Reinventing a 1988 Trek 520
Old 04-04-24, 09:46 AM
Stosheroo
Quoted: 13 Post(s)
Liked 9 Times in 6 Posts
My thinking is that the Jones H-Bar (no rise) will give me a generally more upright riding position while still giving me an aero option. I found this Threadless Stem Adapter from Velo Orange that should make it a little easier to experiment with bar/stem height and reach.
Stosheroo is offline
Old 04-04-24, 09:59 AM
Aubergine
Bad example
Quoted: 867 Post(s)
Liked 340 Times in 161 Posts
Originally Posted by ehcoplex
Nicest feeling clinchers (IMO) are Rene Herse. Not cheap, but with aging joints and the rough roads I ride on they're worth the $. In my experience they seem to run a little narrower than stated width, though that's likely as much to do with the rims/rim width as the tires themselves. Only way to know what's going to fit IRL is to take careful measurements with some calipers..... or just try it and see...
I also prefer Herse tires, as wide as I can get to fit. But Grand Bois tires are as good, and there is a 30mm version that works well on older racing bikes with less clearance. (Obviously that's not a concern for you but I felt the info might be useful.)
Aubergine is offline
Likes For Aubergine:
Old 04-04-24, 10:27 AM
Stosheroo
Quoted: 13 Post(s)
Definitely useful as I haven't gotten tires yet so will check these tires out...thanks!
Old 04-04-24, 05:22 PM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Quoted: 1557 Post(s)
Liked 2,035 Times in 991 Posts
Originally Posted by Stosheroo
Thank you for the correction on the 700c vs 27" size issue. I've been thinking incorrectly on that. Re: brakes, my LBS guy set me up with a pair of Shimano BR-CT91 cantis he claims will be sufficiently adjustable to address the 27" to 700c rim issue. If they don't, Paul makes a set that will work but are substantially more cash.
I am running a set of those--well, the same exact design but of Shimano STX variation--on my '84 620. They work very well. That was a 27" to 700C conversion, originally handled by silver MT-62 cantis but now with the black STX's. I run a very shallow straddle cable angle as I have a fork-mounted hanger stop. It looks more V-brake than anything, but it works well with the newer longer-pull Shimano brifters (Campy Ergos and Tektro R200 levers would perform similarly). You should be just fine with the BR-CT91s!
With respect to tires, I'm sure you're covered here. Paselas for the affordable end (yet plenty good), Soma Supple Vitesse EX on sale as next rung up, Grand Bois for those that know and run them, and then Rene Herse at the top. Interestingly, Soma, GB, and Rene Hearse (standard casing) tires are all very similarly priced. Soma tires are on sale right now, so that's the best bang for the buck, but if you want to spend ~$70 a tire, it's really hard to beat a $74 Rene Herse offering.
RiddleOfSteel is offline
Likes For RiddleOfSteel:
