Addiction LXXIX
#2951
Should Be More Popular
Liked 9,204 Times
I know. After all the Saturn dealers closed I got to work on a ton of them. Was never really a fan of the old buzz-bomb 1.9. Simple, but meh. Then there was a butt-load of the hybrid Vue things to deal with. First, the leaking hybrid batteries, then the recall of the batteries leaking or not. I accidentally shorted something and fried the 200 amp fuse in the rear cargo area of one and balls of red hot molten metal rained down, burning holes in the carpet. Luckily the car was hammered so the carpet didn't matter.
That might have been my biggest screw-up with an electric or hybrid car. I did once take the battery out of a Volt without disabling it but didn't get shocked.
All the later model Saturns were just re-badged Chevrolets, so familiar turf.
I just remembered they had that awful V-6, a Vauxall, I think. Oh, and the Astra. How could I ever forget the Astra. The only thing marketed by GM that had it's own language. You couldn't plug a Tech 2 into it and read data until you erased the Tech 2 and reloaded it with Astra specific programs. Ridiculous. Later lap-top apps had a program you could use with an interface device to talk to the Astra but it always needed to be updated when one of the cars came in, even to just read a code. Generic code readers would work, though.
Likes For datlas:
#2952
Liked 9,448 Times
I had my S-10 Blazer for 18 years and sold it running well with close to 300K on it. I neglected it in a big way for years but it refused to quit. It had the notoriously wimpy 2.8 V6. Never had the heads off or the pan.
I have 190K on my Trailblazer, runs nice. Hasn't been neglected yet, give me time.
#2953
So it is
Liked 4,922 Times
When I decided to throw comfort out the window, and concentrate on aero, my power sucked, but I moved. Had I done that sooner in my life, and been more firm with my coach, I/we would be money right now. He is an advocate of power over everything, but I finally talked him into getting lower, just to see and prove it, because that's where I was going. He did it, dropped a good 10% power, which matched my readings yet realized he was going faster from day one. We both did it too late for the 40k, but the results were encouraging, to say the least. I'll be spending my off season getting stronger on that. I know a tri set up needs to be much more forgiving, but there are few people that can match road bike power on a TT bike. Rohan Dennis is one of them, but he's a freak.I say that in a very good way.
#2954
So it is
Liked 4,922 Times
Like I said, simple, but meh. So many of them have that awful vibration. Maybe new motor mounts could help, I never got that far with one.
#2955
So it is
Liked 4,922 Times
Nothing says quality like the Catera and Saturn LC Series with that Opel (snot) V-6. Hurl-worthy.
#2956
Liked 9,448 Times
I'll remember that if I ever go back to work, though.
#2957
Liked 9,448 Times
Likes For big john:
#2958
Bikes: Shmikes
Liked 5,971 Times
#2959
So it is
Liked 4,922 Times
You may have restless leg syndrome, which is very common and can be exercise related. It can be treated quite effectively by a knowledgeable physician, i.e., a neurologist with competence in movement disorders. However, there are plenty of docs just throwing sleeping pills at it, which is to be avoided at all costs. If you want to see someone, VCU is probably your best local resource.
#2960
Liked 9,448 Times
I just got the "you look good for your age" diagnosis.
#2961
Liked 5,306 Times
#2962
Bikes: Shmikes
Liked 5,971 Times
I am getting a gradually lower, but I need to work on flattening the lumbar spine when I'm in the drops. I keep my shoulders down and my elbows bent I hunch up and get achy if I'm not constantly working on it.
#2963
Bikes: Shmikes
Liked 5,971 Times
The genetics and the mechanism are just beginning to be worked out, but there are some pretty specific treatments available. Any good movement disorder doc should be able to handle it. It's also closely associated with something called "periodic movements of sleep," which can be quite disruptive too. Anyone who's really annoyed by it or has it bad enough to cause daytime sleepiness should get it seen.
#2964
Silver Comet Fred
#2965
So it is
Liked 4,922 Times
Very common throughout the population. I take anything that disrupts sleep pretty seriously.
#2966
So it is
Liked 4,922 Times
I don't think I would like a TT bike very much and hills must be simply agonizing. Fortunately, I don't have space for one.
#2967
Bikes: Shmikes
Liked 5,971 Times
Thank you. The MIL has been dealing with it for a long time, and back then, like you said, it was more of a muscle relaxer, sleeping pill, and other pill cure, which were largely ineffective. Since Mrs. LAJ is now starting to show signs, I'll have to tell them to rattle some cages.
#2968
So it is
Liked 4,922 Times
My MIL had it and was prescribed clonazepam, a long-acting sedative, which practically put her in a coma a few times. Pills tend to be what's on offer, but anyone with a bad or difficult-to-treat case should be worked up for a disorder of iron metabolism, which can be very subtle and hard to trace. That is, the usual iron tests can be normal.
#2969
serious cyclist
Bikes: S1, R2, P2
Liked 3,685 Times
#2970
smelling the roses
Liked 901 Times
Waiting for the No Mas Clavos to set up. I used it to replace the tiles loosened by the sink violence. Then I will glue the sink in with silicone and have at the plumbing. Looking forward to the end of this project. It will be a great improvement in kitchen experience.
#2971
Administrator
Liked 6,873 Times
You got hit on? Sweet!
#2972
Administrator
Liked 6,873 Times
#2973
Klaatu..Verata..Necktie?
Liked 12,412 Times
After college I bought a 14 year old MGB, which turned out to be due for its patching and reinforcing. Then I moved to Ithaca, in central New York, where cars last 10 years, but there's not a "no rust-through" rule. Cars there last maybe 10-12 years. I saw 10 year old cars whose front fenders consisted of the inner fender liner and the headlight and side marker light areas, with the rest rusted away - that was a Chevy Vega. In Ithaca, mechanics were AMAZED at the wonderful state of my rusty MGB, because it was actually still on the road.
Two years later, I moved to California. Cars here last till they crap out mechanically and become unfixable, or they get totalled. Suddenly, my 'amazingly well preserved' MGB became 'a rusted out piece of s***', and when the brakes started failing, I could not get a mechanic to fix them - "Not without a tetanus shot!" said one. That was the end of my MGB. Traded it for a bottom-of-the-line Toyota.
Likes For genejockey:
#2974
So it is
Liked 4,922 Times
Upsides/Downsides With rust, it's been about 20 years minimum that anyone has had to work on a carburetor and the car it came on. Old feedback Quadrajets are crap, and there are still many of those heaps on the road here.
#2975
Liked 12,412 Times
EDIT: I think this was about the very end of carburetors generally, when they'd added so many different adjustments that it had to be tweaked within an inch of its life just to run. This is why EFI took over. Yeah, a Holley 4bbl carb (or two) sitting on a big 7L V8 looks nice and gives me a nice warm feeling, but they were dinosaurs.
