Scooter Style ebikes
#326
Try Aliexpress . piece , not wholesale .There is plenty of options and prices . Currently Chinese New Year FESTS is dragging on my purchase 60 volt 20 ah $ 633.00 US Though my humble advice is to run 60v . Both my 500 & 600 watts bikes can. In Fact when my Ping Battery fully charges it reaches 71 volts AliExpress.com
#328
Bikes: veloteq cavalier
Veloteq Cavalier gear box problem
So, the symptom was, the bike was just in 'neutral'.
I removed the whole gear box with motor (not in hub).
Split the casing: several 10mm? bolts on the outside. Two 8mm bolts on the inside face. And the buggers hid an 8 mm bolt inside the brake housing (find it with a flashlight!).
The problem is the 'dog clutch'. Must turn in one direction, neutral, when pedaled, catch when the motor is driving it.
It is done by 8 or so small metal wedges that wedge themselves against the bearing races when turned. Except they are held in by thin plastic ring, which fell out, wedges fell out.
I think a 'washer' 22mm id and 39mm od, made of super thin metal is needed to keep the plastic ring in.
Opinions?
Thnaks, John, john@rakos.com
Opinions?
#330
55+ Club,...
Bikes: 9+,...
Liked 899 Times
Contact the company and get assistance: https://www.hybikes.com
