Your favorite road tubeless tires
#276
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
Certainly faster on rough roads plus on descents. The safety margin is higher. I can tell while on those fast and twisty corners I usually do near my house. I am not on the ragged edge anymore. For me it isn't about being faster on the downhills in general...it is about being safer and enjoying the corners. The improved traction and the ability to brake quickly and effectively (ever seen a deer pop out when carving at 35/40 MPH?) even though I generally am trying to go slower in these sections. The comfort is really really nice. With a larger contact patch, a bigger safety margin, and a little more compliance, it just makes cycling more enjoyable for me.
#277
Quoted: 4646 Post(s)
Liked 5,180 Times
Likes For PeteHski:
#278
Quoted: 464 Post(s)
Liked 182 Times
I have Pirelli Cinturato 32s waiting for the winter. I took the Maxxis ReFuse 32s off and put on the Specialized S-Works T2/T5 whatever 30s on. They now measure 32.1...great tires though with the minimum PSI (I prob mentioned this earlier) of 65 is a bit much. So, I bought a few ENVE SES 31s (they measure 34s eventually on 25mm rims) so I can run 50-55 in front. I'll run 55ish in the back tire and I air the rear up a bit when on long climb days, so 60. You could no longer convince me to run even 28s. I do have 28s on another bike and will put the Specialized tires on it since it has hooked rims and with the Future Shock, I don't mind running 65.
#279
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
I have found it all depends on the rim. My fingers and thumb ached for two days just trying to get them on the rim. Seating them was another issue. I enjoyed them when I had the LBS mount and seat them, but for me as a DIYer (with a compressor) it was a no go. Glad they work for you since they are awesome
Likes For eduskator:
#280
Any suggestions for a 28 to run on sandy roads? Picked up my first set of carbon wheels (Reynolds AeroDV 46), and they have a 19mm internal width (hooked). I do a lot of riding on Pacific Coast Highway in Califorbia, so there's always a ton of sand blowing across the road.
#281
Quoted: 810 Post(s)
Liked 1,888 Times
#282
Quoted: 464 Post(s)
Liked 182 Times
Look at the Maxxis ReFuse or some similar tire that has some tread. I have used the Maxxis and they appear to be tough and are grippy. They are a bit heavier but roll well.
#283
Quoted: 1290 Post(s)
Liked 1,420 Times
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
#285
GP5000s
#286
I’ve put almost 1,500 miles on them and I’ve not had a single puncture that didn’t seal almost instantly (I only knew it had happened because of the little bit of white goo on the frame).
They’re wearing good, too. The front tire still has a little of the “molding flash” still on it!
#287
Quoted: 810 Post(s)
Liked 1,888 Times
My 2022 Domane SL5 came with those and I’ve got no complaints.
That is an older post. Have not been on the Bontrager's for a while, moved over to a Pirelli but, the Bontrager's still not a bad tire.
#288
Quoted: 800 Post(s)
Liked 512 Times
So after just over 7,000km this happened to my rear Michelin Power Road TLR tyre. I guess I cannot complain too much since, like I said, I was just over 7,000km. Still I am burned a little bit b/c the tyre wear indicators still showed some life to go.
Overall still very pleased with the Michelin tyres. I have another set waiting to be put on the bike once I use the Veloflex tyres I bought..
#289
I bought early model Michelin tubeless and had similar cracking at the tread/sidewall junction. I've got my last four in use on two bikes. If I see cracks, they're going in the trash. Pirelli P-Zero have been better, but they usually cost a lot more.
Likes For DaveSSS:
#290
Liked 5,180 Times
#291
Quoted: 800 Post(s)
Liked 512 Times
I have one more pair of Michelin tyres waiting to be mounted and I have a set of Michelin tyres on my second bike. To your point DaveSSS if the Michelin tyres on my second bike start cracking like this, my time with Michelin tyres will come to a swift end. I have been getting good result with Veloflex tyres. Even if the tyres are a few dollars more, I will switch back to them.
#292
Quoted: 800 Post(s)
Liked 512 Times
So just to post an update on this thread. I had a look at the set of Michelin's on my other bike. Just under 4,000km and the rear tyre appears to starting the same process as the tyre in the photo above. I definitely think I am done with Michelins. Too bad too b/c the tyres were a breeze to mount on my setup and I thought they gripped the road quite well. Bummer about the shortness of the tyre life though. Looks like I'll be sticking with the Veloflex tyres.
I will continue to ride the tyre but I am going to inspect the tyre after every ride so I can keep an eye on when the tyre splits.
#293
Liked 5,180 Times
Thanks for the update on Michelin tyres. I’ll cross those off my future list.
I’ve now got 4000 km on my Conti GP5000S TR (30 mm) and they are still looking good. No cracking and plenty of wear life remaining. They’ve seen some rough roads and extreme heat too. No flats either, but the rear took a small cut recently that self-sealed without me noticing on the ride.
#294
Quoted: 2333 Post(s)
Liked 2,097 Times
That MIchelin looks well beyond when I would replace it. Worn out. YMMV
#296
Liked 595 Times
Some people like to live dangerously. If that thing explodes at high speed on a descent, there will be a serious hospital bill (unless that guy lives in Canada and/or has a free health care system).
#297
Quoted: 1468 Post(s)
Liked 1,495 Times
I double flatted Wednesday AM on a chunk of broken glass and ruined two brand new 28mm GP5000 S TR's. I happen to have an REI and a Backcountry store just a few blocks away, so I walked up there today assuming I'd be able to find some replacements, or maybe one of the other popular road tubeless options (P-Zero Race, Pro One, maybe the Power Cups or one of those crazy Vittoria options...). Nope. Neither of those stores have any 28mm+ road tubeless tires in stock at the moment.
Anyway, there is also a Specialized store near me (yes I'm surrounded by corporate chains) and they had some snazzy tan wall S-Works Turbo's in 30mm size. This was not my first choice, I've been very happy with 28mm GP5000's, but seemed like the best option if I wanted tires today (which I do, so that I can ride tomorrow AM).
So... Specialized gets another $200 from me (I also bought a mini hand pump and a bottle of sealant). I'm going to mount these up on Zipp 303S wheels tonight and try them out tomorrow on a group ride. Hopefully they go on & seat easy and don't cause me a bunch of headaches.
Anyone have any experience with these tires? They're the regular Turbo 2bliss 2T/5T, not the "RapidAir" which I think is the higher end version. I presume that means they have a little more flat protection at the expense of a few grams and rolling resistance, the latter of which I'm hoping I won't notice.
#298
Liked 1,495 Times
Ready to rock. Install was uneventful. Fit is slightly tighter than the GP5000 S TR's, but nothing a tire lever couldn't handle. I needed to use my airshot on both tires to get them seated initially, but they stayed seated when I deflated to add sealant, so that's a nice bonus. Size wise - I don't have a caliper to measure, but visually I don't see any difference between these and the 28mm Conti's.
I like the tan sidewalls. Hopefully these last a while:
#299
Liked 5,180 Times
It will be interesting to hear your thoughts on how these compare with the GP5000S TR.
#300
Liked 3,176 Times
-YMMV
-YMMV
