Addiction 2021.2
#4401
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,535 Times
#4402
BTW...Cicadas don’t really swarm like locusts. They mostly hang out in wooded areas, make of noise, mate and die.
#4403
Liked 10,163 Times
#4404
Klaatu..Verata..Necktie?
Liked 13,203 Times
I got adapters so I could use clipless pedals on the Lotus instead of the Dyna Drive clip-and-strap pedals, because they're really designed for old fashioned slotted cleat cycling shoes not tennis shoes. Because the platform of the DD pedals is BELOW the pedal spindle, it effectively lowers the bottom of the pedal stroke, which allows/requires you to set your saddle lower. Even so, because my legs are longish for my height, I was near the max extension of the Dura Ace EX seatpost it came with. Once I installed the adapters and the clipless pedals, the bottom of the pedal stroke is now 1-2 cm HIGHER, and because they're 170mm cranks, the saddle height needs to be raised accordingly. And I ran out of seatpost. I tried it with clipless and the seatpost as far out as the mark, but it felt really funny. So I ordered a new, longer seatpost. It's now installed and really, I only raised the saddle about 1 cm. HUGE difference! Before, the bike felt REALLY twitchy, especially at lower speeds. Now it feels much, MUCH more stable. Riding hands off is no problem, but it still changes direction easily to dodge rocks and potholes.
The brakes are much better with the pads stolen from the Ritchey (which got even better pads in exchange), but braking from the hoods is still not great. The same 'squeeze' in the drops gets a lot more braking. I conclude that Shimano did not expect serious braking to be done from the hoods, so they didn't give you much leverage there. I'll have to get used to that, and while they're still not as good as dual pivots, and not even in the same league as disks, they're good enough for all my rides except the big climbs, but the available gears already mean I won't go up those, so i don't need to worry about going down.
The tubular tires, run at the SRAM calculator's recommended 105/110 (they're only 22mm, after all) never tossed me out of the saddle, even while it felt like I could read the manufacturer's name off manhole covers I rode over. Curious what 25 would feel like, but it's not worth the expense.
#4405
Liked 13,203 Times
So, 39 miles on the slightly revamped Mrs. Peel. I finally feel like this bike can be ridden like a bike, not a big toy. So, she's earned her place in the stable.
Requisite pic at Frenchman's Tower, along Old Page Mill:
Likes For genejockey:
#4406
Mostly Harmless
Bikes: Have two wheels
Liked 4,937 Times
#4407
Mostly Harmless
Liked 4,937 Times
Likes For rjones28:
#4408
Mostly Harmless
Liked 4,937 Times
#4409
Mostly Harmless
Liked 4,937 Times
Strava from one of the shop guys. Caz Icebender | Ride | Strava
#4410
Silver Comet Fred
#4411
Liked 10,163 Times
Likes For big john:
#4412
Silver Comet Fred
You can't easily gage how much toilet paper someone has but you can require an 8 gallon MINIMUM at the pump. Any less than 8 gallons pays the 8 gallon price. That'll stop/deter the people (cagey types to appease velo vol) from buying when they don't need it.
#4413
Mostly Harmless
Liked 4,937 Times
The gas can for my mower only holds 6 gallons.
#4414
Bikes: everywhere
Liked 8,535 Times
#4415
Bikes: everywhere
Liked 8,535 Times
#4416
Bikes: everywhere
Liked 8,535 Times
I ate lunch at a park today and a nurse sat in her Jeep with it running for a half hour while she ate her lunch.
#sorryeastcoasters
#sorryeastcoasters
#4417
Bikes: everywhere
Liked 8,535 Times
Location not known on this one, feel free to assume it's Florida also
#4419
Mostly Harmless
Liked 4,937 Times
#4420
Bikes: everywhere
Liked 8,535 Times
#4421
Bikes: everywhere
Liked 8,535 Times
#4422
Mostly Harmless
Liked 4,937 Times
#4423
Liked 5,580 Times
#4424
VFL For Life
Bikes: Velo Volmobile
Liked 2,064 Times
#4425
VFL For Life
Liked 2,064 Times
