Shimano RD Cable Keeps Fraying Inside Shifter
Quoted: 3260 Post(s)
Liked 2,572 Times
What happens to the shifter cable/housing when the brake lever is squeezed? Do they move fore/aft with that action? Are they stationary? Does that cause additional stress for the cable?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Obviously nothing or you'd end up w/ your derailleur shifting every time you braked.The brake lever pivots separately from the shifter.
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 477 Times
Quote:
Originally Posted by cxwrench View Post
Because changing a $4.00 cable once year is such a huge ordeal, right?
Yeah, that change-out is way too frequent. Hopefully you eliminated all other culprits.
Mine works out to about a once-per-year chore. It's far less about the cost than the time.
Although, come to think of it, I replace my bar tape every other time. That stuff is expensive.
Cxwretch: please tell me where to find the $4 high-quality cables.
Imagine you get for dealer cost, so send me a batch and I will repay you.
I honestly would not mind changing it once a year. I am chewing through 3/year which I think is a bit much. I read on another forum that there was a Shimano Service Bulletin that said change out cables every 1000 miles. That would solve my problem but NFW I am going to change a cable out every 6 weeks.
Bikes: lots
Liked 2,932 Times
Likes For BCDrums:
Quoted: 4231 Post(s)
Liked 3,940 Times
QBP lists Jagwire Sport SS shift cables (CA4444) for less than $4 dealer cost, these would typically retail for $5-$10 shop dependent. I suspect cxwrench doesn't use coated cables, as I don't too. Andy
AndrewRStewart
AndrewRStewart
Bikes: lots
Liked 2,932 Times
In that case we buy cables from QBP and our cost for SRAM is less than a buck when we buy a box. Shimano is a $1.50 so we sell both for $4.00/ea retail. Standard stainless steel cables. We sell Optislick for $8.00/ea. And this is in Marin County, so our labor prices are pretty high but we don't gouge people for product.
Thread derailleur
Quoted: 378 Post(s)
Liked 477 Times
Still, that's like $18 a pair for regular Shimano, non-optislik. (Those never work right for me.)
Oh well....part of the price to pay to patronize the LBS. Along with CO2's, tubes, lubes, and other smalls. lol
Old fart
Quoted: 3617 Post(s)
Liked 3,446 Times
The Experimental Aircraft people have a rule-of-thumb that in order to prevent eventual fraying of a control cable, any pulley/guide/direction change on a cable should have a radius at least 50 times greater than the diameter of the cable. I can't see that fitting inside a modern shift lever, and I suspect that's why Shimano makes those routine replacement recommendations. At least, failure of a shift cable on a bicycle isn't likely to be as catastrophic as a control cable failure on an airplane.
Likes For JohnDThompson:
Bikes: lots
Liked 2,932 Times
Damn. My local shop sure sticks it to me. Part of our discrepancy here is that I always buy in pairs.
Quoted: 858 Post(s)
Liked 1,093 Times
I am trying out these "Alligator- Superior Shine Slick Stainless" cables. Alligator Shift or Brake Cable Superior Shine Slick Stainless fit Shimano Sram | eBay They have thinner but more strands to fit Shimano and Jagwire housing and I'm hoping this may help them last longer. I only have about 2,500 miles on them now for my 6600 shifters and usually get 4-6K miles from the S or J brands so the jury is still out. Might be worth a try with yours. Shop around as prices have gone up a bit from this seller.
Quoted: 5899 Post(s)
Liked 2,765 Times
You may get varying life from various cables, but ALL cables will fray and break there because the problem is inherent in the design.
If you've ever bent a paper clip back and forth until it breaks you're familiar with the issue. As the cable winds onto and off the lever's curve, it's being bent and straightened. Eventually it will "work harden" and become brittle, after which strands will break over time. Folks who shift often between the same few gears are bending the cable in the same place and will see lower life than those who shift less often, or use a greater range of gears, but ALL cables will break this way over time.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 3596 Post(s)
Liked 3,016 Times
Liked 2,765 Times
Since cable life relates to shift count and not miles, that means we can expect less than 1/3rd the cable life if all other things remain equal. Factor the smaller pulley radius, and nobody should be surprised by short cable life.
FWIW, back in the bronze age I was using Campy bar cons with 7x7 wire rope cables. Riding 15k+ miles per year, I'd replace the cables every 2 years as preventative maintenance. No idea how long they might have lasted otherwise.
FB
Chain-L site
FB
Chain-L site
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
To be clear, I have had the same problem with Shimano shifters eating cables. Apparently the problem started in the 5700/6700/7900 generation when they started the under bar tape routing and the shifter wraps the cable very tightly inside the shifter. My 6800 road bike has internally routed cables which are a royal PITA to change. I was changing the rear shifter cable every 1500-2000 miles and even had one that only lasted for 800 miles. Finally at 10K miles, the rear shifter broke. I decided to switch to SRAM Force 22 shifters and derailleurs. The worst thing about SRAM is that the FD is tricky to set up correctly. Once I figured that out, it has shifted flawlessly.
Thread derailleur
Quoted: 378 Post(s)
Liked 477 Times
Good timing on this thread. I replaced my shabby bar tape and figured it a good time to replace the rear shifter cable.
DA 9000-series. 3k miles and the cable still looked fine. Swapped it out, nevertheless.
When those suckers go, they seem to deteriorate quickly. And usually around the 3k mark for me.
Oh, and for the first time ever for any generation DA STI, I got the cable perfectly set, without the need for adjustment!
No doubt, some of you hotshot wrenches routinely nail it.
Old fart
Liked 3,446 Times
I've had individual strands break on downtube shift levers, but not the whole cable. Possibly because the broken strands prick my fingers when I shift gears, alerting me to the problem before complete failure occurs.
Old fart
Liked 3,446 Times
Sock Puppet
Liked 863 Times
I usually get a one ride warning. The first thing that happens is that shifting suffers as strands break and you can't shift into the largest cog. No matter how you try and adjust the cable, you can't get it to play nice. At this point, time to turn around and head back to the start site unless the ride is super flat. I have always managed to nurse the bike back home without losing all shifting.
Bikes: a couple
Quoted: 563 Post(s)
Liked 869 Times
I suspect it may actually shorten cable life, as the slick cables are die-drawn after winding to create a smooth surface for the coating. This work-hardens the strands before the cables are even installed and suffer the useage work hardening @FBinNY notes in message #38, above.
It's the only thing that makes any sense.
Should Be More Popular
Quoted: 22690 Post(s)
Liked 9,036 Times
Quoted: 7084 Post(s)
Liked 11,189 Times
Method to My Madness
Quoted: 2039 Post(s)
Liked 1,534 Times
On my bike, I have to remove the BB cable guide from the BB shell in order to thread a replacement RD shift cable through the BB cable guide. In order to remove the BB cable guide, I have to disconnect both shifter cables. Which means that I might as well replace both shift cables at the same time, every 18 months or so.
Sock Puppet
Liked 863 Times
The first sign I usually get is a little finicky going into the smallest 2 or 3 cogs. I believe this is due to the burr-like nature of the frayed cable which increases resistance. That seems to be the first clue. The inability to go to the largest cog usually happens JUST BEFORE the break.
