Totally Tubular
#3151
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 766 Post(s)
Liked 1,625 Times
Schwinn-Approved “330” tubular rims (may be Super Champion Arc en Ciel), Campagnolo Nuovo Record high-flange hubs, DT 14 gauge/2.0mm spokes, Vittoria Corsa Graphene 2.0 30mm tires. For now the tires are stretching until a shipment of Effeto Mariposa Carogna adhesive arrives. Can’t wait to try them!
#3152
Quoted: 952 Post(s)
Liked 3,078 Times
I switched rims on an existing wheelset, replacing Super Champion Gentleman clincher rims. I got lucky that the spoke length was just fine for the Schwinns but the orientation wasn't thee way I wanted it so I couldn't tape the rims together and move them one by one. Instead I kept the drive side laced and used the tape to held everything in place and laced the non-drive sides.
Likes For ascherer:
#3153
Quoted: 766 Post(s)
Liked 1,625 Times
Likes For ehcoplex:
#3154
Making up the numbers
Quoted: 112 Post(s)
Liked 525 Times
Having resurrected a fine Vittoria Pave 30mm onto Campagnolo Record Strada rim, I have, for the first time I can remember, if not ever, managed to roll the tyre slightly on the rim. Just a few millimetres from centred, but consistently around much of the rim and enough to be visually noticeable. If nothing else the iconic green stripes show up the situation. Having applied my usual three thin coats of Continental tubular cement to the rim bed, two to the base tape, with a final rim coat just before fitting, and left things to set for days a now slightly crooked valve stem also confirms all is not well between the two.
Rim had been cleaned with isopropyl alcohol, as had the tubular base tape after a previous Effeto Mariposa Carogna tape adhesion and removal.
I’d like to wear out my two remaining Pave 30s before delving into new stock of Corsa 28s, but I’m not sure what more I can do to avoid a rotational recurrence.
Any similar experiences from long-term users of both cement and Carogna? Any suggestions short of removing and replacing the base tape, which for me is a bridge too far…?
Nothing quite says wall hanger like drillium toe straps
#3155
Bikes: many
Quoted: 1460 Post(s)
Liked 1,413 Times
The tubular tire repair service in Florida (Tire Alert ?) I want to say charges like 35 or more to extract a tube then sew in a new butyl or latex tube. I would have to really love a magic carpet ride set of tubulars to go to this length to keep them on the road.
Edit: turns out they charge $42 to put in a new butyl inner tube and base tape: PRICES | tirealert
I agree with masi61. Better to just hunt around for good deals on new tubulars you like. Or spend the time to learn how to repair them yourself.
Likes For smontanaro:
#3156
Quoted: 1968 Post(s)
Liked 2,064 Times
seagrade I don’t understand the issue. Did the isopropyl alcohol dissolve the base tape glue? If the tire was centered, would there be room for it under the brakes? I think your Bianchi wants 23s or 25s maybe.
#3157
Quoted: 112 Post(s)
Liked 525 Times
I’m about to remove the tubular but I’m pretty sure the base tape remains securely attached. My initial suspicion is that in spite of cleaning the base tape with isopropyl alcohol some residue from the Carogna tape remains and hasn’t played well with the Continental cement. Will report back for those with a passing interest in such esoterica…
#3158
Quoted: 4860 Post(s)
Liked 4,005 Times
Although it looks otherwise there’s sufficient clearance under the rear brake and seat stay bridge for the 30mm tubular fitted, both when initially fitted and centred and as it is now rolled a few degrees from centred. Maybe 2-3mm clearance the caliper arm at the centre bolt, more everywhere else. The fork is a different story with clearance for a 25mm Vittoria and no more.
If it were me, I'd just ride the heck out of those 30s and do my best not to look! Done many miles on crooked sewups and nothing bad ever happened. And I love Open Paves. Never ridden them in tubular simply because I went back two years ago and they were passe.
#3159
Quoted: 112 Post(s)
Liked 525 Times
Were you setting the tire down on wet cement or cement that had tacked up nicely to grab the tire when you laid it down? I like to wait 15-25 minutes after the last glue before mounting the tire. Now some tires are not sewn evenly and want to sit a little off. They probably need the tackiest glue to keep them from going to their natural position. (And some stay a little off no matter how hard you try. Get better tires. And I think Vittoria has had teething issues with their factory in Asia. Those Open Paves may have been from that time. The Corsa G+ (I assume; most have come information free but they look very similar to the clincher equivalents) 28s I've used have been pretty darn sweet! Mount as nice as anything I've ever used. I bet your 28s will go on nicely.
Anyway, removing the tyre indicated the problem was between the tubular cement and the rim bed, rather than between the cement and the base tape. The Campagnolo Record Strada rims have a smooth and hard finish, and in spite of light sanding to give some texture, and subsequent isopropyl alcohol clean, haven’t held the cement well. Back in the day I used a hardened steel scribe to scratch parallel lines between spoke eyelets, but don’t have such a tool these days. Carogna tape worked well on the same rims previously, but the instructions for that say to leave the rim bed smooth for best adhesion.
The rear tyre had certainly moved enough not to keep riding it, and more importantly wasn’t sufficiently stuck to keep riding safely. At this stage I’ll remove what’s left of the cement from the rim bed while deciding whether to scribe it before trying again, or revert to Carogna tape which previously worked all too well with the same tyres. Curiously, the front tubular, a 25mm Corsa, has stayed true and remains well adhered despite being fitted the same way as the rear…
#3160
Quoted: 952 Post(s)
Liked 3,078 Times
I finally finished cleaning the old glue residue off the Schwinn rims. As I've mentioned, there was very little on them and it was fairly brittle. For better or worse I used fiber abrasive wheels in a Dremel to clean them off. It worked well, eye protection and a mask is suggested because they create a fair amount of dust as they wear. I used Effeto Mariposa tape to mount the tires.It was pretty straightforward and the tires mounted easily and fairly straight after being inflated on the rims for a couple of weeks. I have no idea when I'll be able to try them - winter storm is coming!
Likes For ascherer:
#3161
Freewheel Medic
Quoted: 1466 Post(s)
Liked 2,230 Times
Beautiful ascherer !!! I'm glad you tried the Effeto Mariposa tape.
Consider their mastic remover gel in the future. I'm currently working on a pair vintage Roval wheels. One was covered in the red (Clement?) mastic and the other in a white mastic. A thin covering of gel and wait 24+/- hours, followed by scrubbing the surface with a green Scotch pad soaked in hot water and rinsed often. No toxic fumes, no dust, and no flying eye debris. I did need to repeat on the red mastic one. Several places where the mastic was thicker didn't remove with the first pass yet came clean with a second application and scrubbing.
Bob
Bob
#3162
Quoted: 2375 Post(s)
Liked 2,904 Times
to note, I have used a brass wire wheel in a drill for old glue removal, have to wear eye protection but does a good job with no damage to the rim
hopefully will get to using mounting a set of FMB cobblestone tires to ambosio nemesis rims this weekend (tape this time around....)
Likes For squirtdad:
#3163
WGB
Bikes: Panasonic PT-4500
Quoted: 1809 Post(s)
Liked 2,363 Times
https://www.excelsports.com/vittoria...ular-road-tire
Vittoria
Was $129.99
Vittoria
Corsa G2.0 Tubular Road Tire
On for $48.00Was $129.99
Likes For WGB:
#3164
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 228 Post(s)
Liked 312 Times
^^^ Caught my attention when I saw the 25mm width in the photo. When I clicked on the link, I see the actual offering is for a 30mm tire. Anyone, am I missing something here? $48 is a great price in my view, but 25mm is as wide as I can go.
Dean
Dean
Roll Me Up and Smoke Me When I Die
#3165
Liked 4,005 Times
I chased that same rabbit. (I want 28s.)
#3166
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
It's become more apparent to me recently (when shopping on-line) that images of stuff being offered on-line too frequently don't match what ends up in your cart.
More than onced I've had to cancel an order when the confirmation doesn't reflect what I thought I'd been buying.
Likes For spclark:
#3167
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4367 Post(s)
Liked 3,030 Times
I bought some Continental glue from *mazon that was clearly advertised in text and photos as a box of 12 tubes; good price but not ridiculously low - about a dollar per tube. Then only one tube was delivered. I complained and they refunded my payment, so I got the one tube for free. I think the seller copied somebody else's ad or something and didn't pay attention.
#3168
Quoted: 952 Post(s)
Liked 3,078 Times
I posted that deal a month ago and if I recall correctly other sizes were available. I imagine they simply sold out.
#3169
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 350 Post(s)
Liked 180 Times
#3170
SEAGRADE :
Stay away from Continental glue. The stuff is worthless. Continental make great tires which I am v. partial to, beginning with their Sprinter. But Continental's glue is beyond worthless. I've been at this for over five decades and inasmuch as Clement "red" is sadly gone......... Vittoria Mastik 1 IS exceptional. It holds!!! I trust your tires were not loose when mounted, a tight fit is essential. I also mount the tire when the glue is just applied and wet. That is critical. I only glue the rim, never the tire, which just prior to final mounting is wiped on the base tape with lacquer thinner to open the pores for the wet glue to go into. You should get excess between the tire and rim which, after you've centered the tire with a increase from 5psi at time of mounting to then around 25psi, you pump up to 40psi and let it stay there for 24 hours, wiping off the excess glue with lacquer thinner (NOT isopropyl....., that does NOTHING!!!) on a CLOTH rag. You want some excess to bleed out, an indication of full coverage.
And why in God's name are you combining worthless tape with glue? Stay away from tape!!!!! Just glue. You NEVER mix the two. You're skating on thin ice the way you've botched this. Undo. Get rid of the tape, Re-glue with Vittoria.
#3171
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 169 Post(s)
Liked 93 Times
Totally disagree with some of the negatives I read here for Continental glue (can only speak for their aluminum rim version). I used Vittoria's mastic for many years when using Vittoria sewups and even for Sprinters. When I started using the Sprinters more and more I went to Conti Glue in the individual tubes. I could never tell a performance difference between the two brands of glud.
If you follow Continental's directions online you will not experience problems, aside from good luck removing a tire on the road (just make sure you are carrying 1 metal tire iron). I also have to think that if there is a potential for a difference in formulations, it may be best to use Vittoria Mastic with Vittoria sewups and Continental glue with Conti sewups.
Likes For gkamieneski:
#3172
It's MY mountain
Liked 3,030 Times
Continental tires, Vittoria tires, Specialized tires, Challenge tires, and Michelin tires. Mavic 330s and HED aluminum rims. Cold rides, rain rides, and one Eroica. Never a problem, and always damn hard but not impossible to remove a tire on the road or in the garage. It's available and it's good.
Likes For DiabloScott:
#3173
Liked 2,904 Times
I've been using Continental glue since I re-entered the tubular world 20 years ago - I don't remember what I used back in the 80's.
#3174
Bikes: 57 ExpressWerke, 58 CinelliB, 62 CinelliB Altenberger, 70 Cinelli SC, 76 Masi, 77 Colin Laing, 78 Ritchey, 80 Jack Taylor, 82 Appel, 82 Davidson, 85 Ironman, 92? Andy Gilmour, 04 Peter Johnson, 91 Ed Litton, 11 Bianchi
Quoted: 102 Post(s)
Liked 471 Times
Is biketiresdirect.com now the best source for decent deals on sewups? Any other recommendations to look at?
Thanks.
Guy
Thanks.
Guy
