Who makes Rivendell-type bicycles & bicycle frames?
SE Wis
Quoted: 2754 Post(s)
Liked 3,418 Times
When I was looking for shifters for my S5 hub they sent me back there telling me to "Look around up there"
Palmer
Quoted: 1701 Post(s)
Liked 1,877 Times
Standard production? Off the top of my head...
Pashley. Some Breezer models. Detroit. Worksman.
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1144 Post(s)
Liked 2,033 Times
I have an idea. Come to Portland OR Aug 22-24 for the MADE show. Most the hand made builders in the US will be here.
I gave my spare room to the top builder from Australia who is staying with me, but I have a couch and bedding and plenty of bikes to loan if you need a ride.
Message me
Robert
Message me
Robert
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4368 Post(s)
Liked 3,031 Times
https://rexcycles.com/
2012 NAHBS Best Road Bike
2016 NAHBS Best Fillet-Brazed Frame
2019 NAHBS Runner-up Road Bike
2019 NAHBS Best City Bike
Steve Rex will do all kinds of custom options. He specializes in fillet brazing but has nice lugs too. Very classy looks, and lots of NorCal fans especially the CX folks. He might try to talk you out of a quill stem though.
Likes For DiabloScott:
Malcontent
Bikes: I honestly don't know...
Quoted: 81 Post(s)
Liked 98 Times
Message me
Robert
Message me
Robert
Quoted: 2376 Post(s)
Liked 2,904 Times
per Dave's site in a couple of places
The JK Special bikes are built with a proprietary mix of tubes (chainstays, seat stays, and fork blades) made to my specifications by Reynolds of England as well as Reynolds 953 and 853 Pro. The tubing is designed to give a solid and responsive ride without the harshness all too many races bikes are known for and this makes the JKS a race bike you want to spend all day on.
The original JKS is built with oversized main tubes, Kirk by Reynolds stays and blades, and lugs by Llewellyn of Australia and has a moderate slope to the top tube. It can be made with traditional straight seat stays or the optional curved Terraplane stays to up the performance on less than perfect surfaces one more notch. This, and all versions of the JKS, use the Kirk Triple F dropouts to make things simple, strong and light.
Likes For squirtdad:
Malcontent
Quoted: 81 Post(s)
Liked 98 Times
This is a JK special, which dave recommended after doing the questionnaire and measurements, which was a bit of a surprise as it is the 'raciest" but it is so nice (note there is not an ounce of upsell with dave, he will give honest opinion, example: i saw bike of his with stainless stays and forks which simulate classic chrome. he steered me away from that for issue like ride not matching and long term paint issue and noted the one I saw was intended by the owner to be a wall hanger)
Since Columbus came out with the Cento tube set in correlation with their 100th Anniversary, seeing Dave Kirk’s work on that green bike struck similarly in tube diameters, namely in the main triangle. I guess why I thought that bike was so amazing.
Liked 2,904 Times
That is quite impressive. I’ve seen Llewelyn’s work for years, along with his enthusiasm toward steam engines via Flickr.
I am building a set of tubular wheels it will be fun to compare the 32 mm rene hearse with 29mm FMB cobblestone on Nemsis rims
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 237 Post(s)
Liked 308 Times
Similarly, Peter Mooney worked from FitKit measurements and photos, and I'm more than happy with how I sit on the bikes. He too bumped my seat up a bit from the Guimard/Hinault/Lemond style fit I was riding.
Bikes: 1988 Specialized Rockhopper Comp, 2012 Goodrich Randoneuse, 2016 A-Train, 2022 Wilde Dream Engine, 2022 Salsa Mukluk
Quoted: 61 Post(s)
Liked 88 Times
I know you've had a lot of nice bikes, but I think you'd be happy with that Goodrich someday!
Likes For twolve:
Ride, Wrench, Swap, Race
Quoted: 1568 Post(s)
Liked 1,306 Times
YMMV but not in person was not an issue for me with Dave Kirk. 99% of his frames are not in person. He even caught that I was riding with my seat too low from measurements. I had chatted with him at cino 2021, but that was more about disk vs rim brake.
of course everyone has their own comfort level
With a low saddle height, the rider finds themself feeling the rear edge of the saddle top, so the intuitive tendency is the saddle getting moved rearward.
With the saddle moved upward and forward, the rider not only achieves a more-aero profile without having to bend sharply at the waist, they also discover a relatively effortless transition from seated to standing, so the process is quicker and gets done more often according to the whims of the grade of the road you could say.
This helps riders of vintage bikes (having limited gearing) by allowing greater leg extension from standing to thus spare stress on one's knees.
The saddle usually gets leveled out in the process, and the bike's high-speed stability improves greatly.
While the upper body adapts to the added weight borne by the arms, it's mostly the rider's neck that may end up defining the limit of how far forward that the rider can ride.
Likes For dddd:
Palmer
Liked 1,877 Times
Bikes: I hate bikes!
Quoted: 432 Post(s)
Liked 731 Times
I sold 2 Rivendell’s and bought these.
Jeff Lyon is the builder.
Lyon L'Avecaise 700c randonnering bikes. Made from thin-wall tubing (28mm 7-4-7 top tube, 32mm down tube) for the right flex characteristics according to the Bicycle Quarterly approach. Designed for a 6ft tall rider weighing 200lbs, made to fit 700x35mm tires (actual width) with fenders.
Geometry details:
Top tube length 58cm c-c (level)
Seat tube length 59cm c-c
Seattube angle 72.5 degrees
Headtube angle 72.5 degrees
Head tube length 178mm
BB drop 78mm
Chainstay length 44cm
Fork rake 58mm
Geometry details:
BB drop 78mm
Fork rake 58mm
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 273 Post(s)
Liked 344 Times
Quoted: 432 Post(s)
Liked 731 Times
Quoted: 4552 Post(s)
Liked 6,512 Times
Plenty of fantastic builders making frames all over the country right now.
The MADE show next month here has almost 300 exhibitors so far and many that we have called out here are not on the list so anybody looking to have a frame built should have no trouble finding a builder no matter where they are.
https://made.bike/registration/
Likes For merziac:
If you can find a SOMA Stanyan you'd probably be happy with it I think it is a wonderful lugged frame and very stylish even though its not a custom built frame, I get compliments on mine all the time . I am a big sad that SOMA has mostly started making all disc brake frames save one or two . If the Pescadaro was lugged I would have probably already bought one and may still do so simply because it will take center pulls.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
I don't run the show, but it would be cool if there were a sticky for active framebuilders (steel, but not necessarily C&V.)
Quoted: 278 Post(s)
Liked 349 Times
There is one over at paceline, under the custom builders section. It's even broken down by state.
80 Mercian Olympic, 92 DB Overdrive, '07 Rivendell AHH, '16 Clockwork All-Rounder
Likes For Kobe:
Quoted: 604 Post(s)
Liked 1,064 Times
Tim
Likes For tkamd73:
Quoted: 4864 Post(s)
Liked 4,012 Times
The kirk just wants to go......even on just 5 miles to work in the morning I find myself in the drops and pushing, with big smile. The only other bike that came close is my 84 team miyata.
