BQ: Disc Brakes "Not Mature Tech"
Thread Killer
Liked 1,841 Times
Yeah, knowing Heine/BQ, you don't need to read the article to know how they're going to fall or what they're going to b*tch about. Talk about mature tech...those guys are over the hill.
I believe they may mean removing the wheel. I think it was Team Roompot who tested them in the Eneco Tour a few weeks ago. They ended up just switching bikes when a rider had a flat because changing the wheel took too long.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Liked 2,812 Times
Jan Heine, who runs that magazine, is using an older rando bike with centerpull brakes and he has a preference for performance....and I'm sure his braking is totally solid. Older stuff like centerpulls are awesome.
I'm not at all sold on disc brakes for a road bike and have found rim brakes are perfectly fine. Of course they aren't mature tech for the road though...they haven't been out all that long and they haven't been widely adopted.
There's a cool picture in an earlier issue of BQ testing rim brakes where the rear tire is a foot off the ground. The tester said it looked scarier than it was; the bike was surprisingly easy to control with the rear wheel airborne. How much more braking power do you need on a single bike if your current brake can throw you over the handlebars?
Maybe they should be comparing rim and disc brakes on a tandem.
pluralis majestatis
Bikes: a DuhRosa
Liked 5 Times
A bit refreshing from the fawning of other publications -- when have you ever read a negative review?
"This frame is light and rockets off your feet"
"This frame is heavy but gives the feeling of sturdiness and durability"
"The top grade dura ace groupset provides impeccable shifting"
"This sora groupset is not as pretty or light as the upmarket equipment, but functions exactly the same"
**yawn**
Vain, But Lacking Talent
I can see the "not mature tech" argument in terms of industry wide standards (but in that case, pressfit BB's aren't mature technology), but who needs anything better than Shimano hydraulic discs? Those things are friggin' awesome. Not that they won't improve, but carbon-ceramic rotors? That seems like a bit much. That's basically F1 and MotoGP tech. The majority of cars being produced and manufactured as we speak use steel rotors, and would you call a brand new car an immature technology?
Thread Killer
Liked 1,841 Times
Jan isnt entirely retrogrouch for the sake of being retrogrouch (a la Grant Peterson). He wears tights, uses clipless, and while advocating fairly large tires, still favor fairly light versions of them. He doesn't endorse or market his wares as race-appropriate... and atleast has justification for his choice of gear. (although I think top-routed brake levers are utter rubbish for ergonomics and function).
**yawn**
**yawn**
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,037 Times
Shimano MTB parts are adapted for road bikes and are in no way mature.... Waiting for some company who is willing to spend the R&D for a true ground up design exclusively for road bikes.
Liked 1,461 Times
In general, people should avoid buying "immature" technology.
That things "don't always come about in linear fashion" has no relevance (no one is talking about how new technology is developed).
Liked 1,461 Times
But this somehow only applies to road? I knew MTB'ers or other non road riders weren't actually using their brakes hard! It must have something to do with loose surfaces, the need for extremely precise braking to keep front traction and enough power not have cramping hands after every small hill... I guess if I wanted to brake hard on my MTB i need to go back to Vee brakes...
BQ is talking about bicycling for long-distance Randonees and dirt-road riding. Not racing or mountain biking or downhill or touring.
Liked 1,461 Times
As mentioned earlier in the thread, hydraulic disc brakes for road bikes are not mature technology. The calipers and levers are making a ton of compromises and design choices that MTB did not have to deal with. I think road hydraulics will get better but most definitely will not be as good as MTB hydraulics since the shifting and brake mechanisms have to be incorporated into the same lever, unlike MTB where shifting and braking controls are two separate components.
Mechanical discs for road bikes are probably as good as they're going to get but they're making compromises over rim brakes that generally turn people off.
I''ll still take the review with a grain of salt. Jan has provided an excellet counterpoint to modern race-focused cycling but anyone who prefers & advocates threaded headsets in 2015 is suspect.
![Not Amused](images/smilies/brood.gif)
If they were studying wheels with standard dropouts and quick release skewers then maybe. There are cases where disc brakes have pulled wheels out of dropouts, I know one case went to court. The disc pulls the wheel in the direction of the open fork ends with a lot of force. I don't see how thru-axles would be a problem.
Disco Infiltrator
Liked 2,116 Times
"Afraid for my safety, I stop to let the (Shimano BR-785) brakes cool......
the brakes have stopped howling but the lever still bottoms out against the handlebars during hard braking."
BQ #53 Pg.40
BQ #53 Pg.40
Seriously, disk brakes for road bikes don't seem big enough. They ought to be bigger than the ones for MTB's because the speeds are higher, especially on descents. But the market wants them to look more delicate because they're for road and not MTB.
Genesis 49:16-17
Genesis 49:16-17
Bikes: everywhere
Liked 8,037 Times
I think the wheel ejection thing came from this..
Trek released a statement detailing how improper installation of a front quick release lever on the bike could lead it to get caught in the front disc brake, resulting in a separation of the front wheel and loss of control for the rider.
Another front wheel ejection fear stems from the fact that when applied, most front disc calipers want to push the front axle out of the dropouts. So if your skewer fails or isn't properly tightened (even if it's not the full-swing levers that the recall is concerning, even if you have leverless skewers) the wheel might eject.
You'd have to be going over some rough stuff (rough enough to unweight the front wheel intermittently), while applying front brake, with a broken or improperly tensioned skewer to even have a chance at wheel ejection.
Through axles will probably dominate disc braked bikes in no time, so chances of this type of ejection will drop from very slim to extremely slim.
Liked 1,461 Times
I don't think this is standard/universal yet. If it isn't, this could be part of why it's being characterized as "immature technology".
As for over-heating brakes, this isn't really a new issue. People over-heat rims and pop tires on a regular basis. I'd rather have the brakes start to fade and gradually degrade compared with a catastrophic front tire blow-out, due to the tire/tube over-heating.
I do think forks will ultimately need to support 180mm discs, especially for larger rides.
pluralis majestatis
Bikes: a DuhRosa
Liked 5 Times
Sounds like Tejon Pass... He should have shifted down to third to let the engine do the work.
Shimano R785 road hydraulic disc caliper failure - BikeRadar
" the rear Shimano R785 hydraulic brake failed on the road bike I was riding as I was descending from 12,000ft to 9,000ft on a -5% paved road in traffic. ....
The rear brake lever felt mushy for a minute or two, then lost all power. Oil had leaked out of the caliper"
Bikes: everywhere
Liked 8,037 Times
The MTB community has basically standardized on a 15mm thru axle (20mm for downhill bikes). The exact threading mechanism, etc is left to the fork manufacturer, but the hubs are all designed to accept a 15mm axle, so your wheels work with any fork.
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
BQ #53 Pg.40
BQ #53 Pg.40
