometry.
#2761
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Liked 55 Times
the Moots looks great, but hey, it sure looks like you have the rear derailure cable routed to the left side of your handlebar and the left side brake shifter or am I confused?
#2763
Liked 9 Times
Hello, I noticed the crossing of the shifter cables routing, and will correct the discrepancy. The shifting is as usual for Campagnolo components excellent, and did notice a slight hesitation between shifting. Thank you, Mike
#2764
Ride more, eat less
Liked 773 Times
There is no need to correct, cross shifter cables at the downtube is a common trick the bikeshop mechanics use, it allows less curvature in the shifter cable housings from handlebar to downtube, cleaner installation, and less frame rub.
Unless the shifter cables are not properly adjusted, shifters or derailleur are worn, shifting performance shouldn't be any different than non-crossed shifter cables.
#2765
#2766
Liked 9 Times
#2767
Ride more, eat less
Liked 773 Times
If anything, the front brake cable housing looks a little long than necessary, the rest seem to be fine.
The Ergolevers do not look like they are at even height on the handlebar.
#2769
#2770
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Liked 182 Times
My dream of a custom Ti bike is getting close and closer (being jobless for 5 months kinda used up too much $$). All good now. Very hard to decide on one though. There are simply too many awesome ones now. Moots and Mosaic may end up at the top of the list since they are in Colorado. Great bikes posted here!
#2773
Liked 527 Times
Just took delivery of my Litespeed T2 two days ago. This is my first Ti bike. I have already put 80 miles on it and all I can say is wow! I did not know what I was missing!
#2775
Who is Austin Dunbar?
My Lynskey Sportive in final form. Ksyrium SLS wheelset, Shimano R8000 Ultegra components except for DuraAce R9100 bar end shifters and SRAM brake levers.
