Cleaning a chain prior to first wax bath: OMS + Methyl Hydrate VS Citrus + water
ignominious poltroon
Quoted: 2299 Post(s)
Liked 3,531 Times
For a new chain, I wipe it off with a paper towel and dump it in the hot wax, let the temperature equilibrate, swirl it around a couple of times, and then I pull it out to cool/drip dry. Like Stuart says, at worst the wax will be softer and more pliable. I do the same to re-wax. Basically the only waste is a paper towel and used wax when it gets dirty enough to discard.
Went to cheap chains also, from CN-M9100 / PC-1170 to HG-601 / PC-1110. Weekly cleaning (more often when riding in the rain) gets me about 4-5k miles out of a £10 chain, using regular Finish Line wet lube after cleaning chain and cassette with a solvent, usually petrol, never water. For the money spent on the rotating chains, wax, croc pot etc, I'd rather buy new chains and cassettes, which is better for the drivetrain anyway. I only ride on the road.
Just had a new cassette and new chain so I'm testing 5w30 engine oil as chain lubricant on my commuter, seems to have the same viscosity as the Finish Line wet lube I've been using for ages.
Bikes: 70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, '11 Shimano Masi Partenza
Quoted: 110 Post(s)
Liked 19 Times
Do what we have been doing since the 70's; yank the chain, coil it up, and drop it in a steel coffee can full of gas. Let it soak a few days, come back, rinse it off,string it up and blow it out with an air compressor, then relube.
70's Nuovo Record Jeunet Franche Compte, '88 105 Trek 1200, '85 Victory Bianchi Vittoria, '89 Exage Bianchi Strada LX, & '11 Shimano Masi Partenza
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,311 Times
…and burn down your house and spend months in a burn unit…if you are lucky. Don’t use gasoline! There are other solvents that are safer. Do something less dangerous if you need thrills…like juggling chainsaws.
Stuart Black
Stuart Black
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
This is what I do before I wax a chain for the first time.
https://moltenspeedwax.com/pages/clean-your-chain
The instructions make it seem a lot harder than it is in real life, and it's only once per chain. After that, it just goes in the crock pot full of melted wax.
When I'm done cleaning a new chain, I pour the used OMS & alcohol through a coffee filter in a funnel into jars so I can use it again next time.
same here,
clean a new chain once and just keep rewaxing as needed. I keep it very simple and have a couple chain rotation. Super simple and its a great, no muss or fuss.
Method to My Madness
Quoted: 2067 Post(s)
Liked 1,560 Times
I soak and agitate the chain in OMS (but no alcohol) prior to each waxing.
Quoted: 1158 Post(s)
Liked 1,266 Times
I do the lazy overkill method. I use a three pronged method. First treatment is degreaser. I just let it soak overnight. I am a bit lazy so that is really the only reason. I use simple green but a citrus solvent should work. Next day, I remove, wash with water and put it in mineral spirits and again let it soak overnight. Again, just lazy on my part. Shake maybe once or twice but that is about it. Next day, remove and wash with water and do a soak in ethanol again overnight because, you guessed it, I am lazy. Next day, remove, quick rinse with water, wipe down and dry (I use a hair dryer) before going into the hot wax where I let it sit for a bit - not overnight but a good bit before turning the slow cooker off and taking the chain out. I wait for the wax to start forming little islands on top. A quick wipe down and let dry before putting onto bike. When I started, I did two chains, so now, I am never in a rush and do it so I have the chain ready to go on when I take the used chain off.
Also, the chain that has been waxed and comes off the bike is generally just wiped down with water, dried and put into hot wax. No real cleaning. The above was just for new chains.
In terms of solvent, the degreaser gets put into a potted plant (for no other reason other than wanting to see what it would do to the plant), the mineral spirts are filtered and re-used. The ethanol is generally pretty clean and have not done much to that. I have now converted my three road bikes and my three mountain bikes.
Honestly, what I do is overkill and you could easily do just a 60 second degreaser, a 60 second mineral spirit and water/dry before waxing. I get about 200-300 miles on a chain. I generally change out chains when I hear them and shifting gets impacted. I should probably do it sooner but am lazy.
Lazy, economical and eco-friendly is OMS/Mineral spirits, one and done. Swish n jar #1, swish in Jar #2, air dry over night. Let the used OMS settle and pour off the clear stuff. Gather the dirty stuff in a separate holding jar and after a few chains done like that, you have some dirty mineral spirits in a jar, which in turn also settles, leaving more clear to pour off and reuse. The "waste" from mineral spirits is very little over time. I end up with a cup or so per year of stuff I can't re-use and I just dump in on a bonfire when I happen to have one. It's not very flammable at all, not explosive like gasoline. I could also take it to the hazmat bin at the transfer site if it was any significant volume, but there's not.
But I don't do the full immersion wax, I use a drip on commercial wax lube. Usually, I just wipe the chain with an OMS soaked rag and drip on the new lube. A couple of times a year I might do a soak routine, but generally not. Like someone said above - don't over think it. Chains are cheap and time is not unlimited.
I alternate between 2 chains and switch them on a monthly basis.. While one is on the bike I'm cleaning the other. My initial step is to soak my dirty chain in mineral spirits over night. Then I put the chain in an ultra-sonic cleaner in a solution of the citrus de-greaser from the Dollar Store and water. Let it cook for about an hour. Everything comes out bright and shiny.
Quoted: 1637 Post(s)
Liked 1,852 Times
Don't forget about cleaning your cassette, jockey wheels and chain rings too. Otherwise all your hard work cleaning your chain is all for naught.
Also, I measured the temperature of my pot of wax in the crockpot. It pegged the far end of the meat thermometer right away. I estimate it to be over 230F (the meat thermometer markings only go up to 220F). So there is no need to worry about traces of rinse water remaining in/on the chain- if you leave the chain in the crockpot for half an hour all water will evaporate.
Quoted: 110 Post(s)
Liked 19 Times
Somehow I still haven't burned down any houses. Odd! Maybe I just think things through before I do them I guess lol. Nothing cuts grease like gas.
Liked 4,311 Times
An added benefit is that the solvent isn’t likely to ignite from some random spark. The flash point of gasoline is -45°F which means that it will ignite at any temperature that we humans are going to encounter. It has has a high vapor pressure which means it evaporates easily and spreads widely. The high vapor pressure also means that the fuel burns hotter and faster.
Mineral spirits has a flash point of between 70°F and 150°F, depending on the grade. Most are around 100°F. Mineral spirits also have a low vapor pressure which means it doesn’t evaporate that easily nor spread that widely. It also burns slower. It’s far better than gasoline because it works and you aren’t playing with explosive material.
Stuart Black
Stuart Black
Liked 1,560 Times
There is a solvent that cuts grease better than gasoline. Mineral spirits is as efficient…if not more so. I’ve never had to let a chain…checks notes…”soak for a few days”. I put the chain in a Gatorade bottle, shake it until my arm gets tired…about 30 seconds (I am a cyclist, after all)…, take it out, and let it evaporate. The chain is clean and ready for lubrication.
And, I’ll say it again, why the complicated multi step process? Have you tested your seven step process and found it to be superior to a single step…shake in mineral spirits…process? Does your overly complicated system give you improved mileage? And by how much? Does it double, triple or even increase chain life by 10 times? Or do you get just about the same mileage as most others who do a lot less work? My money is on the latter.
Is it "necessary"? Who knows? Does this process give you a very clean chain that wax will readily stick to? Yes, absolutely. Maybe I could save five minutes of my time, maybe I shouldn't mess with success?
Liked 4,311 Times
Leaving a bunch of chains in mineral spirits and then shaking in isopropyl alcohol is "complicated"? This is maybe five minutes total "work". Doing six chains is the same amount of work as one chain, so it's not something you have to do often either. It's also the suggested method from basically every "expert" (lol). I filter and reuse the mineral spirits and you need only a little isopropyl alcohol so it's not particularly wasteful.
As for the “experts” on chain cleaning, they only got to be a “expert” by calling themselves that or by developing a complicated process to a simple problem because they felt it needed to be complicated. I will guarantee you (almost) that the “experts” have never tested the effect of the steps of their process nor can they tell you why the steps are used in the first place.
When I develop a chemical procedure…and I’ve developed many of them…I start simple and add complication only as needed. And I test each added complication to see if it is really needed. If I’m using someone else’s procedure, I test to see if a step is needed. If it doesn’t change the results, I eliminate that step.
Test your process to see if all those steps really are needed. If you leave out the isopropanol step, what effect does that have on the chain life or the adherence of the wax to the chain? If you leave out the second wash with mineral spirits, does that have an effect? If you only wash once with mineral spirits does that have a large impact on the chain life?
My own chain cleaning/lubricating method is based on my own testing. I used to do 2 washes with mineral spirits (although I’ve only used agitation and have never let the chain just sit in solvent). I used to clean my chains frequently (mostly when using oil). Then I stopped using the second wash. I keep records and found that the chains lasted just as long, so the second wash was stopped. Then, because I use solvent wax, I noticed that my chains were clean and didn’t need the frequent cleaning. Now they get cleaned once on installation and don’t get cleaned again because they don’t need it. My chains last just as long as previously so why do more work?
As I said in post 2, keep it simple. Don’t do 10 steps if 2 will do. Don’t do 2 steps if you only really only need to do one. Don’t do something blindly. Test it.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1956 Post(s)
Liked 2,201 Times
The easiest and most productive method is to remove the chain, pour gas on it, set it on fire, and make s’mores.
”We’re doing the tandem tonight, invite the neighbor kids over.”
John
John
Likes For 70sSanO:
Is it even required cleaning/stripping a new chain at all. I tried hot waxing with some old school castrol MC hot melt wax. Worked perfectly fine, just dumping in a new chain direct from the package. Im betting simply swishing a new chain in what ever mixture of paraffin, or what ever is used for bikes, would make it adhere just fine, just like the castrol wax did. Cant see why it wouldn't. Its all hydrocarbons anyway, - but of course Im not a chemist and at this point Im just guessing. Did anyone ever try, or did you go straight to the ten step plan .. ;-)
Liked 4,311 Times
It doesn’t matter anyway. Although I’ve not been brave enough to try it, I doubt that you’d get any different results with regards to chain wear if you didn’t put any lubrication on it. No matter how many cleaning steps you have or secret sauce lubrication recipes or magic enchantments, a chain is going to wear out in about the same amount of mileage.
Stuart Black
Stuart Black
Thats my thinking too. There is an old video somewhere on YT, from a bike chain factory, showing the uncut chain running through a bath of hot lube. Most likely wax .. Stripping it all of in some elaborate process seem very redundant. Id like to see a comparison between a new, fully prepared, waxed chain and a non prepared one after 500 km. Im betting the difference is nil or at least very close.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
Additionally, hot waxing a chain doesn’t require stripping everything off the chain each time it is waxed. It probably doesn’t need stripping the first time it is waxed. The factory lubricant is a soft wax and will mix readily with the harder canning waxes that most people use. It will result in a softer wax...similar to Speed Wax...that won’t flake off as easily. You can think of the molten wax as just being mineral spirits with a higher melting point.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Liked 4,311 Times
This is directly at odds with what both wax manufacturers and independent testing labs recommend. See https://zerofrictioncycling.com.au/wax-instructions/ for a pretty definitive explanation from the gold standard for independent testing labs.
I also don’t consider Zero Friction to the be gold standard for chain testing. I question their results and can find little about how they arrive at those results. They say something about variance of the measurement but don’t list the variance. Their results are very suspect in my opinion. On their chain longevity testing page, they claim that they only get 1000 km (600 miles) out of an inexpensive Shimano chain, which is unbelievable. They claim only 3000 km for the best actual measurement on a chain. That’s extremely low from what most people report. They also list only one 9 speed and one 8 speed chain but give an average for “all” 8 speed and “all” 9 speed chains. That’s lazy science.
Finally, if someone…manufacturer, testing lab, or home mechanic…suggests a long involved multistep process for chain cleaning, they had better have good reasons for doing all those steps. I have yet to see anyone provide a reason. I also have yet to see anyone actually test if those steps result in different results than something less involved.
Stuart Black
Stuart Black
Jedi Master
I just bought several new chains for the spring cycling season, and I'm going to throw caution to the wind and toss one of them in the wax crock-pot without cleaning it first. I'll report back in a few weeks and let you know how it goes. If it works, it could save me hundreds of seconds a year in chain cleaning.
Likes For kingston:
Liked 1,560 Times
I have often pointed out just this point. The factory lubricant on chains is a soft wax. Candle or canning wax or even other types of wax are hard waxes. A soft wax bends and flexes while a hard wax is brittle. Adding the soft wax to the hard wax would result in something in between the two which would stick on better and not flake off.
Likes For SoSmellyAir:
Same with the claim you must use a crockpot, that slows down the process even further. I tried both the before mentioned MC wax and paraffin. Both can safely be heated on the stove. Its no more dangerous than cooking an egg and your done in a few minutes rather than waiting a hour for a 100w crockpot.
Quoted: 110 Post(s)
Liked 19 Times
…yet. Go talk to your local fire department. At least warn them that you are soaking chains in…checks notes…”a steel coffee can full of gas”. That way they know what to expect.
