How long does your DI2 battery last (12 speed groupsets)?
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
Shimano still outsells SRAM even in the top tier by orders of magnitude. My bike was able to communicate without issue so not sure what that is about and again most people take their bike to shops and get updates there.
lastly it really doesn’t look that stressful actually quite relaxing.
https://youtube.com/watch?v=mJZQhVFg...jnGA3DWHpcz6f8
For the update hassle, and unless Shimano finally found a way to make our life easier, it's not possible to update your 12sp shifters wirelessly. They need to wired to be updated.
I do my own maintenance so I don't bring my bikes to LBSs and don't want to pay 50$ for a piece of wire and an adaptor (it's just stupid IMO) so I'm not updating mine for now. Will see if I have issues at some point.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
Like most consumers, my Di2 bikes came from the shop with Di2 installed. If I was running a shop or building bikes from scratch, simplicity could be an issue, but from a consumer perspective, I just want a product that works, and Di2 does, the way I want.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 678 Post(s)
Liked 431 Times
That certainly doesn't explain the number of riders with Ultegra and Dura Ace at races, group rides, tours, etc.I don't think I've ridden an "entry level" groupset since the 1980s. When I got back into cycling in 2012, I test rode Shimano and SRAM, and picked Shimano because I liked the way it worked. That is the case with most of the folks I know who prefer Shimano. Nothing against SRAM, but it is possible to prefer one or the other simply because you like the way they function.
No, and it's a moot point for me. I buy my bikes fully assembled, and have no need or desire to go inside the frame. I've also never rebuilt the transmission on my car or had need of soldering chips onto my motherboard. I salute people who do those things, but it isn't necessary for me to do that if the device works as intended.
Likes For bbbean:
Liked 595 Times
If you're choosing a groupset only because it has no wire, then I don't need / want to argue with you. All I will say is: use a magnetic tool, it's as easy as fishing a brake line.
My beef against SRAM is the slow shifting FD and frequent chain drops. It's a big no no for me. If you don't know what I'm talking about by slow shifting, go try an Ultegra or DA DI2 FD and compare.
Quoted: 678 Post(s)
Liked 431 Times
You know what's really easy to install and maintain? Exterior cables and down tube shifters.For that matter a single speed does away with shifters altogether!
Likes For bbbean:
Even with a magnet tool, it's still a challenge. Building up a bike from parts is only a very small portion. My biggest issue was when a customer brought in a LBS bought bike with a Di2 issue. Usually it was just a wire that came unplugged from the shifter. But there were times when having to replace a wire that went from the battery to the rear derailleur. Those were the ones that drove me nuts.
While that is all true, modern bikes have complete internal wiring, cables, and brake lines as you already know. So anything ran internally is going to be a pain even with the correct tools (which I have). If I am able to eliminate internally ran wires and cables, that's what I'm going to do.
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 231 Post(s)
Liked 377 Times
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 397 Post(s)
Liked 327 Times
Interesting thread. I've been tempted to "upgrade" my Ultegra Di2 from 11 to 12 speed, but I've found too many reasons not to... and battery life is now another reason not to.
I personally prefer hard-wired components and a single battery. If I buy any more gadgets that require coin batteries, I'm going to have to buy stock in a battery company.
I built-up my own bike and don't feel that running the Di2 wires one time was much of a hassle, although I might think differently if I worked at a bike shop and did it daily. The only major disadvantage I see to hard wiring is the addition of wireless blip shifters, but my Di2 setup has a wireless module installed, so I'm assuming that could be "the best of all worlds" should I actually want wireless blip shifters.
Liked 595 Times
A lowered range does not bother me - I charge it every 2 weeks rather than every month. I started this tread to figure out if the average mileage I am getting out of a charge was reasonable since it was unknown territory for me.
For the coin-cell batteries inside the shifters, they are advertised to last 2 years, which is more than reasonable.
Quoted: 397 Post(s)
Liked 327 Times
https://bike.shimano.com/en-US/produ.../EW-WU111.html
Likes For PoorInRichfield:
Liked 595 Times
Yeah, I was aware of this module, but it was extra money I couldn't justify spending (just like I find that the 50$ wire needed to update my current 12spd shifters is total bullsh*t given the price we pay for our groupsets). It should have been OEM equipped from the start in my opinion, or at least only on Ultegra and DA groupsets.
Likes For eduskator:
And with regard to the original question that started this thread... I get several weeks (at least) between charges with my Ultegra and Dura-Ace 12-speed Di2 systems, and I ride 200-300 miles per week. Good battery life is a big reason why I prefer Shimano over SRAM. Having to charge those SRAM batteries every 20-25 hours would drive me nutz .
Liked 595 Times
If you're running 12-speed 105, Ultegra, or Dura-Ace Di2 you should be able to update firmware and customize shifting wirelessly through the E-Tube Project app on your phone. No cables required. The only caveat I will add is this: In the (rare) instance where a firmware update goes wrong, you will need a SM-PCE02 interface module to rewrite (and correct) the firmware as this function is not available through the E-Tube project app.
For the updates, you can't update your wireless shifters unless they are hard wired to the system.
Resident PIA
Quoted: 231 Post(s)
Liked 377 Times
Shimano is better than SRAM, period
Shad
67'er
Shad
67'er
Likes For Shadco:
Quoted: 4884 Post(s)
Liked 4,051 Times
Correction - not always. "For that matter a single speed does away with shifters altogether!" I have two fix gears with double sided hubs and flip the wheel frequently. Just like racers did 110 years ago/ Four, five (or a lot more) on the floor - down tube shifting. Stick shifting - using that hub wrench. Brifters - three to thirteen in the tree.
Liked 595 Times
On 12speed Di2 I bought a 1.6 meter $25 Di2 wire, I pop out the seat post and use the 3rd port on the battery and connect directly to shifter and update the shifters, no adapter required. When originally building I updated everything before installing the components on the frame.
Quoted: 678 Post(s)
Liked 431 Times
Likes For bbbean:
Liked 595 Times
Choosing a specific component because it's less difficult to install during a build < choosing a specific component because of how well it performs.
Liked 4,051 Times
Please read my reply in context. I was referring to the argument that setting up Di2 was more complicated than setting up SRAM. I was trying to make the point that as a rider, I was less concerned with the initial setup than I was the effectiveness in use. I wasn't trying to make an argument about the very simplest bike to setup. I suppose that would be no bike at all.
Quoted: 678 Post(s)
Liked 431 Times
No hard feelings perceived. I just wanted to clear that up before it became its own 748 post sub thread.
Several weeks @ 200mi per week = roughly 1000mi? That's huge. Do you ride flat or mountains? I am asking, since the numbers of shift per ride certainly affects the range.
As for the wireless shifters not connecting directly to E-Tube Project, I'm not thrilled about that. However, it's not a huge hassle, and you can work around that obstacle if necessary. Use of the SM-PCE02 module (if you have one) definitely makes it easier.
Likes For Turnin_Wrenches:
Liked 595 Times
I'm in Florida, so the flat terrain (e.g. less shifting) is probably a big reason why I don't have to recharge as often.
Resident PIA
Quoted: 231 Post(s)
Liked 377 Times
Yeah, I guess this works. I'm just not a fan of messing around with screws and components unnecessarily on my bicycle. If I would do this, I'd go through the front derailleur to not have to remote the seatpost. For now, I'm not updating them since I find it completely stupid to have to buy separate parts to update your bike (at least the accessories should be included when you buy the bike) and I hope they'll come up with a wireless fix soon.
Shad
67'er
Shad
67'er
Quoted: 10306 Post(s)
Liked 5,277 Times
Just got my SLR 7 with Di2. Had Sram before so had no idea about this. Don’t get me started on updates.
I guess mine won’t be getting updated.
