Wahoo Kickr Circuit Board Repair
Randomhead
Liked 3,837 Times
I would like to know where this circuit board is, don't want to have to probe around.
I want to see if I can put a better antenna on it.
Pcb fail
So I've managed to get into the Core. Does anyone know which bit fails when the pcb goes? I'm hoping to get it repaired as wahoo aren't being as helpful as I'd hoped. My ideal solution would be me buying a new pcb but I can't locate one. I can't post the photo until I've made a few more
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Liked 95 Times
Does Wahoo sell the circuit boards as part of support?
Board failures from static etc were warrantied and they were pretty good about support
and appeared to iron out early problems in later models
I was looking at used ones, and the ability to repair reasonably is as good as a warrantee for me.
Achooly better. I love the smell of flux in the morning.
Out of curiosity, anyone have links to teardowns or wiring diagrams a trainers?
Ive seen repair vids for the Wahoo online for other issues.
Randomhead
Liked 3,837 Times
My understanding is they don't have boards for repair of the original, can't get any, and they offer you a discount on a refurb. Hopefully I don't have to find out if that's true or not.
Randomhead
Liked 3,837 Times
Randomhead
Liked 3,837 Times
You can upload pictures to an album in your gallery and we can rescue them for you.
I have never heard of a repair for this, but I imagine it's possible if it doesn't blow the microprocessor.
Uploaded pictures
I added some pictures in my album. If I need to do something else please let me know. This is my first time to post here and I’m new to this. Also if this helps: When the board is plugged in the kickr doesn’t work. But the circuit board still gets power. The brake engages but nothing lights up. It may be the main box on the board but it could be some other part and don't know where to locate parts. I accidentally plugged in the wrong power cord and wrong voltage.
Thx again for any help.
Likes For Cturrin1:
Randomhead
Liked 3,837 Times
Unfortunately, it says there are no uploads in your albums or photos. You have to select the pics, it looks like they should be uploaded, but there is an upload button on the upper right side that completes the action.
Likes For Cturrin1:
Randomhead
Liked 3,837 Times
Looks good.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/80_3ec7d2b9_53b7_4de0_aaa3_dd7a279c0910_ff93978f182c261cd51801f28afe510e3adfec7c_jpeg_76c6447b9da65af08797868c8d2a8119edcf6c9e.jpg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/80_e40d4544_51bf_4554_b803_407cb4ffd090_080b66b0af4485342d7e0b2c91f9ebd4243a0925_jpeg_e180b847cab80a4be77110c4223f6597fedb1d6b.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1500/80_7ed84bf4_e257_4b3e_a0ea_f4e8e7b6207f_7d8ef3974c99166f89240d120769d4ff2d883f4e_jpeg_69a5eb543fda77ea42566959ee1fbbf450c39be1.jpg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1500/80_9c0425a6_9dd8_49fb_86b9_a2d294f48338_60c0de8b47ff03ed56c9199be70cf69ef30a7436_jpeg_7256f73736a9d5976a613f04d905d57cd59fdfe0.jpg)
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1500/80_8ab0ea24_5bb1_4353_b0df_4eb0e9773ff6_62049b23049022941e733ce5645e6445364bc943_jpeg_9938eccb51e8d446e78aa9f837e30957f4519da0.jpg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1500/80_35b99323_c9db_40c7_9369_d630a72bc80c_16714506e61dc8c3d5ce748b2981e9554bb38798_jpeg_b6c09405eedbbbf20cf3ec8c7398f24f2cc46065.jpg)
Randomhead
Liked 3,837 Times
Okay, you have to love FCC test reports. There is also a users manual for the radio module
That board has test points all over it, so you should be able to get a good idea of the state of the power supply.
The module itself is mostly a nRF52832 in a shielding box.
https://www.google.com/search?q=gems...hrome&ie=UTF-8
Likes For unterhausen:
Likes For Cturrin1:
If the voltage regulator fails open, it probably put 24V on the main controller chip, which would definitely kill it. That's a replaceable module, but there's no way for anyone (other than Wahoo) to program it.
I personally have a full SMT re-work station, but it would take me some time to trace the circuit. Then ordering replacement components and hoping the original event didn't fry the microcontroller. Best case it's several hours and you get it working.
Your best bet is going through Wahoo, who probably want you to send the entire trainer in. Which makes sense from their perspective, that way they send you a fully functional trainer.
Randomhead
Liked 3,837 Times
I think wahoo can repair everything but the version 1 kickr. This doesn't look like a V1. Okay, it's not, I can see the handle in one of the pictures.
And get rid of that other power supply![Smilie](images/smilies/smile.gif)
The power regulator is U3, it's an MC33275- something (3.3v)
MC33275DT−3.3RKG
Didn't see an absolute max input voltage, they just say input voltage is 13vdc
https://www.onsemi.com/pdf/datasheet/mc33275-d.pdf
I always wondered if it would help to replace that chip antenna with an external antenna. Doesn't look particularly easy
The module manual says how to upload firmware via a couple of pins. Getting it from wahoo would be a bit of a hassle, but they let you download it. https://fccid.io/PADWF116/User-Manua...Manual-3085164
MC33275DT−3.3RKG
Randomhead
Liked 3,837 Times
Interestingly, the OP was wrong, VNH21 identifies his mosfet just fine. It's one of these https://www.onsemi.com/pdf/datasheet/ntd4810n-d.pdf
Interestingly they seem to have switched from an N channel to a P channel between these two boards.
Thanks
I’ll see if I can decipher through this foreign language of information that has been given to me. I am not a mechanically inclined person so much of what’s in the manual doesn’t make much sense. I also reached out to Wahoo. I appreciate the feedback and the knowledge that’s been sent my way in such a short period of time.
Randomhead
Liked 3,837 Times
I think the best thing to do is go through wahoo. If that doesn't work out U3 is available. Not sure where you are going to find someone that can desolder/solder that on the board though. They are all around us, but hard to identify. I assume that is blown. As gsa103 said, it's possible it blew as a short, which would be bad because the whole board would have been exposed to high voltage. Let's hope it blew open circuit and was the only thing that died.
It costs 90 cents from Digikey https://www.digikey.com/en/products/...-3-3RKG/920890
Randomhead
Liked 3,837 Times
Welcome to the forum. Hopefully Wahoo got him sorted. Someday I'm afraid I'm going to have to start a kickr V1 support group.
