Will a gravel tire slow me down?
The Moose
Bikes: 2016 Giant Roam 2, 2004 Norco Torrent, 1969 Raleigh Grand Prix
Quoted: 108 Post(s)
Try an APP called Trailforks. Or use their website. It has a decent portfolio of trails that will be in your area, if of course anyone has listed them.
Quoted: 7397 Post(s)
Liked 2,572 Times
I'm not all that experienced at off-road riding, but I don't see how knobs on your tires help with rocks and roots. Knobs are for grabbing in slippery stuff like sand and mud and snow. My gravel roads -- the "carriage roads" in Lake Minnewaska State Park Preserve in NY State -- have pebbles up to about golf-ball size, for whatever that's worth. If my tire goes over a pebble, either the pebble jumps out from under me (not common) or my tire goes over it.
Why don't you try it before deciding what you need? Equipment matters less than skill, and you acquire skill with time.
As an example, I have a pebble driveway at home. On the 32mm tires I can only go a few metres before the bike slips or slows down too much. Even with 35mm tires (on a different bike), I can ride over the pebbles successfully.
Liked 2,572 Times
Yes you will like wide tires and low pressure.
Quoted: 185 Post(s)
Liked 38 Times
I currently ride on 700x32c Bontrager H5 tires, which are fairly tough with a shallow tread. These have OK grip and rolling resistance if pumped up to >65psi.
I am considering getting some wider tires that would be suitable for both road and gravel - something in the 35-40mm range (for a Trek Crossrip). This could them become both my commuting and general-purpose touring / gravel bike (the 32mm tires feel too stiff and thin off-road).
Given that gravel tires typically have deeper tread or smallish knobs (e.g. Schwalbe G-One), would I be likely to notice any difference in rolling resistance or effort required, when used on pavement?
Any recommendations for this kind of dual-purpose commuting/gravel tire?
Many thanks!
John
Many thanks!
John
I've ridden plenty of gravel on slicks to chunky knobbies, and it's the lower tire pressure, supple tire wider tread that seems to make the most difference to me.
Liked 2,572 Times
I find Jan's reasoning to be entirely convincing. I hope to be able to try tires like that on gravel, but in the meantime, I'm riding tires that are very similar but just a bit narrower. Not only do I have the Pasela tires, I have some Grand Bois tires, also made by Panaracer. They're lighter than the Paselas. They've been nice on smooth roads, rough roads, and gravel.
With those light tires, there is a chance of a sidewall cut, but it's small. If you think you're taking a risk of being unable to pedal home, carrying a spare tire isn't a burden, since they're light and easy to pack. But I don't carry one.
Bah, humbug... Here is my scientific test... For about 8 years I have been going down this hill on the same bike the same size/type of tires (2" mountain bike tires), and 52KM/Hr was the fastest I ever did it, I tried to better that speed for hundreds of rides down that hill... NOPE, Then one day after I came home from a tour I had narrower tires on that I put on for the tour I just finished and (1.5" road tires) and WOW, I went down the hill at 54KM/Hr, I was shocked that it made that much difference so the next day I did it again, this time going for gold, and... 56KM/Hr.
So Yea, a gravel tire will slow you down some, I am still going to go with the old ways of thinking.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,500 Times
What's the tread difference between the 2" mtb tires and the 1.5" road tires?
What'st the pressure difference as well?
I'd be very very interested to see data gathered by you for successive no-pedaling roll-down tests with tire pressure dropped at, say, 2psi increments (decrements)
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,500 Times
Yeah, the difference you're seeing is from knobby tread vs smooth tread. I'm surprised you only gained 2kmh. Now what you want to do is decrease your road tire 2psi at a time and watch your speed increase as you enable the tire to isolate more and more vibration from the frame and your body.
Those tires (pictured) seem very different to me! I'd also be interested in seeing data for these experiments:
1) Same tire width with different tread profiles
2) Same tire width at different pressures
3) Different tire widths with same tread & pressure.
I know there's been a fair bit on research on (3), with a tendency for relatively wider tires at lower pressure (e.g. 28mm) even for pro racing.
What do people think of tire treads that have a smoother central strip with more knobs on the outside?
John
John
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,500 Times
It's a solid design. Almost all of riding (especially road riding) is straight ahead, so a tire with a smooth center strip can be relatively efficient on the road, yet side-knobs can give turning traction on softer terrain.
Quoted: 4560 Post(s)
Liked 2,804 Times
Both my bikes have tires with pronounced tread on the shoulders: Continental Speed Rides with knobbies; Michelin Protek Cross Max, deep chevron pattern tread. Both took a little getting used to, coming from tires with shallower shoulder tread.
It's not a huge adjustment, just be cautious at first and practice a few turns on pavement away from traffic -- a large parking lot, rural area, anywhere you don't need to worry about other vehicles while you're getting the feel of new tires.
The plus side is the traction in dry grass, stuff like climbing around levees or hilly open fields, pastures, prairie, etc. The side knobbies and tread seem to help more in those situations than on most gravel.
If you prefer more predictable behavior in all conditions consider something like Schwalbe Big Ones or G-Ones, which have a shallow file tread all across the tire, including the shoulders. Ditto, Maxxis Hookworms (26" only, IIRC), Michelin Protek Urban, and many similar tires.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
Quoted: 1186 Post(s)
Liked 289 Times
You might see a small difference but it's not enough to worry about. I normally use 28mm GP4000s on my winter bike but recently tried a set of 40mm Schwalbe G-Ones on some gravel rides. I left them on for commuting and did a few excursions onto trails on the way home. My normal commute time is around an hour and it seems about the same, perhaps a couple minutes slower, with the G-ones. I commute on mostly smooth roads but still like the fat tires. I think I'll leave them on and see how long they last.
Sunshine
Quoted: 11073 Post(s)
Liked 7,643 Times
My question was intended to ask whether gravel tires will slow me down on pavement - I wasn't very clear! My idea was fit some wider tires to my commuter, so that I can use it on smooth off-road tracks, such as gravel on the weekends. If this is too much of a compromise, then I'd need to consider an N+1 gravel bike :-)
John
John
My time was within 2 minutes of what i did on thirsday with one of my road bikes.
I wasnt pusbing to set some record, just consistent riding. I feel no slower and dont find i exert more energy.
Barrettscv
31
05-08-19 04:27 AM
mack_turtle
23
01-28-18 10:16 AM
jcivic00
5
06-05-17 07:47 AM
johngwheeler
19
04-28-17 08:11 AM
tomazo
7
12-27-16 08:00 PM
