Cadence for large cyclists
Liked 9,456 Times
As my knees have been feeling better (less painful) over the last season, I’ve found myself dropping cadence and upping torque, because I can generate pretty good watts at lower RPM and keep my HR lower, saving the top end headroom for when I need to haul my tremendous mass uphill. When my cadence is high, HR runs higher, too, so even at moderate power levels, I’ll fatigue faster doing 98rpm than I will at 88rpm.
I'm a newer cyclist, but 120 rpm seems impossibly fast to maintain for a group ride for any significant duration.
I'm a big guy and my "natural cadence" is somewhere in the 85 rpm range, which gives me about 80 average over a 3-4 hour ride when factoring in longer hills (standing = lower) and ~2 minutes of coasting to a stop at lights or intersections per hour. This is for solo efforts. Group rides are a challenge to maintain any set cadence, as it's a lot of surges and coasting/soft pedaling in my experience when you're not at the front.
I've been working on maintaining a higher cadence outdoors closer to 90 rpm average and do find that I am a bit fresher saving the legs more that way at the end. Also need a touch less fueling. Indoors, I find I cycle at higher cadences (more like 90 average) for some reason than outdoors and particularly for large wattage efforts do find it easier to put out more power for longer spinning up to 100 - 105 RPM.
Thread Killer
Liked 1,840 Times
Hmm. I'm exactly the opposite. Sure, at light efforts, under ~75% or so, I'll spin slowly. Otherwise, I find that there's a cumulative muscular fatigue that builds more quickly with higher torque/lower cadence and I find that there's only so much that can be drawn from that well. For shorter rides, this isn't terribly problematic, but longer rides can get pretty hurty. The same power at a higher cadence does drive my HR a little higher, but I find that's something that I can recover from more readily, so no big deal. I'll save high torque efforts, regardless of cadence, for when they're needed.
Liked 9,456 Times
I was maintaing very low torque for awhile there due to my painfully swollen, arthritic knees, so without knowing what numbers we’re talking about here, I wouldn’t say it’s exactly opposite. I mean, yeah, you’re absolutely right that HR will recover faster than depleted legs, and that’s my experience as well, but I’m not talking about doing thigh-burning, 2hr rides here, but rather having the confidence that I can drop my cadence to 85rpm for a few minutes to aid HR recovery and still maintain Tempo level power, which is something I’d avoided doing for a long time simply because it hurt my knees. So, no, unless I misunderstood you, I think we’re on the same page that high torque/low cadence is fine for short periods, but doing the same power at higher cadence/lower torque is preferred despite the HR boost because yeah, I gotta save the legs/torque reserves to get up the hills in good enough time to stay in the mix.
Likes For WhyFi:
Riding my 42x18 single speed with the fast group increased my max comfortable cadence by like 25%. It sucked though I even injured my knee on the downhill once just by spinning.
edit: just did a 1 minute cadence drill and got 134 with a stopwatch. Not comfortable though
Expired Member
Another thought is that since you are on a single speed, lowering your cadence will lower your speed. Lower your speed and you'll drop off the back. Maybe they are trying a different approach to get you to stop crashing their rides.
Likes For shelbyfv:
Over the hill
Liked 1,259 Times
It's like riding a bicycle
just another gosling
Liked 2,005 Times
1. It's obvious that the OP does not normally spin 120.
2. Different ride parameters demand different cadences, i.e. cruising in the pack on the flat, pulling the line, climbing at various gradients, descending below your "too fast" speed, etc.
3. There's no right answer. I know local champions who normally use anything between 60 and 100 cadence on the flat.
4. Given #3, there's still no right answer. One can train to establish a different "freely chosen cadence." it's not that hard.
5. When going as hard as one can for say 20', it's easy to tell if one is using one's optimum cadence: If you're running out of legs, too slow. If you're running out of breath, too fast. But see #2.
6. Before posting something like this, know what you're talking about - buy a gadget with a cadence display and note your cadence under varying conditions, see #2..
Results matter
Results matter
![Roflmao 2](images/smilies/roflmao2.gif)
To the OP- the common sense in this may be elusive, but if you're spinning so fast you injured yourself, you're spinning too fast.
A bike computer with a cadence sensor would tell you what you are actually doing and when you correlate that to how you're feeling and how fast you are going, you can get information you can act on.
My cadence generally seems to be around 85-95 when going hard on the flat or 80-90 when going hard uphill, which is thoroughly conventional. When going easy it's lower.... but I'm not actually thinking about it - it just gets recorded. I'll just more or less subconsciously shift to an easier or harder gear. On some days I feel different and do the efforts at the same power in a different gear at a different cadence 🤷
It's like you have a crystal ball
this thread is the most classic type on this forum- completely indecipherable between bargain basement trolling and poorly thought-out question.
Likes For LarrySellerz:
I'm a masher. VERY slow cadence.
However, if one rides say 10 to 15 MPH, then cadence doesn't matter, and it is quite possible that slow cadence is more efficient.
As one increases the speed to say 25 to 30 MPH (or faster), then one eventually reaches a point where one can no longer produce adequate power at a slow cadence.
I.E. the max power one can sustain is somewhere around 100% of one's body weight as force on the pedals x the RPM (likely less than half the body weight per pedal). For short distances, one can increase power by standing up and pulling up on the handlebars, effectively increasing the downward force, but that is relatively inefficient. Pulling up on the opposite pedal helps some with both more force up as well as down on the cranks.
However, to keep increasing power, one needs to increase cadence... thus spinning.
he said member
Bikes: yes please
Liked 1,951 Times
Here's a guy with big legs who seems to think working on increasing his cadence is a good idea:
https://www.youtube.com/watch?v=a5PcQJF5Jl0
he said member
Bikes: yes please
Liked 1,951 Times
Likes For Badger6:
The whole "spin to win" thing doesn't work for me personally. I'm 165# and my rides typically come in at around 83 avg cadence. If I try to gear down and run a higher cadence I get exhausted more quickly. I don't have issues with injuries so I'll stick with my grinding ways.
42 x18 at 120 rpm is only 22 mph. Larry says this is a ride with Cat 1 racers. Something does not add up.
Likes For GhostRider62:
I don't think 83 rpm is particularly grindy, would be a bit low for me if I was really going all out or near it, but as an average over a ride it looks thoroughly normal.
Likes For Branko D:
Expired Member
Liked 9,456 Times
Likes For WhyFi:
Thread Killer
Liked 1,840 Times
My workout last night made me think of this thread:
10min Warm Up
3x:
5min L4 Threshold (90-100rpm)
5min L2 Recovery (90-100rpm)
2x:
5min L4 Threshold (80-85rpm)
5min L3 Tempo (70-80rpm)
5min Cooldown
A little bit of everything in that ride, yet none of my favorite 85-90rpm range! Those high cadence segments really had me huffin’ and puffin’, but I was getting the HR drop during the recovery segments, so I was able to push through the final 20mins at a low L4 average, which was super-solid.
I’m kind of amazed that I can do low cadence at those power levels today, because two years ago my knee pain was making it so hard, if not impossible (I don’t recall). Being a year off work and off my feet so much really allowed the arthritis which has haunted me for 10 years to settle down, and for my cycling to return to decent form. This past season was my best in four years, and great fun! I guess that’s nothing to do with cadence…sorry.
10min Warm Up
3x:
2x:
5min Cooldown
with a high cadence you can still sprint when your legs are dead at the end of a ride
Thread Killer
Liked 1,840 Times
Dead legs don’t sprint.
Likes For indyfabz:
