Why do I coast faster than everyone else?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
OK, so I'm not alone. Thanks.
Seriously, I wondered about this for years and every year test it on downhills, watch other riders and sure enough, I roll faster downhill. Someone said something about it today after the ride so I decided to ask about it here.
I like the descending muscles and valve cap theories quite a bit but am going with good tires and possibly more aero as the most plausible explanations.
I have always used good tires - Michelin Pro3/4, Vittoria Rubino Pro III and now Rubino G+ Speed with Conti Race Light tubes. A pair of Corsa G+ are on deck. Clothes are always close fitting - club cut is OK but I don't like things baggy.
Y'all think tires/tubes could make that much difference? You guys who coast faster, what tires are you using?
-Tim-
-Tim-
Quoted: 4560 Post(s)
Liked 2,804 Times
I just double-checked my helmet video cam from yesterday's group ride, using slo-mo to see what I missed. Everybody I passed was riding their brakes.
Mystery solved.
Mystery solved.
don't try this at home.
Quoted: 987 Post(s)
Liked 530 Times
At downhill speeds, it's essentially all aero.
See this chart of power to pedal at different speeds on the flats. Wind resistance in gold, other drivetrain resistance in purple.
At 10 mph, it's about evenly split between aero power and drivetrain/tire power. At 30 mph, it's way more aero power.
Coasting downhill, the "power" comes from gravity, and is proportional to weight. And the frontal area of a larger, heavier rider doesn't increase as fast as their weight increases. (Essentially, weight is proportional to changes in width*height*depth, but frontal area is only width*height, and perhaps even less when in a bike position.) That's why strong, big riders can sprint, but get dropped on hill climbs.
But different riders at the same weight can have different body shapes or can sit in a more aero position on the bike.
So: minor improvements in tire rolling resistance, slight improvements in wheel and bike aero, but mostly in rider aero. (or affected by timid/prudent braking, of course.)
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
I'm a featherweight yet I coast downhill a lot faster than riders a lot heavier than me. I attribute good hubs (I use White Industry T11) to it.
Bikes: Kestrel Talon w/carbon fiber 88mm wheelset, Trek 820MTB
Quoted: 7 Post(s)
Coasting? Hmmmm.....Not sure if I want to try that. I tried last year drafting and coasting down every hill another cyclist was riding....I got tired of coasting because I like to pedal down the hills, usually as fast as I can.
Advocatus Diaboli
Quoted: 4781 Post(s)
Liked 1,544 Times
Physics; Bend over lower, so present less air resistance? skinnier but heavier? gain flatulence-thrust?
Or just humble bragging..
Quoted: 645 Post(s)
Liked 797 Times
Ack - you're right - didn't think it through. Gallileo showed that acceleration under gravity is weight-independent, but, as you say, the heavier object will accelerate to a higher speed before opposing forces (drag, rolling resistance) balance out at terminal velocity
elcraft
How recently have your wheel bearings either been serviced or replaced,if sealed? What type of lubricant/grease do you use? Maybe the choice of grease is a factor. If one "overloads" the wheel bearings from a really tight Quick Release lever(or one doesn't plan to leave the bearings a tad looser to compensate for the end loading that the quick release will apply),'then there might be more drag on the wheel bearings. These factors should be considered.
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 359 Post(s)
Liked 122 Times
Hubs and bearings..
Some have mentioned that hubs and bearings may make a difference. I kind of tend to agree, I often wondered if better hubs and bearings on cars could get more gas mileage also?
The Left Coast, USA
I suspect such an advantage disappears with pro level riders who are much more disciplined about knowing where their center of gravity is on the bike, I suspect they intuitively go right to the sweet spot.
There is more to life than simply increasing its speed. - Gandhi
It's not that you're faster ...but rather they're slower.
- Soli Deo Gloria -
Liked 736 Times
Me too, always. I think the answer might be simple, if you are smart about distributing with your weight over your wheels, you will beat riders that are improperly balanced. Try it; move your weight fore or aft when you are coasting and watch your glide taper off.
This is a great post.
I had not though of this.
It is certainly plausible and worthy of testing.
-Tim-
Quoted: 659 Post(s)
Liked 7 Times
At typical downhill coasting speeds the rider's weight and aerodynamics are the dominant factors. The tire rolling resistance also plays a significant role with other things like bearing resistance of much less importance (barring some serious mechanical problem).
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4369 Post(s)
Liked 3,031 Times
You can affect your drag by rebalancing your weight and getting into different positions, but in general, people with more mass are always going to have the downhill advantage.
Bikes: canondale silk trail--92 schwinn criss cross--sun atlas x type--fugi odessa--2018 trek domane ALR5 disc
Quoted: 47 Post(s)
Can't coast down hill where I live. The wind will blow you uphill backwards.
C*pt*i* Obvious
Switch bikes with other riders, then you'll have your answer. Its probably not the bike IME.
One of my riding partners always out coasted me, even when we switched bikes.
Its mostly weight distribution and aerodynamics.
