Show Your Vintage MTB Drop Bar Conversions
#4826
#4827
Yeah, paid a bit more than I wanted, but it was cheaper than buying from On One...their shipping rate is too high for my taste. It is supposed to arrive next week...can't wait to get it built up.
#4828
The On One Midge drop bar arrived earlier than scheduled, yay!. I finally got the build completed on my 87 Schwinn Cimarron 18". The weight came in at exactly 24.0 lbs. It's been raining, so the first test ride will have to wait.
#4830
#4831
I expect your Cimarron will fly like the wind at 24 pounds.
Enjoy.
My faded red 23" Cimarron frame with broken rear seat stays is lanquishing in the garage awaiting a trip to the local frame builder to repair.
If I could build it to 24 pounds I would be more motivated.
Did you pic parts for it based on a lighter weight goal?
As I recall a few other Cimarron owners achieved builds in that weight range or even a pound or bit more lighter.
With my current project ,an aluminum frame mtb, which is the lightest frame out of about a dozen or so rigid mtb's I have experimented with,
will hopefully be my lightest mtb build to date. I was hoping for the 25 pounds range.
#4832
Jedi Master
#4833
While reading through the forums, I got bit by the drop bar conversion thread . And then a second project started to replace my current commuter with a drop bar that can possibly do a dual role of CX and commuter duties. I started to look for parts to start the conversion. I have decent MTB parts bin, especially since I had quite few donor bikes. But I had barely any road parts. Few weeks later, a CL ad came up for 18" Cimarron which is an ideal size for drop bar. I drove down 2 hours to pick it up...and that is the above bike.
I had 3 options on the frame/fork. The ETT on the 3 frames are roughly the same size. I weighed all three them. The weight of frame + fork + headset + bottom bracket for the 3 were as follows:
- Schwinn Cimarron 18" - 7.6 lbs
- 90 DB Apex 16.5" - 8.1 lbs
- 91 Specialized RockHopper Sport - 7.7 lbs
I was going to go with Cimarron even before weighing it, but this made it much easier choice.
My goal was to try to get it as light as possible with the parts that I had on hand. If you look at the components, they are not anything special. For example, the rear cassette is 7 speed 13-34T that weighs 1/4 lbs more than my 9 speed XT cassette. I used lighter 9 speed XT rear derailleur that I was saving for another project since the Deore DX rear derailleur has issues dealing with 34T, the max capability on that is 32T. However that being said, I did pay special attention to small details. I went with wheelset from 94 DB Apex over the DX wheelset as it weighed about 100g less. The Deore LX crankset was chosen over XT crankset as it weighed 30g less plus I like the touch of black, etc...
Once I start adding racks and fenders for commuter duties, all that is moot. For now, I am going to enjoy the CX.
I think 25 lbs is easily doable if you watch the weights on the wheelset, tires and tubes. Good luck.
For your reference, here's the parts list on the build:
[TABLE="width: 562"]
[TR]
[TD][/TD]
[TD][/TD]
[TD="align: right"]24.08[/TD]
[/TR]
[TR]
[TD]Components[/TD]
[TD]Model[/TD]
[TD]Weight (g)[/TD]
[/TR]
[TR]
[TD]Frame & Fork[/TD]
[TD]1987 Cimarron Cro-Mo DB full/ Cro-Moly
[/TD]
[TD="align: right"]3439.3[/TD]
[/TR]
[TR]
[TD]Bottom Bracket[/TD]
[TD]Shimano Deore XT BB-M730[/TD]
[TD]incl[/TD]
[/TR]
[TR]
[TD]Shifters/Brake Levers, Right[/TD]
[TD]Shimano RSX 3x7 brifter (used)[/TD]
[TD="align: right"]260[/TD]
[/TR]
[TR]
[TD]Brake Levers, Left[/TD]
[TD]Cane Creek SCR-5 Brake Lever[/TD]
[TD="align: right"]142[/TD]
[/TR]
[TR]
[TD]Brakes, Front[/TD]
[TD]Shimano Deore XT BR-M730 cantilever, cable adjuster with round straddle carrier[/TD]
[TD="align: right"]166[/TD]
[/TR]
[TR]
[TD]Brakes, Rear[/TD]
[TD="align: right"]168[/TD]
[/TR]
[TR]
[TD]Brake Pads[/TD]
[TD] [/TD]
[TD] incl
[/TD]
[/TR]
[TR]
[TD]Cable Adjuster, front brake[/TD]
[TD]Origin8 Brake Cable Hanger, 1", Silver[/TD]
[TD="align: right"]40[/TD]
[/TR]
[TR]
[TD]Cable Adjuster, rear brake[/TD]
[TD]Jagwire Pro Inline Adjuster, Indexed for Brake Housing - 5mm, Black ($12.95 for 2)[/TD]
[TD]incl[/TD]
[/TR]
[TR]
[TD]Cable Adjuster, front shifter[/TD]
[TD]Jagwire Pro Inline 4mm Bicyle Cable Adjusters ($10.83 for 2)[/TD]
[TD]incl[/TD]
[/TR]
[TR]
[TD]Cable Adjuster, rear shifter[/TD]
[TD]Jagwire Rocket II Adjusters, Black ($13.04 for 2)[/TD]
[TD="align: right"]0.5[/TD]
[/TR]
[TR]
[TD]Cable Yoke[/TD]
[TD]Cable Yoke, 10g each, Qty. 2[/TD]
[TD="align: right"]20[/TD]
[/TR]
[TR]
[TD]Cable, Transverse Brake[/TD]
[TD]Transverse Brake Cable, 8g each, Qty. 2[/TD]
[TD="align: right"]16[/TD]
[/TR]
[TR]
[TD]Cable Housing, brakes[/TD]
[TD]Shimano XTR brake cable housing, Grey (used)[/TD]
[TD="align: right"]54[/TD]
[/TR]
[TR]
[TD]Cable Housing, shifters[/TD]
[TD]Jagwire 4mm Derailleur Housing w/ L3 Liner[/TD]
[TD="align: right"]48[/TD]
[/TR]
[TR]
[TD]Cables, brakes[/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]Cables, shifters[/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]Cassette[/TD]
[TD]Shimano CS-HG50 13-34T 7-Speed Hyperglide Cassette (new)[/TD]
[TD="align: right"]412[/TD]
[/TR]
[TR]
[TD]Chain[/TD]
[TD]KMC X8.99 Bicycle Chain (1/2 x 3/32-Inch)[/TD]
[TD="align: right"]314[/TD]
[/TR]
[TR]
[TD]Cranks[/TD]
[TD]Shimano Deore LX FC-M560, 175mm, Black, 46/36/24 (BCD 110/74mm)[/TD]
[TD="align: right"]700[/TD]
[/TR]
[TR]
[TD]Derailleur, Front[/TD]
[TD]Shimano XT FD-M730 (from 87 21" Cimarron)[/TD]
[TD="align: right"]112[/TD]
[/TR]
[TR]
[TD]Derailleur, Rear[/TD]
[TD]Shimano XT RD-M771 SGS (new)[/TD]
[TD="align: right"]238[/TD]
[/TR]
[TR]
[TD]Derailleur Adjuster, Rear[/TD]
[/TR]
[TR]
[TD]Grips[/TD]
[TD]N/A[/TD]
[TD="align: right"]0[/TD]
[/TR]
[TR]
[TD]Handlebar[/TD]
[TD]On One Midge Dirt Drop Bar Silver, 31.8mm[/TD]
[TD="align: right"]278[/TD]
[/TR]
[TR]
[TD]Handlebar tape[/TD]
[TD]Cinelli Cork Tape[/TD]
[TD="align: right"]52[/TD]
[/TR]
[TR]
[TD]Headset[/TD]
[TD]Tange G Master[/TD]
[TD]incl[/TD]
[/TR]
[TR]
[TD]Headset Top Nut[/TD]
[TD]Tange -Seiki Levin CDS 1" Steel top nut Silver[/TD]
[TD="align: right"]18[/TD]
[/TR]
[TR]
[TD]Headset Spacers[/TD]
[TD]1-10mm & 1-5mm 1-1/8"[/TD]
[TD="align: right"]10[/TD]
[/TR]
[TR]
[TD]Pedals[/TD]
[TD]Suntour XC Pro pedals WTB Grease Guard[/TD]
[TD="align: right"]302[/TD]
[/TR]
[TR]
[TD]Saddle[/TD]
[TD]Terry Men's Fly Ti Saddle (used)[/TD]
[TD="align: right"]244[/TD]
[/TR]
[TR]
[TD]Seatpost[/TD]
[TD]Suntour XC seatpost, 26.4, cut down to 239mm[/TD]
[TD="align: right"]268[/TD]
[/TR]
[TR]
[TD]Seatpost Collar[/TD]
[TD]Shimano Deore XT SQ-M730 Seat Post Quick Release[/TD]
[TD="align: right"]80[/TD]
[/TR]
[TR]
[TD]Shifter, Left[/TD]
[TD]Shimano Dura-Ace SL-BS77 3-speed Bar End Shifter[/TD]
[TD="align: right"]82[/TD]
[/TR]
[TR]
[TD]Stem, Threadless Adapter[/TD]
[TD]Profile Design Threadless Size Converter ( 1- 1/8-Inch)[/TD]
[TD="align: right"]156[/TD]
[/TR]
[TR]
[TD]Stem[/TD]
[TD]Origin8 Pro Fit Alloy Ergo Stem, 1-1/8" x 31.8 clamp x 35deg x 90mm, Silver[/TD]
[/TR]
[TR]
[TD]Tires, Front[/TD]
[TD]Schwalbe CX Pro Cyclocross Bike Tyre, Black, 26 x 1.35[/TD]
[TD="align: right"]394[/TD]
[/TR]
[TR]
[TD]Tires, Rear[/TD]
[TD="align: right"]396[/TD]
[/TR]
[TR]
[TD]Tubes[/TD]
[TD]Forte MTB Presta Tube 26 x 1.1-1.4", 112g[/TD]
[TD="align: right"]224[/TD]
[/TR]
[TR]
[TD]Wheel, Front[/TD]
[TD]Shimano STX Parallax, presta, 32H[/TD]
[TD="align: right"]862[/TD]
[/TR]
[TR]
[TD]Wheel, Rear[/TD]
[TD="align: right"]1085[/TD]
[/TR]
[TR]
[TD]Wheel Skewer, Front[/TD]
[TD]Shimano skewer[/TD]
[/TR]
[TR]
[TD]Wheel Skewer, Rear[/TD]
[TD="align: right"]86[/TD]
[/TR]
[TR]
[TD]Bottle Cages[/TD]
[TD]Blackburn Chicane Bottle Cage (44g each)
[/TD]
[TD="align: right"]44[/TD]
[/TR]
[/TABLE]
#4836
The new VO dirt drop stem would look awesome on that bike.
#4837
I still have Salsa Cowchipper bar on backorder. I have heard good things on the Midge bars, so I am going to give that a try for now. Just riding around the block it feels good so far, but I will see how it feels after a few rides.
#4838
Jedi Master
How's the brifter working out? Seems like you could save a little weight going to a rear bar-end shifter, and you would have the aesthetic advantage of matching brakes and shifters. Your current setup looks a little hillbilly, which is cool if it works for you. I like having bar-end shifters on my dirt drop since I spend most of the time riding in the drops.
#4839
#4840
This 1986 Stumpjumper has been shown in this thread before, last time I believe about a year ago. I bought the stripped down frame a few years ago, had it powder coated and added my preferred components. It may be the only Stumpjumper with down tube shifters! Had the fittings brazed on before powder coating. The fenders are Velo-Orange Aluminum 650B ones. Couldn't find any nice 26" fenders. Lately, I installed a right hand Suntour Command shifter. Attempted to get it to work with the Shimano rear deraileur and cassette but just couldn't get it to work reliably. Thinking that I might put the Suntour Command shifters on a Panasonic MC5500 frame with all Suntour drive components soon.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#4842
Here are some photos from the dirt ride:
Climbing up the steep fireroads. Two of my buddies had to push their bikes up
Finishing up the ride and the view of the lake.
#4844
I just finished this yesterday. It's a 1993 Rockhopper frame. This has WTB Dirt drops, Cane Creek SC5 levers, and Dia-Compe shifters. Naturally I had to replace the stem also. I've only put a few miles on it but already I'm loving the handling - very precise, stable, and in-control. And I had forgotten how much I prefer friction shifting over indexed.
#4845
Liked 635 Times
[TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
Yes. Nice frame, but I think you need a bigger one
#4847
#4848
Bikes: Brompton H6, Schwinn Mirada, Cruzbike Sofrider. Used to own: ICE B1, 2 F-frame Moultons, Koga Myata Elevation 5000 mtb, Challenge Hurricane, Riese & Mueller Birdy Silver, Actionbent Tidalwave 3
#4849
It's powder-coated. I originally intended a "British Racing Green" in standard gloss finish, but I when I saw this finish on a sample, I decided to try it. It's actually textured. I joke that it won't slip out of my hands if I have to carry it up the stairs in the rain. My only concern was that it would pick up dirt compared to a gloss finish, but that has not been the case and it actually hides normal ride grime better than a normal finish. And it's very tough. Only downside is that you can't put decals on, but that wasn't important to me. Here are some close-ups when I first got it back.
