Totally Tubular
#3076
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 169 Post(s)
Liked 93 Times
Amazon has been in the news a lot lately for how they are having to deal with counterfeit goods. I had an issue with several fake KMC X10 chains, and like you, Amazon made good and refunded me, but still because of their business model it's buyer beware.
#3077
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 228 Post(s)
Liked 313 Times
I'm transitioning from glue to tape. Somewhere.....I read that I should leave a gap in the tape, 180 degrees from the valve stem, to simplify removal of a flat tire. Are any of you tape users doing this? For those that are, how much of a gap are you leaving?
Thanks in advance for your input!
Dean
Dean
Roll Me Up and Smoke Me When I Die
#3078
Freewheel Medic
Quoted: 1467 Post(s)
Liked 2,231 Times
I use Effetto Mariposa tape and don't leave a gap. I've not had any issues removing the tire when I needed to.
Bob
Bob
#3079
Under Pressure
I used 22mm tires with high pressure in my criterium days; and I was a hard convert to lower pressure and wider tires... but now I like it a lot.
For me it's not about power output or road buzz, it just feels nicer and I feel more confident carving my line in the downhill hairpins of imperfect pavement I ride all the time.
#3080
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 305 Post(s)
Liked 709 Times
Dean
Dean
Haven't had to remove any yet though.
Likes For Aardwolf:
#3081
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 282 Post(s)
Liked 973 Times
Likes For SwimmerMike:
#3082
Quoted: 2375 Post(s)
Liked 2,904 Times
I used tufo tape with tufo tires on my first tubular setup and it really messed up the tires when taking them off
Likes For squirtdad:
#3083
Wheelman
Quoted: 305 Post(s)
Liked 709 Times
I used Tufo tape on 2 sets of tyres, I've now switched to Jantex and I think it's easier to use but haven't tried removing it yet.
I did managed to peel the tufo tape off some Vittoria Rubino 28mm and replace in with Jantex.
#3084
“Senior” Member
Don’t forget tape costs more than glue
A quick online check on prices shows Effetto Mariposa tape at $13-17 per tire versus Continental glue at $3 per tire (recent purchase from my LBS) based on half the cost of tube of under $6, which will do more than two tubes.
Also not sure in the case of a flat if you have to clean off the old tape and spend money again on another roll when you remount a new tire after a flat? With tape you just refresh the existing glue base on the rim and add a layer to a brand new tire if needed.
#3085
Quoted: 282 Post(s)
Liked 973 Times
#3086
“Senior” Member
I see jantex tape from merlin at lower prices and in their case a roll will do two wheels. Probably all over the map…
#3087
Freewheel Medic
Liked 2,231 Times
I don't mind it when a member points out the difference in costs between different approaches in bike maintenance, but it doesn't need to be a criticism. Such decisions are choices.
Yes, there is a difference in cost between tape-mounting and glue mounting a tubular tire. However, I chose the more expensive route for my own personal reasons, which include:
- Quick installation (about two minutes to mount tape to rim and another five minutes or less to mount tire)
- Neat installation (no residual glue on rim, tire, hands, etc.)
- Near perfect tire alignment (well, nothing is ever "perfect," but it is easy to center the tire on the rim, check for any humps, slanting valve stems, etc.)
- It is easy and not messy to remove the tire before pulling out the tape backing strip (just in case the tire needs to be removed, i.e. you realize the labels are on different sides, etc.)
Bob
Bob
Likes For pastorbobnlnh:
#3088
Quoted: 1618 Post(s)
Liked 2,233 Times
Can't argue with 1 and 4.
2. I have done well to not have residual glue on the rim or tire. Gloved hands take care of the rest.
3 Not a problem for me when following the time part of the instructions for Mastic. Can;t say I have had issues with humps, slanting valve stems or etc.
That being said to each there own. I love options and individuality.
Likes For SJX426:
#3089
“Senior” Member
Well. if you read my posts in this thread I don’t think you will find me being critical of anyone’s method.
It is always a personal choice in finding the best way for you.
i reread my recent post and did not feel I hid any criticism.
It was a don’t forget…no criticism intended.
#3090
Freewheel Medic
Liked 2,231 Times
Bob
Bob
#3091
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1303 Post(s)
Liked 954 Times
Dean
Dean
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Likes For 1989Pre:
#3092
Standard Member
Liked 954 Times
I'm 170 lbs and my R4's are 25mm, so what you are doing sounds similar to my approach. If I was riding in conditions like Belgian Waffle, Eroica Cal or even Dairyland Dare (three roads have gravel), I'd be approaching things completely differently.
#3093
Dean
Dean
TAPE...**********??? Big mistake. Only use MastikOne, period!!!!
#3094
Quoted: 1968 Post(s)
Liked 2,064 Times
Likes For Classtime:
#3095
Quoted: 282 Post(s)
Liked 973 Times
Wow, I now see the light! With such a compelling argument I now feel like such a fool for using tape. When I get home I will throw out my shop roll of tape, remove the 8 sets of tubulars that are taped on, and then put the tubulars back on with MastikOne. Hopefully I'll never make a mistake like using tape again. I feel so foolish.
#3096
Quoted: 228 Post(s)
Liked 313 Times
Regarding my original question, I've decided to not leave a gap in the tape other than at the valve hole, just like I've done on my other taped on tubulars.
Dean
Likes For Dean51:
#3097
Quoted: 4862 Post(s)
Liked 4,011 Times
I've now taped two bikes worth of wheels with the Jantex. No gap. Haven't taken one off yet, I do carry a steel tire iron. Don't have very strong hands. We will see.
#3098
WGB
Bikes: Panasonic PT-4500
Quoted: 1811 Post(s)
Liked 2,368 Times
Tape versus glue is a personal choice. Both seem to work perfectly.
Some people hate gluing due to getting it on side walls or arm hair. Personally, I liked gluing. The problem is I'd glue one, maybe two sets in a year. I'd faithfully ensure the can lid was on tight and I'd store it upside down and yet the next time I reached for the glue it was just that little bit too hard to use. I'd add a little solvent to try to dilute (can't recall what I use, but I followed what was recommended on this thread). Problem was, either the solvent didn't work or I didn't trust it after dilution. I switched to buying only single use tubes. Then I had to remember to order the tubes when I ordered something else to avoid extra shipping charges.
I saw that Tufo tape would only tape a single wheel so with Tufo, tape was definitely way more money per wheel than glue.
This summer, I saw a sale in the UK and bought Jantex tape for $5.85 Canadian a roll as I'd heard Jantex covered two wheels. I bought 5 rolls (+ a single roll of Tufo as I had a roll that was given to me). My order was shipped to me for about $65 Canadian. Keep in mind that if I can find Matsik here it's about $40 Canadian a can (plus $20 shipping) so I'd see glue and tape at close to parity but, presumably with tape, there'd be no wastage.
I put the wheels on my Hozan truing stand and put the tape on. I removed the new tires from the spare rims where they were stretching and installed on the wheels. Including fussing to make sure the tire were on a straight as possible, total time was under 15 minutes. I didn't have to glue tire and rim, wait, re-glue, etc.
I haven't had to remove a tire yet, I don't know how hard or easy that will be, or how easy or hard rim clean up will be.
I still have 3-4 tubes of glue. I expect that I will glue again in the future, if I ever have to set up a bunch of tubulars at once. Having said that, I have 4 rolls of Jantex and two rolls of Tufo sitting a drawer and next summer I'm sure I will open that drawer and the tape will be ready to go, whereas a partially used can of glue might be useable, but then it might not.
#3099
Wheelman
Quoted: 305 Post(s)
Liked 709 Times
I think I hit the same offer:
One roll does 2 rims.
https://www.merlincycles.com/velox-j...ape-81504.html
2023 May 21st
Merlin Cycles
Jantex tub tape white £3.59 (instead of £7.99)
Just checked the link and price hasn't changed Merlin Cycles
#3100
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 237 Post(s)
Liked 308 Times
I wasn't sure whether to post this here or in "Where did you ride today." Got the Stan's shower a little over half way through a 63km jaunt yesterday.
