Bike stuff that bugs you more than it bugs most people
#376
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
I just realized my list excluded possibly my biggest pet peeve - dirty/greasy drivetrain. Not necessarily on others' bikes (not my problem if you want to deal with the mess).
I've ditched grease/oil altogether and have gone the Molten Speedwax route for several years now, and will never go back. Silky smooth and spotlessly clean.
I guess my years of commuting with a belt drive/IGH setup decreased my tolerance for dirty driveline beyond my already low level, once I re-integrated chains into my life.
#377
Quoted: 174 Post(s)
Liked 157 Times
More than aesthetics, there is a practical reason for going bottom-top, primarily the direction of the overlap as it relates to the direction of your hand placement/movement. For folks who spend alot of time on the hoods/tops, the bottom/top wrap yields a more compatible overlap, whereas the top/bottom results in an overlap that will very readily peel/roll or gap as the miles pass.
Who among us can remember gaps in their Benotto pearlescent tape or rolled edges of cloth/cork tape on the top bends and above their hoods after trying the top/bottom wrap?
Personally, I'll take a small strip of tape at the center of my bar to messy tape edges and gaps any day
Likes For canyoneagle:
#378
Habitual User
Quoted: 5060 Post(s)
Liked 8,342 Times
I've wound bottom to top for nearly 40 years - the center tape has always been an element of a properly finished bar, in the minds of many (myself included).
Likes For Eric F:
#379
Quoted: 1843 Post(s)
Liked 3,457 Times
Funny thing, and I wonder if others here have experienced this - more than once I've come down the road on my bicycle and passed by motorcyclists who have extended the wave that I used to get and return when I rode a motorcycle. There is a commonality in that car and truck motorists often fail to look out for two wheeled road users. Anyone else?
What I find interesting is that I get it a lot more when riding the recumbents than when riding the upright bikes. Maybe I'm more recognizable as kin when leaning back than when leaning forward?
I do try to wave to the motorcyclists more often now, just to try to expand the sense of community. A little positive public relations never hurts!
Steve in Peoria
#382
Quoted: 2588 Post(s)
Liked 4,827 Times
to wit:
https://youtu.be/5MzIiv7pewE
I guess it all depends on where you prefer to have your tape rolling. Rolling is going to happen regardless if you utilize the bar's real estate to the fullest extent possible.
Top down for me, and sometimes I use an alternating finishing tape. Sometimes not.
DD
#383
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i've seen some folks wrap the tops down and then from the bar ends up finishing off both at the levers
Likes For thook:
#384
bironi
Quoted: 106 Post(s)
Liked 311 Times
I'm frightened by the very large flat pedals with the knarly grippy studs for foot traction.
They are shin rippers to me.
They are friendly to my wife and some of her riding friends.
Likes For bironi:
#385
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
ha! there was a time in my younger years of riding knobby platforms i shied away because of the shin damage. i don't ride them, anymore. i like toe straps. getting stuck in them sucks....and then it's bloody elbows
#386
Quoted: 604 Post(s)
Liked 1,064 Times
Wrap from top to bottom and the tape will roll from contact on the tops of the bars, okay. But! Wrap from the bottom to top and the tape will roll from contact on the drops.
DD
DD
Tim
#387
Liked 4,827 Times
DD
#388
Quoted: 1869 Post(s)
Liked 666 Times
More terminology: "vintage"
#389
Liked 666 Times
DD
DD
But none of these are peeves for me, so maybe this bar tape stuff is just off-topic.
Likes For Phil_gretz:
#391
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Non-aero brake cable housing where the loops pass beneath the handlebar from the front side. Yikes.
Splatter patterned bar tape.
Tires colored to match the trim of the bike. Tires should be black or tan/black. In some exceptional cases, wider tires can be cream colored. Otherwise...no.
#392
Zip tie Karen
Liked 1,542 Times
The one exception to this I've found is where the closing the lever would interfere with a disc brake caliper combined with a thicker MTB fork. Flipping the front skewer gives the lever free movement on the drive side. I know, otherwise a heresy.
#393
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3931 Post(s)
Liked 6,581 Times
#394
Liked 3,457 Times
DD
DD
My question is whether this (and other) advice is specific to a type of tape, and whether there are factors that determine whether the edge of the tape will roll.
Honestly, I thought this debate was only relevant to cloth tape. I've always wrapped cork-ish tape from bottom up because ... I think that is what the instructions showed? It's been so long!
Plus, cotton tape was finished at the bottom partly because you could just shove it in the end of the bar and secure it with the bar plug. That was never going to work with the thick tapes.
Personally, I don't recall the tape ever rolling, regardless of the type or direction of wrap (with the disclaimer that I always wrap cloth from top to bottom, and cork from bottom to top). Cloth tape wears out before it rolls, or just starts looking terrible. Cork-ish tapes get filthy or get loose, or both.
I think some proper research is in order! I recently wrapped a bike with Tressostar cloth tape using the Harlequin pattern. The bike uses bar end shifters, so I had to wrap the top half from the stem down to the brake levers, and the bottom half from the bar ends up to the brake levers. Maybe I'll get both halves rolling at the edges? Maybe neither? I'm betting it will just get too faded and nasty before either happens.
(sorry... no good photos)
Steve in Peoria
#395
Habitual User
Liked 8,342 Times
DD
DD
#397
Habitual User
Liked 8,342 Times
This gives you the wrong overlap direction on both parts of the bar. Starting at the levers and working towards the top and towards the ends would give you the right overlap. However, it wouldn't eliminate the finishing tape on top, which is the hang-up for some people.
#398
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
perhaps. i'm just sayin' i've seen people do that. i just wrap from the bar ends up, personally. never been a problem for me
#399
Habitual User
Liked 8,342 Times
People do lots of things that don't make sense - LOL. That said, I'm an ends-up guy, too.
#400
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
