Can I use 700x23 tube in a 700x25 tire?
Also, IIRC Gatorskins usually run on the narrow side for a 25mm tire, so there should be even less concern that you overstretched the tube.
Bikes: Specialized Sirrus, Giant Defy 1
Thanks for the responses. I probably did pinch the tube between the bead and rim as I was wrestling it on. I'll chalk it up as user error and try to exchange the tire for a new one at performance.
working on my sandal tan
Liked 2,600 Times
Wait -- is the tire itself damaged? Perhaps it was defective, or damaged during installation.
The tire did get damaged. The sidewalk blew out just as I was about to put the presta valve nut on. That's why I revived this thread to see if using an undersized tube will cause such a thing.
