ISO and for trade thread part 5
#3101
ISO classic looking, light weight 27.2 seatpost. I have a 26.8 Campy NR short, 26.8 titanium American classic, and a couple 27.4 American classic aluminum seatposts for trade.
Thank you.
Thank you.
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
#3102
I just took a silver 27.2 alloy American Classic off of a bike if that would work. I think I also have a Campy NR in that size. Let me know.
#3103
All fixed up, folks. Thank you.
Next request:
my 120mm GB stem for your 80-90mm GB stem. I’ll add cash if you have the version with the long point.
Thanks!
Next request:
Thanks!
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
#3104
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Liked 146 Times
hello Kurt, did you try to soak the pulley in evaporust? This may free it up. What’s wrong with the lever but you have ? Does it spin? Instead of replacing you can put the tip of screw driver in the gap when you tighten the bolt. That will prevent from spinning.
#3107
www.theheadbadge.com
Liked 4,538 Times
The levers are A-OK; I'm trying to replace the hardware. The nut for the pivot on one had backed out and is long gone, while the clamping bolts on both are rusted solid to the half-moon nut.
No amount of penetrant helped on the clamp bolt. The half-moon nut started rounding itself out on the lever, and its difficult to apply force to the half-moon nut without damaging it (and you're liable to nick the chrome of the lever doing so). Had to cut one off. I expect the same of the one I haven't removed yet.
-Kurt
#3109
ISO: sugino mighty seatpost saddle clamps
I have a sugino mighty seatpost (2-bolt campy clone) that is missing the bottom part of the saddle rail clamp. I know it's a long shot but does anyone have these extra bits? I would also consider another full 26.6 seatpost if you have one.
Lots to trade from Shimano/suntour but not really any campy. I'm also happy to buy outright. Let me know!
#3111
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Liked 415 Times
Topeak rack accessories
If you have a destroyed/nonfunctioning Topeak bag/back basket, I would like the plastic dovetail fitting ("fixer") that slides into the rack, screws included if possible.
Also iso one or two good used, or new, Salsa Side Loader bottle cages.
Thanks!
Thanks!
#3112
Señor Member
Liked 1,193 Times
ISO -
Huret clamp-on front derailleur. Would consider pretty much anything that functions and isn't all rusted up.
116 BCD 3-pin chainring (or a six arm) that isn't all worn down. The fewer teeth the better. Hoping for something with fewer than 40.
Saddle cradle clamp (preferrably silver colored) that fits over a seat pin.
Have:
cranksets, freewheels, brakes, stems, rear derailleurs, headsets, bottom brackets - and likely leaving a few things out.
Have:
#3113
Looks like nobody sells creme or white poly mudguards anymore for 700cc wheels. DON’T want to paint!
Does anyone have a set of these for possible trade? The Raleigh is British racing green and just screams for a set of these.
Thanks for the consideration!
EDIT: Looks like I found a set!
#3114
I think I have a set of white Bluemels. What do you have to trade?
#3116
Further rehab of the old toolbox indicates That I have a Suntour Superbe Pro 5200 rear derailleur with no cable clamp or bolt.
I don’t think this part is unique to this derailleur.
Anyone have something that would work?
Thank you!
Thank you!
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
#3117
Looking for TRADE for 650b wheelset !
I currently have mavic open cd wheels laced to shimano 600/tricolor hubs wheels must be compatible with shimano 10 speed cassette
#3118
Liked 3,990 Times
ISO:
108-110mm square taper BB spindle
#3120
Bikes: A few too many
Liked 2,498 Times
Ben
#3121
Stop reading my posts!
Vintage French and Vintage Japanese lighting, both FREE for cost of shipping (or trade for something I can use)
Probably all a longshot but have two old tech lights that both use a Cat's Head logo (guess this connotes "lighting" for some reason)
French is SouBitez front and rear, made to pair with a generator I guess, single wire and grounds thru the mount, the headlight has broken mount but you who want such stuff will figure out a work-around...very stylish, the lamps both work. Have any interested party for these, and....GONE!
Japanese is a Cat Eye battery-powered front only that includes a very worn box, I tested it and it worked IIRC
Take them all or pick your fave, just cover shipping.
If you want to trade (and we both ship at own expense): I can use a pair of inexpensive thumb shifters, the Falcon or a similar quality level, to handle 6-SPD rear and double or triple front. Another thing I could use is one of those "hybrid" Shimano RDs with the giant red pully that are made in Indonesia or Malaysia and found on the lower-end "comfort" bikes, but want one that works well so if somebody wants to swap for the Cat Eye light this may not be a straight-trade (or maybe it would be, I dunno)
#3123
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1969 Raleigh Superbe: 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold), 1966 Schwinn Deluxe Racer (sold)
Liked 1,019 Times
#3124
Liked 4,538 Times
