New Chain Skips On Freewheel
Now, I need time to work on the bike. I plan to ride tomorrow, so it has to be in the morning.
Quoted: 1972 Post(s)
Liked 2,083 Times
This is a funny thread.
Likes For Classtime:
Quoted: 95 Post(s)
Liked 50 Times
^ - This. They wear together. Most of the time you have to replace the freewheel when you replace the chain. I have only had one of my vintage bikes not need a new freewheel after a new chain. That tells me the bike hadn't been ridden much before it came my way.
Likes For Trueblood:
Alternatively, I have never before had this happen. To me, this is a puzzle.
Quoted: 2614 Post(s)
Liked 3,149 Times
Casual riders with 2x or 3x cranksets often do the vast majority of their riding on flat or nearly flat terrain with the chain on the small or middle chainring and on the smallest one or two sprockets in the back. That's a recipe for wearing those smaller sprockets out. Bike shop mechanics get used to such riders complaining that their cassettes wear out rapidly, the sole symptom being the chain skipping in the smallest sprockets.
Liked 2,083 Times
Quoted: 95 Post(s)
Liked 50 Times
But it is happening now, correct? I think folks are trying to provide a solution for you. I would think replacing the freewheel would be easier than messing with the chain links. Yes, I have a chain tool, and have used it for tight links, etc., but I would think fiddling with the links too much would cause more trouble down the road.
Similarly, I have several near-new freewheels in my junk box. I also found some chains in there.
I have lots of easy to implement options, all on hand.
It's just that I LOVE TO FIDDLE.
Quoted: 937 Post(s)
Liked 1,339 Times
Well, it's true that they do wear together but you only need to replace both the freewheel and the chain if you let your chain wear too far beyond limits, which wears the cog teeth so that they are incompatible with a new chain. If you measure your chain regularly and change it whenever it exceeds 0.5% elongation (12 links measure >12-1/16") your freewheels will last a very long time. If you let things go much longer than that then you will ruin the freewheel (and possibly chainrings) so that a new chain will skip.
Likes For davester:
I just got back from my ride using the old chain (Regina Oro). It shifts well and did not skip even a single beat.
When under load, it sounds like it was trying to change gears. It didn't but it sounded like that. Under light loads, it sounded as if it was not quite in gear and no amount of fine tuning would quiet it down. When I looked down, it always looked as if it was a bit askew from the cog.
My next step is to investigate the derailleur and jockey wheels a bit further. Under static conditions, the derailleur body is not loose in any way.
Quoted: 3466 Post(s)
Liked 2,839 Times
I have retired two Regina Record Oro chains- in succession, the same malady- they do not skip but there is too much limberness- the chain deflects “ twists” for lack of a better term when shifting.
quite annoying.
the Record Oro has narrower side plates, that probably does not help longevity.
these were not meant to last that long.
quite annoying.
Liked 3,149 Times
Quoted: 4867 Post(s)
Liked 4,027 Times
Exactly. If you can see it, that FW was very worn long ago. Now, you can run quality chains on the same FW for a very long time, especially if you are good about using all the cogs and not just staying one or two, but when it does come time for a new chain, you will have to replace the chainrings too. (1/8" of chain stretch and a ride-able bike is possible and some make it a point of doing it for money savings but for most of us, changing chains at 1/16" stretch and going 3-4 chains, then getting a new FW works pretty well and means shifting quality as intended.)
Likes For 79pmooney:
The noise was very gritty or grindy, not unlike a fracture ball bearing would sound. I believe I could even feel the grinding thru my feet. I wasn't sure I'd make it home. This is different than the chain skipping. This is why I thought the cahin needed replacement.
The drive train needs work before I can ride it again. Swapping freewheels and chains is easy. I can check the axle bearings when the freewheel is off. Inspecting the jockey wheels is easy. It's all easy, I just have no idea what it is or what I will find.
Le Crocodile
Quoted: 370 Post(s)
Liked 792 Times
I flipped some sprockets around once on a freewheel (new chain, old freewheel) to get me a working setup until replacements came in the mail. I swear I could not tell that it was excessively worn from a visual inspection, but "flipping" it sure got it to not skip anymore. It would only skip under power, but it doesn't take much of a mismatch to do so.
Liked 2,083 Times
I think replacing the FW to go with your new chain is preferable to using the old chain and soon needing to replace the chainrings also. Now, if this is a beater bike, don’t replace anything—put in your AirPods with some LedZeplin and just ride. 😉
Likes For Reynolds:
Quoted: 659 Post(s)
Liked 471 Times
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
FINALLY found there's a cure lurking inside barrel: there's a second spring tension hole you can set the coil spring's base pin into that boosts tension. That fixed my problem 100%! Took me 51 years to stumble onto that....
So then I swapped out the Campy DR in favor of a 'donored' Suntour long cage anyway when I upgraded' the five speed FW for the 'upgrades' where I bike now.
I inspected and disassembled the drive train.
1. The derailleur and pulleys look to be just fine - tight where they should be tight, free-spinning where they should spin.
2. The wheel bearings are smooth and tight with no lateral play.
3. The bottom bracket is tight in the frame and spins freely.
4. The freewheel was removed. The body is in fine shape, smooth, quiet.
I put on a different freewheel and the new IZUMI chain. I was able to ride up the hill outside my house with no skipping under load and the drive train was quiet. I will get a test ride in tomorrow, I've used up my free time for today.
Now for the fun part.
As I said earlier, yesterday's ride was sounding very gritty and I feel I barely made it home. I suspect this is why. I also suspect the cog was cracked during the previous chain slippages, some of which were brutal, then the piece fell off during yesterday's ride.
I added this picture trying to show more of the tooth profiles. I measured the width of several teeth at their very tops. New and old cogs on several different freewheels all measured about 0.130" +/-0.005". These teeth measure 0.135".
Any thoughts?
Any thoughts?
It's time to buy some replacement cogs or even a whole new freewheel. I have a lot of freewheels in my kit but this one was my favorite and most used - 14-16-18-21-24. It is a Suntour Pro Comp.
Quoted: 4584 Post(s)
Liked 1,730 Times
I have several brand new old Suntour freewheels in storage. Want me to check?
Quoted: 7397 Post(s)
Liked 2,566 Times
@Bad Lag, please listen to experience. I've had this happen dozens of times because I was a professional bike mechanic for several years. Effectively, I have the experience of thousands of cyclists. Others here have seen this, too. We know the cause, and we know the solution, and I think you would do well to pay attention. This thread has so many complicated theories and esoteric procedures that I don't think help. You often have to change the chain and freewheel together. You may not have needed to until now, but now you do. Accept that, change the freewheel, and learn a lesson. It's not that complicated. The wear may not be visible, but it's there.
