Racer Tech Thread
#3626
RacingBear
I am actually interested in this also.
I have dura ace SRM with rival rest. I was throwing around upgrading to electronic shifting on the race bike, but I don't want to replace SRM.
#3627
commu*ist spy
i don't think they changed the chainring teeth between 10 and 11. in fact, I've heard that 11 speed chains work better on 10 speed drive trains than 10 speed chains, in terms of shifting
#3629
Quoted: 693 Post(s)
Quoted: 693 Post(s)
How do you guys transport multiple bikes including a TT bike with rear disc? For a single bike I've always just put it in the back seat with the front wheel in the trunk, but adding a second bike poses a problem. I'm considering a tray-style hitch-mount rack to put on my wife's SUV for traveling to stage races, but some of the more popular options (Thule T2 Pro, Kuat NV 2.0) don't work with a disc wheel since they are designed to run a strap through the rim of the rear wheel.
Reading through some discussions on the topic at slowtwitch, some recommend racks that use an arm over broth the front and rear wheels, such as 1up USA or Inno. Others say it's too risky with the disc wheel, put a training wheel on for transport. I guess my question is how much wind is the wheel going to catch at highway speeds if it's mostly sheltered by the SUV? I guess it's worth mentioning my disc is HED Jet+, so we're talking fairing/cover, not solid CF.
The training wheel seems like the safe/obvious option, but would be a PITA: having to bring an extra wheel in addition to race spares for the road bike, plus swapping the wheel and handling the chain, etc. But the biggest hassle is that the Jet+ barely fits my TT frame even with 23mm tires; the wheel has to be perfectly aligned in the horizontal drop-outs to avoid tire-rub when getting out of the saddle, and getting it right can take a bit of trial and error. I'd rather not have to be messing with that right before a TT is about to start if I can avoid it.
(3.0 turns out to be the maximum width in 'stock' configuration, but with a spacer kit you can fit up to 5" tires -- and, yes, i know some folks that actually have bikes with 5" tires that weigh more than their frame.)
love the modular aspect.
everyone who loads a bike onto my rack comments on how great it is, and that includes owner of pretty much every other rack.
highly recommended.
#3631
Quoted: 693 Post(s)
i am always curious about any new power meter, and for sure i'd be happy to try it out if given one for free or at low cost. however, i've had enough experience with power to no longer want to be a retail tester.
many years ago i wanted to believe the hype of the new kid on the block and happily paid my money. i came to realize the value in a mature product design.
i hope the shimano meter is accurate, reliable and reasonably priced. i hope their is continued downward pressure on the market (i'd like to see ACCURATE and RELIABLE power democratized).
we'll see what happens with this one. it's not coming for basically another year.
#3632
RacingBear
Should I start a thread in Road Cycling?
#3633
commu*ist spy
you know I always wondered whether sram front shifting would be better with shimano chainrings. it probably will be. but how will it compare with shimano front derailleurs?
#3634
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
get the 1up. i've had it for 6+ years. works with every bike i've ever thrown on it......and depth road wheel (including disc), lefty forks, my kid's 20" then 24" and now 24plus bike, and my wife's new bike with 3.0 tires.
highly recommended.
highly recommended.
I had initially ruled out the 1up in favor of the Inno because several reviews mentioned the lack of security, but I see they now offer a hitch lock that works with the current models, as well as a way to lock the wheels in place.
#3635
Quoted: 693 Post(s)
Thanks for the feedback. So you feel the disc wheel is OK on the rack at highway speeds?
as for security....i never use anything on my 1up, but i also don't really leave it alone. someone could always have the right combo of wrenches to essentially open up the rack/remove struts/whatever and defeat any security. that's pretty much true with every rack i've seen. i don't really worry about it, but i also have no idea where you live/travel and how comfortable you are.
#3636
Bikes: Scott Foil 10, Di2
Quoted: 148 Post(s)
Anyone try the Specialized Power (Pro or S Works) saddle? Currently using a Selle Italia SLR Max Flow. Just demo'd two of the ISM saddles, and *hate* how wide they are up front.
#3637
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I've got the lower-end one on my TT bike. The shape is the same, just the padding and rails are different. I really like it. It turned the TT bike from a torture rack into something I could ride for a couple of hours comfortably. A lot of guys around here have put them on their road bikes and are happy with them; I'm considering doing the same thing.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#3638
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
I really need a new saddle. My Specialized Toupe 135 is wearing away at the front and I'm sure it's completely worn out internally. Might have to find a good local shop and try some out.
#3639
Quoted: 160 Post(s)
i tend to not travel with my disc that way, but i've done it plenty. it's at the back of the vehicle and a bit sheltered. i don't think some wind on the disc is going to do much, anyway. that just my opinion, though.
#3640
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
If you're thinking of keeping with the Toupe, the new style is much better built. I've got ~7k on one and there's no sagging like I experienced with the old ones.
#3641
No matches
Liked 444 Times
Good to know. I feel like the Toupe was comfortable for me when it was new (otherwise I'm not sure why I would've kept it). But now I get some numbness and it feels like it sags. There aren't as many comfortable places on it anymore.
I think I have a Phenom on my track bike, which is fine for the amount of time I spend on that bike. Maybe I should swap them and see if I like that.
#3642
That tempts me to give it another try. The sagging was a huge problem for me, it actually ends up seriously aggravating my knee if my pedaling platform isn't rock solid. I do need a new saddle next season probably, and the changed the design on my current Phenom, so. Hmmm.
#3643
Tyrannosaurus Rexitis
Bikes: Scott Addict 6870
Quoted: 60 Post(s)
I am one those who switched from Toupe to Power because of the sag issue. I like it well enough. My wife rides the same width toupe (143) and hates the Power, so there's that. Net 0.
I put our spare Toupe on the TT bike and was pleasantly surprised that I wasn't split in half. People must get fearful of a firm saddle for tris because it came with this lazy boy of a Cobb saddle.
#3644
W**** B*
Bikes: Several
Quoted: 103 Post(s)
Still waiting on my eTap order (order in since March). Local shop still can't get their hands on the upgrade group.
I see it "in stock" on a few websites, but I'm holding out to get my sponsored team shop discount.
Anyone else seeing it available locally or have any insider info?
Last update I got was "maybe July".
#3645
Quoted: 98 Post(s)
I tried the Power from a Toupe and my ass was not a fan at all. Back on a new Toupe and really liking it, no sagging issues at all.
#3646
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2772 Post(s)
Liked 3,362 Times
Most saddles I've used have been so-so at worst. I'm riding an old Flite right now, forgot how comfortable that thing was.
"Your beauty is an aeroplane;
#3647
Quoted: 1853 Post(s)
Liked 680 Times
(I tried the Toupe once. I think I described it as an "Ass hatchet.")
#3648
Liked 680 Times
#3649
Quoted: 98 Post(s)
I bought it, but the Clean Machine has a 30 day return policy. They said it's Specialized's way of having saddle demos without needing actual demo saddles.
#3650
Bikes: Specialized Allez E5, Specialized Crux Pro, S-Works Langster
