Bike Boom Gitane TDF Conundrum
Likes For Mr. 66:
Bikes: 2000 Serotta Hors Categorie, 1990s Lennard Zinn, 1985 Guerciotti Jet, 1975 Peugeot PX-10,
Liked 118 Times
Darn!
It’s a bummer to learn that even your AV 3 front derailleur’s plastic cracked.
If I use a surplus Record FD, should I expect flak for my Simplex RD?! 🤷🏿♂️
Liked 118 Times
Gitane TDF Update
I removed all of the parts-except the cranks-and the paint and chrome look pretty good, except for the driveside rear dropout that “went through a garbage disposal.” 😱
Does anyone have a source for the top tube “Service Course” decal? I looked at the Cyclomondo website and Greg Softley appears to have all of the replacement decals except that one.
Here’s another oddity: the top tube brake cable clips were supplied by Huret, NOT Simplex…🤷🏿♂️
Oh, and of course the front derailleur’s plastic body was cracked.🙄
Likes For big chainring:
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Liked 177 Times
I have three bikes with Simplex derailleurs, one set is all-alloy and the other two are mixed alloy-steel-plastic (Delrin). The rear units have all performed very well. My FD with a Delrin body cracked, and I replaced it with a humble-but-loveable (and all-steel) Huret 700, which works fine.
Shall you play the roll and keep it vintage, go with a Simplex LJ1000 rear with hanger. Yes, it has Delrin body but does have a steel parallelogram. These particular derailleurs don't break. Nor wear out like Campagnolo.
You girls can argue much as you like, but from my experience and having N.O.S. Campy NR and SR, the Simplex shift with better precision and smoothly. Ugly, yes.
Ps. Don't fall for some of the ebay overpriced sellers. Just search Simplex cycling. Often found in a multi parts lot. Though right now listed from a UK seller is a LJ1000 with hanger, sans pulleys for $22.
Likes For chain_whipped:
For the front derailleur, another option for reliability and giving a few in the Eroica circle a head scratch, convert the craplastic to a matchbox type aluminum. Paint it black, too. 8 gram difference.
^^(Forget about searching for one of these.)^^
'72 PX-10 w/ LJ1000 rear and DIY ally matchbox front mech. Bulletproof.
Liked 2,339 Times
If Simplex had used their same designs but built of aluminum all along, today we would all agree they worked much better than Campagnolo.
All of that said - this bike is going to be glorious. I have never ridden a TdF that didn't have that special something to it. And I note that yours appears to be a 60cm to top, and in the color I always lusted for. Why do I only find them in Omnium Vert?
Death fork? Naaaah!!
Top
Liked 118 Times
Thanks, Folks!
Thanks for all of the great tips & ideas.That green TDF is lovely. Random thoughts:
1) Point taken on the French pedal threads. I use Soma CDM (Citoyenne Du Monde) English threaded pedals on all my bikes. These 170mm cranks are too short, regardless.
2) I’m toying with finding a metal Juy FD from the pre Delrin era. It might be even cooler to find a “suicide” front derailleur. That will get them talking…
3) I have 1 or 2 “surplus” Campagnolo front derailleurs…🤔
Likes For repechage:
It seems to me that at least one of the THREE TdFs and TWO Super Corsas that have passed through my hands had Huret brake cable clips instead of Simplex. I think they just ran with what they had. I suspect Gitane got in the habit of substituting things partially because they were competing with the 800 lb gorilla of the French Veloverse, Peugeot. I don't recall EVER seeing a Peugeot with substitute standard parts, whereas Gitane TdFs turn up with the OP's Simplex ends (also used by Jeunet on their model 630), the classical Simplex with an integral hanger that usually gets tapped and filed on to create a stop, and a certain number with Campagnolo dropouts. Apparently, they also used Huret ends with a Huret-specific hanger for European-market bikes.
Gitane TDF
That's what I heard...I have Sugino and Huret on one of my TDFs, with a Campy Headset. All French threading. Of course who knows what it came with originally. It still had one of the original Tipo hubs.
Likes For marnar:
I have a 21" like this one. It appears to have all original parts including the Ideale saddle and setups. Going to keep it.
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Liked 389 Times
If it is a TdF and you do have a Campy headset, you may be playing with fire as the TdF’s steerer tube was cut for 33mm Stronglight headset and a Campy NR needs 40/41mm to purchase on sufficient number of threads. I’d measure the stack height to figure out what you should be using. Good news, if taller steerer tube, you might have a Super Corsa instead of TdF as Chas has been pointing out for years.
Liked 389 Times
Thanks for the info. I don't know much about the bike but I like it's ride. I'll measure for sure. Interesting, there appears to be plenty of threads on the steerer so I think I'm ok. I thought the Super Corsa would have Campy fork ends. Wish there was more information on Gitanes. This one clearly, or not so clearly, has Simplex. Perhaps a fork replacement over the years. The only stickers left on it are on the seat tube.
Likes For Markeologist:
Liked 118 Times
Gitane TDF Update(s)
Hi Folks,
I’ve been busy making some updates to the Gitane TDF:
1) Wheels. The bike came with Roval aero clinchers which are all wrong for the early 1970s time period.
I had a pair of spare tubulars that came with my 1974 California Masi GC. Campagnolo Record rear hub, Gran Sport front (36h F/R) with mixed Mavic & Wolber rims. I brought them to Charles Hadron of Wright Brothers Cycle Works.
He trued them and repacked the rear hub. The front hub had pitted cones & races. Charles had a friend (thank you Chai, if you’re on here🫡 bring by a 36h Record front hub & Charles relaced the wheel with the “new” hub and existing spokes.
Sacrilege maybe, but the rear hub was Italian threaded so I had Charles change the threading to English; I like to use modern (IRD/Suntour/Shimano) freewheels on my vintage bikes.
More to come and thank you for reading!
Jacob_R_59
I picked up the wheels yesterday. Chai very kindly provided the front Record hub and both skewers. 🎁
Jacob_R_59
Hi Folks,
Jacob_R_59
Jacob_R_59
Chai is an interesting guy. Haven't seen him much these last few years. I did see him at the bike swap but by the time I was finished a transaction he had disappeared. I don't think he's a forum member.
Good choice having Charles do that for you, he is pretty much the only person I would used for work beyond my knowledge or tooling.
Likes For Mr. 66:
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Liked 732 Times
Liked 118 Times
Skewers?!
I should have seen THAT one coming. 🙄 I’m going to remove the rim decals, polish the rims (and the rear hub) and get replacement decals from Cyclomondo (Greg Softley)
Likes For Jacob_R_59:
Liked 118 Times
Hub Threading Change
I don’t know how Charles did this. I’ll have to ask when the shop is open, and post back.
Jacob_R_59
Jacob_R_59
