Counter clockwise, clockwise, what??
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Liked 43 Times
Here's another way to think of it. Ever heard of the term 'right hand threads'? Now stick out your right hand and make a thumbs up. If you turn the fastener in the direction of your fingers, the fastener will travel the direction of your thumb. For example, if you're looking 'over' your hand, your fingers are curling in a counter-clockwise direction. Turn the nut or bolt the direction of your fingers and the fastener will go up, which is how your thumb is pointed. You can hold your hand up over your head with the thumb pointed down or to the left or right, and the rule still holds true.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Liked 217 Times
As much fun as this rouse might be it has a real life basis. So many people don't have the spatial understanding to follow "clockwise" or the opposite "counter clockwise". I hear this frequently at work as I talk with/try to explain which way to turn stuff. It's really sad that as we (as a society) race towards the digital future such basic concepts as clock hands direction is forgotten as an important nugget. I find myself referencing a light bulb... Soon even this description will be lost.
What really gets my dander is when people refer to rotational direction as "turn the wrench to the right" (righty tighty). I want to ask which way is the wrench sitting? So many people are not use to critical thinking on so basic a level. Andy
Yet the number of people I know who could be told, “There’s a mailbox on the southwest corner of the intersection of Walnut and Beacon” and not have to ask a bunch of clarifying questions is surprisingly low!
It works in any orientation. When working on my car I can be completely on the other side of a Fastener and all I have to do is point my thumb in the direction I want the Fastener to go and my fingers curl in the direction to turn it. No need to visualize a clock or anything else.
Just watch out for a left-hand threads, which I don't think exist on bicycles.
This is all you need to know. Forget everything else.
Only freewheel hub threading that would be left hand thread would be on a rear hub made to have the drive on the left end.
tandem hubs has left ends threaded but that was for a brake, so was made tighter when the brake was applied
(near-trivia) old Regina Freewheels had the 2 largest cogs LH thread against the shoulder in the freewheel body.
But I have made a "lefty", a LH drive bike. Takes people a second to figure out what's different. Pino Morroni did one many years ago, and then Felt recently resurrected the idea for the USA track pursuit bikes. Pino's theory being that the extra weight is lower on the track and travels a shorter distance than a regular RH drive bike, using less energy. Felt also claimed an aero advantage IIRC
Yes, that's right, good catches both. I'd suspect some antique hubs had LH threads on one side of the axle too.
I dont tear down freewheel bodies its a pointless task by now ..
some cars have right and left hand lugnuts holding the wheels on .
Yes it was a rel question
Thank you very much to CNY for their almost instant response which was also the most clear.
And I DO understand how a clock goes around.
I DON'T count the number of times a phrase has been used before asking a real question. That second reply was so snarky it should have been sifted out. Not helpful.
DanBF
Bicycle Mechanics
8
04-30-19 05:24 AM
kalash74
Bicycle Mechanics
5
02-06-17 02:17 PM
