Pictures of you suffering in a race (please credit photographer)
#3801
Batüwü Creakcreak
#3802
Batüwü Creakcreak
#3803
...let me ride
Bikes: '07 trek madone ssl, DA.
Points for the overall are 10 deep. There was still time to work your way up for a top 10. Also around here if there is any gap before the end of the field and a rider they score you as dnf. Field finishes count for 4-3 upgrades. Makes for some really dangerous sprints.
#3805
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
and I think you can upgrade to 3s on top 20s (in large fields, maybe I"m confusing that, but I know you can use top 10s). Either way I should find out since that's probably how I'M getting my upgrade
![Frown](images/smilies/frown.gif)
#3806
In order to upgrade with those top 10 finishes, you need 20 races or more before you can upgrade.
#3807
Bikes: '07 Excalibur, '08 Anthem 1, and some others
slow up hills
Almost, but norcal doesn't honor the pack finish guideline. https://www.ncnca.org/docs/upgrade/index.shtml
#3809
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Additionally, for 10 top 10s, fields need to be 30 or more.
And for 20 pack finishes, fields need to be over 50. That means cat 5 pack finishes don't count, since they are limited to 50.
#3810
I remember now that the races just have to meet the minimum time/distance requirements. Note that they updated the rules again this year to give minimum time or distance for crits, rather than just distance as previously.
#3811
Actually, they've said several times that pack finishes won't count in norcal. Reiterated at our last team meeting by an official. The standpoint of the NCNCA is that those are guidelines, not rules, for upgrading, so they can choose to not use them all. That might change with the new board and leadership.
#3815
Batüwü Creakcreak
I've placed well in crits and still sat up during last laps because I was too far back to make it 'worth it' to get to the front. If you can get by like 30 guys and get on the podium or in the top 10, then you probably could have been in the top 10 out of the last corner.
Just sayin'.
#3816
Mrs. umd
Bikes: Specialized Dolce Vita & Transition
Because you want to ride with a group less likely to crash. Or you are good at TTs and stage races, but there are no points to upgrade from those for 4->3.
#3817
Mrs. umd
#3818
Batüwü Creakcreak
I understand what you're saying, but still. If you're competitive in stage races, you should still be able to finish in the top ten of a road race.
#3819
![Wink](images/smilies/wink.gif)
#3820
It's a USA cycling license, not a NCNCA license, so it doesn't seem fair that the local rep should decide not to follow the standards of USAC. A person can come into NCNCA area from out of district and have upgraded using the experience track, and they don't get downgraded when moving into that area, or racing in that area. Seems you could rent a PO Box in a different area so you are under a different USAC region and upgrade that way.
There are ways to circumvent any system. The local administrator is just trying to address the situation within district. Getting a PO box out of district is a pretty drastic step just to get a relatively unimportant upgrade. I'm not sure why you'd want to upgrade if you can't finish top 10 in cat 4 races anyway. If a rider upgrades out of district, that's fine. There's a lot of overlap in the categories, as you know.
I personally think any upgrade past 5 should be by points, but I understand the need to balance the field sizes a bit. Also, the "standards" are guidelines, not rules. Upgrades should be about ability, not the end goal of racing.
#3821
Mrs. umd
I could understand that if it were a regional license, and all riders in all races in the NCNCA region needed to upgrade on points only, but this isn't the case. I race in both NCNCA and SCNCA races, but live in SCNCA region. I could upgrade on experience (eventually) and would regularly race in NCNCA races.
I understand they are guidelines, but imagine NCNCA deciding that you needed 25 point to upgrade to a 3, or 30 points. After all 20 points is just a guideline. Disagreeing with the national guidelines and refuising to follow them when issuing a national license is ridiculous.
So points are the only determinant of ability?
#3823
The PO Box is just an extreme example to show that it is possible to circumvent the NCNCA . It's a national license, not a regional license, so not following the national guidelines and not upgrading riders on experience while other regions do is not fair.
#3824
I guess I'm sorry you feel that way. It works for the NCNCA and few seem to have an issue with it. And yes, I would argue that race results are indicative of bike racing ability, more so than just rolling in with a pack. The last NCNCA president has publicly announced that he's ignoring the pack finish guideline for a variety of reasons, and USAC has not had any issue with that, but if you feel strongly about it you can file a grievance with the USAC.
