Wheel Spoking Pattern
Quoted: 5964 Post(s)
Liked 2,873 Times
And yet, some high profile wheel manufacturers defy logic by doing exactly that. The only time I will build like that is if I am supplied with a straight pull hub which does not give you the choice of lacing pattern or spoke orientation.
I have seen several Zipp straight pull hubs with drive side radial with broken flanges, including this one that exploded right in my truing stand.
FWIW - when I first started building wheels 55 years ago, race wheels typically used 15g DB spokes and lighter rims that what's trendy now, Some time in the seventies or eighties, focusing on tension and using heavier spokes became trendy. That made spokes stronger than rims, and lead to rims getting heavier in response. Those stronger spokes at higher tensions lead to higher rates of hub flange failures.
It's important to think of wheels as a structural system, where the various elements work as part of the whole. Changing a single element changes the system, and can have negative effects on the other elements.
Required reading for all aspiring (and experienced) wheel builders. (LT 5 minute read)
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,873 Times
Later on, I'll try to find the poem --- The Deacon's Masterpiece --- on another site and change the link.
EDIT ---- it's now fixed
FB
Chain-L site
FB
Chain-L site
Insane Bicycle Mechanic
Quoted: 816 Post(s)
Liked 762 Times
With loose reference to the Brandt book, there would be only one real issue with such a wheel: Radial spoke tensions would work together to pull outward on the hub flange, while crossed spoke tensions largely oppose each other, with a resulting lower outward force. This is a problem for a 36-hole low flange hub (think classic Record low-flange) with very little metal between adjacent spoke holes. You could break a chunk of flange off along the spoke holes, like separating stamps. The consequences could be ugly.
Aside from that, the only consequence was postponing the next day’s ride while I built another wheel. I hate to think what could have happened if I’d been riding it when it let go.
Jeff Wills
Jeff Wills
I did exactly that years ago and it was ugly. I built a 36-spoke wheel on an OMAS hub, laced radially. When it came time to bring it up to final tension, all was well until it went BANG. I had shrapnel bounce off the ceiling and land in my hair.
"It's a fine line between absolute genius and sheer stupidity"
Don't worry about the hub flange failing on the NDS, the tension shouldn't be high enough to cause problems in most cases.
As I mentioned in post #4, check Sheldon's article on wheelbuilding. Read his comments about lacing patterns and situations that causes issues with radial lacing.
As long as your wheel is properly built and tensioned, leave it as is.
A potential problem is that the spokes may be of different lengths and so you would want to carry both spoke lengths to do a repair on the road.
Bikes: '80's Centerion Iron Man (purchased New) , ~'91 Specialized ($50 FaceBook Find), '?? Specialized Cross roads ($20 thrift Store Find)
Liked 18 Times
WHY?
As noted before, many of the arguments for atypical builds are nonsense, but that's equally true for those against.
If the wheel is OK now, I can't see a reason to take it apart.
In fact, many in my generation consider it bad Karma to intentionally destroy a wheel.
I suggest you continue to enjoy this wheel as is, despite any doubts. Worst case, it'll last forever just to spite you.
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,306 Times
Stolen from Facebook but this is a lacing pattern. Any ideas on what it is? (Hint: it’s science)
Stuart Black
Stuart Black
Fractal or new covid variant?
Liked 4,306 Times
Stuart Black
Stuart Black
Let me take some psilocybin and get back to you on that.
