It just doesnt make any sense
#326
Jedi Master
I'm not sure I'd agree with that statement. I know it seems popular here on bf to misunderstand and misrepresent what gravel bikes are, but they really have nothing to do with a high-end hybrid.
Hybrid bikes, regardless of price point, are generally flat bar, have an upright riding position, and area geared/tired for road/path riding. Gravel bikes are generally drop bar, a lower, more aggressive riding position, and especially the last few years have moved to sub-compact gearing and wider, more aggressive tires for rougher terrain.
The two types can converge toward each other, but I would definitely not say that the term gravel bike is being used for many (and certainly not most) high-end hybrids.
![kingston is offline](images/statusicon/user_offline.gif)
#327
Tragically Ignorant
Liked 9,099 Times
Ok. Then it was just some weird dude. I'll take that. I had never heard of a mountainbike with road gears before, so I modified & made one to suit my uses of climbing Oahu's hills, the nimbleness to draft/dodge busses, garbage trucks etc, & flat land speed to keep up at or near the speed limit.
(No, I did not ride very smart back then.)
I kind of feel bad that I disabused you of the possibility you had invented the hybrid since it was probably a harmless delusion that made you happy. OTOH, maybe I spared you some "if only I had thought to market it, I'd be rich" regrets.
![livedarklions is offline](images/statusicon/user_offline.gif)
#328
Klaatu..Verata..Necktie?
Liked 12,429 Times
I agree with you 100% which is why it's always puzzled me that 50-34 has become the de-facto standard recreational chainring size. I'm about 3 w/kg FTP so not massively underpowered compared to the average recreational cyclist. My conclusion is that most people don't care about narrow spacing and run wide cassettes.
The last year or so, I've become interested in bikes from the 80s, with fewer gears in back, and with downtube shifters that do not encourage the frequent shifting that brifters do, and that has trained me to be able to spin a wider range of cadences comfortably. The little roller where I might shift to a lower gear to go up then a larger gear to come down to keep my cadence in the 90s when riding a more modern bike, on an older bike I'll just push harder on the pedals for a bit and let my cadence fall into the 80s, then spin up into the 100s on the other side.
![genejockey is offline](images/statusicon/user_offline.gif)
Likes For kingston:
#330
Liked 7,826 Times
Here's an example. These are two bikes that I actually own and ride a lot. One has a standard 50-34 compact crank with an 11-speed 12-25 and the other has a road triple 50-39-30 with a 10-speed 12-25. The double is fine for fast group rides, but terrible for brevets, especially longer ones. On a 400k in rolling terrain I normally average somewhere around 24-25 kph on the bike. On the triple, I only have to front shift if the hill is big enough that my speed goes below 17 kph or above 38 kph, so in rolling terrain, I might literally go hours in the middle ring without ever making a front shift. On the double, I have to front shift if my speed ever goes below 26 kph or above 31 kph, which is essentially every little incline, so I'm constantly cross-chained and making front shifts. The compact double is great if I'm riding steady in the 30's kph, but it's almost unusable if my pace is in the mid-20's kph. Of course a sub-compact crank solves that problem, but they haven't been widely available until pretty recently when gravel started gaining popularity.
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1173x434/gear_compare_3_934e5523ea58c3c24423ff7032b4dbc156d00f8f.jpg)
![tomato coupe is offline](images/statusicon/user_offline.gif)
Likes For tomato coupe:
#331
The talk here of needing such and such gear range seems to be based on the idea that the cyclist can only pedal in a very narrow range of cadence when in actuality, we are a lot more adaptable and most can perform quite well across a pretty wide range. It seems like the desire is to have all this gearing so that they can pedal with the exact same cadence and effort in every situation. That seems like such a boring way to ride. I guess that's why I never got into group rides, I don't really like the robotic approach so many seem to have toward cycling.
![NumbersGuy is offline](images/statusicon/user_offline.gif)
Likes For NumbersGuy:
#332
Every 2x or 3x setup forces you to shift at certain speeds. Whether or not those shift points occur at speeds that you find inconvenient depends on how fast you ride. In your case, the 2x setup is basically a racing setup, but your 24-25 kph average isn't racing speed, so the shift point from the big ring to the small ring falls in an inconvenient place. A different 2x setup would solve some of your problems.
Then there's the *GASP* pedaling in a wide range of cadences idea that seems to be incomprehensible to most here.
#333
Liked 2,203 Times
But running a 52t/42t with an 80’s 13-15-17, is wider than a 50t/34t with a 10 speed 11-12-13-14-15-17…
Corncobs were race oriented back then and generally not recreational.
John
Edit: Added big rings.
![70sSanO is offline](images/statusicon/user_offline.gif)
#334
Jedi Master
#335
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Liked 1,494 Times
Fourteen pages for something anyone's supposed to have figured out in the first half-hour of their first ride on a geared bike. Boy, this thread really flies in the face!
![sjanzeir is offline](images/statusicon/user_offline.gif)
Likes For sjanzeir:
#336
Jedi Master
Absolutely correct. The fundamental problem here is that I was young and fast in the 80's but now I'm old and slow.
Likes For kingston:
#337
I am potato.
Liked 1,748 Times
No way would I think I could claim credit. That bike evolved organically as my needs changed. The Hybrid as we know it was an inevitability.
Car dependency is a tax.
![base2 is offline](images/statusicon/user_offline.gif)
Likes For base2:
#338
Liked 3,722 Times
Hybrids, or whatever they choose to call them ... have a very specific market.
Hybrid buyers tend not to want drop bars. That is the single most important determining characteristic ... a lot of riders tend to forget that for a lot of other riders ... the ones we don't see because they are on MUPs or cruising happily on paths, trails, and streets not suited for of generally used for more spirited riding---see those funny, ram's horn handlebars as weird and uncomfortable. To those folks a bike is something you ride sitting up with bars that sit up high to reach you.
Next, a lot of hybrid owners like a little suspension (or a suspension seat post) because comfort is a big deal to them. A few extra pounds means nothing---they are used to 30-40 pound bikes and a 30-pound bike is just fine (I can recall my old Bridgestone MB4--a "mountain Bike" back in the mid-late '80s--rigid, 48/38/28 Deore drivetrain, chromoly frame and forks, 30 pounds ..... it was considered a respectable MTB, and just about two pounds heavier than a high-end model. These people probably recall Schwinns or box-store bikes, 35-45 pounds ..... )
The folks who want hybrids are not looking (by and large--@Livedarklions is a freak
![Big Grin](images/smilies/biggrin.gif)
![Maelochs is offline](images/statusicon/user_offline.gif)
#339
Jedi Master
Here's an example of what I mean. A buddy of mine walked into the Trek store 10 years ago and told them he's a 40 year-old male runner looking to do 30-50 mile rides a few times a month on the Des Plaines River Trail (a flat gravel path in north Chicago). They sold him a high-end 3x9 hybrid. That same guy from 10 years ago goes into the same shop with the same request today and there's no way he gets a hybrid. He's walking out of there with a 1x gravel bike. I've been riding the DPRT for over 30 years. It used to be all mountain bikes and hybrids, now its mostly gravel bikes that didn't even exist 10 years ago. That's what I mean by gravel bikes have replaced high-end hybrids.
Likes For kingston:
#340
Liked 3,722 Times
[MENTION=388062]kingston[/MENTION]--I am surprised they sold him a hybrid for 50-miles rides. of course, road bikes all had really skinny tires back then. Sure, they would not try that today .... but here's the thing people never want to remember---and which I noted regarding [MENTION=484412]livedarklions[/MENTION]: Some people are freaks. Some people are outliers.
We all know how generalizations work, yet there is so often someone trying to point out a specific exception claiming it invalidates the rule.
AS I SAID:
"Hybrid buyers tend not to want drop bars. That is the single most important determining characteristic ... a lot of riders tend to forget that for a lot of other riders ... " etc.
I have done long rides on a flat-bar bike. I certainly know it can be done. I also know why manufacturers sell bar-ends, ergo grips, Jones bars, H-bars, and the like. Riding for a few hours in one position is more tiring. I found myself sometimes leaning far forward and reach up from underneath the bars, or whatever, because holding one upper-body position for a few hours is more tiring. That is why they would sell your buddy a drop-bar bike.
If gravel bikes had been a thing back then, they never would have sold him a hybrid. I agree. But he is NOT the typical hybrid customer, never was and is not now.
Likes For Maelochs:
#341
Liked 12,429 Times
Glad to hear about someone else utilizing some flexibility in cadence/effort to deal with grade variations. I have been doing the same on my 2x11 for quite some time, simply not shifting even though it would be supremely easy. I find myself interested in getting a single speed again, which in the absence of any real hills is perfectly fine for recreational riding.
Likes For indyfabz:
#343
Liked 12,429 Times
Well, he DOES say where he lives is flat enough to ride a single speed bike, so.....
Likes For genejockey:
Likes For indyfabz:
#345
Liked 12,429 Times
#346
Live not by lies.
Bikes cover a wide range of styles and uses.
Bikes are ridden at different speeds, different inclines, and different terrain.
Some improvements might not be better for most riders.
It is impossible to say 1x, 2x, or 3x is better. Only which one you like more.
Some like 1x1.
Some like 1x1.
![SkinGriz is offline](images/statusicon/user_offline.gif)
Likes For SkinGriz:
#347
I sure wish I had such a varied and exciting life such as yours, with the time to rack up 30k+ posts on this forum. You sir really are impressive….
#348
Liked 3,722 Times
Why do people have such a problem with other people having different Preferences??? !!! ???
Generally, I prefer to let my transmission do more work than my legs. I stay in a narrow range because I don't have much power or energy, and getting the most out of it is most enjoyable for me, ..... Generally.
Sometimes I just power up a climb or coast down a descent. Sometimes I spin up a climb and shift six times. Sometimes I power down descents. Sometimes I don't even ride my bike. Whatever is my Preference on that day.
Some people prefer other things than you. Sorry, but you had best get used to it.
Also, nobody said it was not possible to ride a wide-spaced cassette, or that it was bad. people said they Preferred narrow spacing.
The Only time I recall someone saying that they almost had to have narrow spacing is [MENTION=186391]indyfabz[/MENTION], talking specifically about fully loaded touring and long climbs. And as someone who has done that (and also gone hard into a 20+ mph headwind while riding all-day rolling hills) I can say that in that case, where you cannot just stop and rest because you need to get to your campsite in time to set up before dark, and where you need enough energy to finish the day's mileage or you might end up camping in the breakdown lane or in a cactus forest full of scorpions or something ..... yeah, in that case, having the right ratio is really important.
That is where triples shine---you can have a couple very low gears, a couple very high gears, and a whole ranges of very close gears so you can really fine-tune your energy output to the terrain and conditions.
Also .... it is about ten times harder to push a loaded touring bike up a hill as to ride it, however slowly. The bike wants to tip over all the time, and you spend half your energy trying to balance it. It is a lot easier to pedal at a steady 4 mph than to push a steady two .... which means an hour's climb might be three hour's push, and you will be twice as tired when you reach the crest .... and then still maybe have 50 miles to ride to your campsite.
Also .... you can mock racers if you like, but there is a reason they use the corncob block, and it is efficiency. In that case also close ratios make a difference, because the energy wasted turning the wrong gear might mean not being able to latch on when someone attacks the breakaway, meaning you busted your butt for three hours, only to get dropped thirty minutes from the finish.
So, yeah ... recreational cyclists Could all ride single-speeds ... after all, for years everyone did. but not a lot of riders Prefer to ride single-speed. Even the people here mocking people who like close ratios don't ride single-speed currently ....
it is all a matter of Preference. There is no right or wrong, beside the right of understanding that different folks like different strokes, and the wrong of failing to acknowledge that.
Likes For Maelochs:
#349
Some like 1x1.
Some like 1x1.
![rsrogers is offline](images/statusicon/user_offline.gif)
Likes For rsrogers:
#350
Liked 9,456 Times
Many people that desire tight gearing, like myself, want it for situations in which we're trying to sustain output at the limits of our capabilities. When you're trying to hold on to a wheel, or an interval, or shave a second off of a PR, etc, and you're at the edge of cracking, a 2-tooth gap might be too much - one asks too much of your legs, the other too much of your cardio, no happy/painful medium.
No one needs tight gearing for noodling around, so don't pat yourself on the back too vigorously.
![WhyFi is offline](images/statusicon/user_offline.gif)
