Intrigued by this double chainring concept...
Quoted: 99 Post(s)
Liked 115 Times
I think it's an interesting idea. I'd draw a comparison with unicycling. We usually don't have changeable gears on unicycles, so our nearest equivalent is changing the length of the cranks: shorter cranks = more speed but less torque; longer cranks more torque but slower. Better quality unicycles have cranks drilled with 2 or even 3 holes. Therefore, instead of changing the cranks half way through a ride, you can move the pedals to the "short position" or the "long position". It takes a minute or two, job done, and it means you can ride fast along the road, then change to a more torquey "gear" when you reach the off road section. The idea is simple, robust, fairly cheap (a geared unicycle hub is incredibly expensive) and sounds wonderful.
In practice, I do not think I have ever swapped the pedals from one hole to another part way through a ride. However, I do choose the best position before my intended ride.
On my fixed bike, I have a flip flop hub and have never once flipped the wheel during a ride. However, I am aware that sometimes I choose my route within the limitations of the ratio that I have available. Maybe this idea would be a good compromise.
A "dinglespeed" with freewheel would have no appeal to me. I typically ride my 2 x 10 for many miles at a time without changing gear and treat it as a "selectable single speed." However, for fixed, the 2 x 2 approach would be worth considering.
Likes For Mikefule:
Likes For mihlbach:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I mostly ride my “dinglespeed” equipped with two chainrings and White Industries Dos freewheel on numerous off-road trails, some are flat while others are excessively hilly. I generally select my gear ratio to whatever is suitable Before the ride, but I can’t recall ever pulling out a wrench and changing gear ratios mid-ride. Having readily available gear options definitely broadens the capability of the bike and lets you plan rides that you might otherwise avoid due to not having the right gear ratio. It nonetheless still provides the SS experience while riding.
For even more options, I am currently also running an 18t freewheel on the flip side of the hub, which works with either chainring and gives me a couple of intermediate gears. These gears are all spaced closely enough that I can change gears and maintain a very similar chainstay length. Lately I have mostly been riding 40:18 on flattish dirt and gravel roads, but I have been yearning for more hilly singletrack so I will probably switch back to 38:19 soon.
In the winters, I usually remove the 18T freewheel and install a 16t fixed cog or 16t freewheel which provide me a more roadworthy gear of 40:16 (about 69-70 gear inches) that I use for commuting.
If you haven't seen it, I posted a link above to an older thread with a photo.
Oddly, my other singlespeed bike is a fixed track bike that has only ever had a single gear ratio, 49:17, and I have never felt the need to change it. Of course I only ride it on roads so there is less of a need for lower gears.
Likes For mihlbach:
Quoted: 284 Post(s)
Liked 313 Times
Thanks for the detailed reply. Very cool. And the bike I'm looking to set up similarly is a Cross Check, so, also a rim brake scenario. I wouldn't want to be futzing around re-adjusting the brakes every time I switched gears. You've given me lots to think about!
The dinglespeed concept really is brilliant. It keeps the axle in the same spot and without having to flip your wheel or adjust brake pads it makes a gear change super simple.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 459 Times
I love riding fix gear, I love riding hills. I'm in my 60s and have had chronic knee issues the past 40 years. 9 years ago I had a custom fix gear built that had a road style dropout but long enough to run any 1/8" cog I've ever heard of. (I now have from 12 to 24.) I've ridden 5 Cycle Oregons on it using a fix-fix flip-flop wheel and carrying a chainwhip.
Three years ago I set my Mooney up to ride the (canceled) Cycle Oregon with its promised 30 miles of gravel. But how to do the gears on a standard late '70s Campy horizontal dropout? Geeky engineer here. Multiple chainlines. I went with three. Made up a rather custom 110 BCD triple pushed as far in as a 38 tooth ring would allow. Had a "dingle" made using a 21 tooth cog as the core, flipping the 21 so the cog sits flush with the hub and cutting out the center of a 17 tooth and braising it to the 21 with a steel spacer. Dished a flip-flop wheel in a touch for the dingle. That kicked out the small cog a touch.
End result? I run a crankset of 46-42-38. Using a 13 tooth small cog gives me a 46-13 (96 high, 42-17 (67") level ground and a 38-21 (49") low. I can also swap out the dingle and screw on a 24 for a 43" low (very low for a fix gear on pavement) if I carry the chainwhip. All three cogs like up near perfectly with their respective chainwheel. Everything is rock solid 1/8". (A shout out for Izumi chains. $25 gets you a really good one. Lots of pin extension so driving and re-driving pins is easy and safe to do. No, not the quietest. Quiet and sweet shifting are closely related, I NEVER want to shift until I stop and pull the wrench out. EVER. So noisy Izumi chains and EurAsian cogs are up my alley. And EurAsian cogs, despite the name are made in the US.)
Yes, on both bikes, changing gears costs my a couple of minutes. Unscrewing cogs about 5. But - this is all fix gear. I ride it to get away from freewheels. Yes, fix gear internal hubs exist but I have never heard that they were up to hard riding. My Mooney has a drive train close to velodrome worthy in all three (very different) gears and the custom, with its Sugino 75 crankset, is fully velodrome worthy, just not a track bike at all.
Ben
Ben
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Quoted: 4875 Post(s)
Liked 4,041 Times
Likes For 79pmooney:
