Retro roadies- old frames with STI's or Ergos
#3676
^That's superb! Not personally a fan of the Cinelli stem, but the modern wheels on the silver frame actually work really well.
#3678
keep it simple.
Bikes: Univega Superstrada modern build
R3tired's bike photo is actually a perfect example and 'answer' to your question. As you can see, he has standard 'italian' style drop bars, but has the levers mounted higher than yours so that the flats of the drops are close to parallel (pointed at the rear brake, apprx) AND lever hoods that are flat or angled slightly. If you want to change to 'compact' drop bars, that is question of personal taste/comfort, but one that is separate from whether you have your bars/levers setup 'correctly'. Try the higher hood position, and if you still don't like that then consider different bars, IMO.
#3679
^ One thing I like about compact drops is that the area of bar immediately behind the hoods is also horizontal, with the hoods in the "correct" position, and I think it is this which you can't achieve with classic drops. Obviously it's personal preference as to whether you want that or not but I find when I'm resting on the hoods, this flat area is more comfortable for the fat paddy bottom of the palm that's just in front of the wrist, compared to the slight downward slope of the classic bars as shown above, e.g.:
(I've since angled the bars back by a degree or two, so the top of the hoods is ever so slightly closer to horizontal.)
#3680
keep it simple.
P.S. That Ron Cooper is stunning!
#3681
Thank you!
Yes, it occurred to me when wrapping my hands completely around a Campag hood in a bike shop the other day that, actually, I only really do that when I'm riding out of the saddle or braking, whereas most of the time I'm resting a little further back, utilising the hoods and top-of-bar. So that flat transition feels good for me, but may be less important depending on other people's preferred riding position on the hoods.
#3682
Hello! I'm new to the forum and this is my first post. This thread inspired me to take and old Trek that I had been using as a single speed and build it up with a modern drivetrain. I'm building it using spare ultegra 6500 components from a different build, and plan on swapping out the black seat post, stem, and bars for something more in keeping with the vintage nature of the frame. Anyway, just wanted to share and I'll update as I get it all together.
#3683
Looks like an excellent start, and welcome to the forum.
The post and stem actually set off the ST logo fairly well.
#3685
The Drive Side is Within
Looks very similar to mine!
Also under construction -- '83 Trek 520 with black post and stem, too.... pardon the mess. Better pics to follow.
EDIT: I advise rotating your bars "down" and moving your shifters so that they create a flat area -- see the picture below.
Those shifters are not placed correctly -- they're in a position that is closer to where old school levers should be. Either way, the bars are probably rotated way too high.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
#3686
#3689
Hot.
2019 Salsa Warbird
2019 Salsa Warbird
#3690
What he said. +1
#3691
Not sure if I'd like that better with white tape (not that I'd want to deal with keeping white tape clean myself) or if that'd be too over the top. But it definitely looks nice as is.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#3692
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Liked 116 Times
I'd definitely go with white bar tape and cable housings. If you're like me, it'll be a "sunny day" bike, and other bikes will be ridden when there's a chance of nasty weather and/or road.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#3693
Fizik white bartape wipes clean easily.
2019 Salsa Warbird
2019 Salsa Warbird
#3695
Bikes: Trek Modone 6.5 (08), 1930's Healing, 1994 Ritchey Road Logic, Kuwuhara T/T early 90's, Shogun Prairie Breaker Expert 1992,
Just finished a complete rebuild, taken a couple of years but worth it, such a nice ride.
With some Wolbers ( just waiting on a new front tire)
#3697
Very nice upgrade. Ride it in the coming winter?
#3700
Here's how I picked it up
All the cable guides where rusted of and the brake bridge as well.
