Pre-ride safety check--what do you look for?
Quoted: 1324 Post(s)
Liked 927 Times
If I'm in one of the downtown areas here is town (the area I try to avoid going to due to the large number of nut cases wandering around) I check my quick-releases on both wheels to make sure some idiot didn't loosen them. I've had two instances where I discovered that the front quick release had been loosened and then close again but it wasn't holding the wheel very snugly = one good bump/pot hole and the wheel might have come off. that's why I avoid that area unless I must go there for business.
Cheers
Cheers
Quoted: 318 Post(s)
Liked 149 Times
I don't commute, but now I'm wondering how often people come out in the morning before riding to work, only to find a slow leak did them in overnight.
After my last ride everything seemed fine, but the next day (yesterday) the rear was mostly flat.
I flipped the bike over, got a magnifying glass and flashlight and went over the whole tread and both sidewalls and didn't see anything.
I took out the tube and looked that over, didn't see anything. Pumped the tube and submerged it, didn't see anything. Pumped the tube way up and saw bubbles, finally.
Back to the tire, I ran my fingers all around the inside under the tread, twice -- nothing. Ran fingers along each side wall twice -- nothing. Looked all along the inside with a magnifying glass -- nothing.
Finally, running my fingers in the opposite direction I found the steel wire (from a truck tire?) that had poked in between two tread blocks. (Michelin Protek Cross, inverse tread.) On the outside of the itre, it was laying flat against the base of a block. I guess it was hidden from view as I rolled the tire for inspection? Lesson learned: next time, rotate the tire both directions.
Liked 927 Times
Cheers
Likes For Miele Man:
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
In terms of hardcore or traditional safety checks, none.
I simply make sure the tires are the right pressures, lights and computer are charged, and water bottles are full and in their racks.
Bikes: yes
Quoted: 512 Post(s)
Liked 411 Times
Likes For Vintage_Cyclist:
Bikes: old ones
Quoted: 26476 Post(s)
Liked 10,440 Times
...that rooster is probably on another online forum right now complaining about the jerk cyclist who almost ran him over in the dark.
Bikes: old ones
Liked 10,440 Times
...bounce the front wheel, bounce the back wheel, work the brake levers to make sure the quick releases are down, and I'm off. Come back quickly when I remember I forgot my frame pump or my lock.
Likes For 3alarmer:
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
Likes For dedhed:
Bikes: old ones
Liked 10,440 Times
SE Wis
Liked 3,412 Times
Bikes: road: 1999 GT road:40Kmi+ // 2001 fuji finest AL:9Kmi+//1991 schwinn paramount ODG:0.1Kmi+
Quoted: 19 Post(s)
Liked 10 Times
if it is the same bike i rode yesterday, just tire air maybe, (though i might wait til i start pedaling and see if things feel ok)
brakes
wheel quick releases
just stuff that could easily come off or change in the night
i;m not going to check wheel bearings, chain slack, headset tightness, other than just by starting to ride
wle
brakes
wle
Quoted: 5234 Post(s)
Liked 3,609 Times
do I have my head screwed on straight? no really ... what am I planning to do? & is it a good idea?
not much I can add to the above but those are excellent lists. A pilot always does a walk around check before take off.
One of the things I do is lock the brakes and wiggle the bike back and forth, to confirm brake authority and nothing is loose (headset, wheel QRs, etc.)
Mark Petry
Bainbridge Island, WA USA
Mark Petry
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
Your pilots didn't wiggle the ejector racks, stick their head in the intakes and the main gear wells, and check the slat deployment (on the TA-4 this was very important! Assymentric slat deployment could kill you.)
I learned my lesson early - about doing your walk around check. Sure there's a longer inspection if the plane hasn't been flown in a while - but I remember leaving our Bonanza parked for lunch somewhere and came back to it - nothing's hanging down, right ? But one of the things I did was just run my fingers down the trailing edge of the wing, across the flaps and ailerons - and it came back wet. Fuel leak. Turned out to be a loose sump drain fitting, which I tightened enough to get us home.
Little things can get you. So, I always pre-flight my bike. Takes 30 seconds.
Mark Petry
Mark Petry
Likes For mpetry912:
Bikes: 1972 Raleigh Tourist
Quoted: 27 Post(s)
Liked 14 Times
Your PRE CHECK is very good!
My PRE CHECK starts before I even look at the bicycle...
....I look at my shoes, are they safe and comfortable?
....am I hydrated for the ride?
....check those sunglasses and sun visor
....clothing, warm enough, cool enough?
....vist the toilet
....tell someone that you are going on a ride
....cel phone and Cab fare?
Ok, now go and check your faithful steed!
Julius in Ohio
....vist the toilet
Julius in Ohio
Just the basics usually. Air in the tires? Brake levers actually connected to something? Chain? Then take it easy for long enough to make sure everything feels right, no squeaks or rattles, before launching into heavy traffic.
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
Well I haven't yet. was that agent qualified to fly anything besides his desk ? "hahahhaha"
there was another one that said in twin engine airplanes, the 2nd engine was there to get you to the scene of the accident.
here's the net net of this thread, at least to me. The airplane sprang from the bicycle ! and like the airplane, the bicycle does not have a lot of structural redundancy. If the engine quits you have a fair chance of gliding to some kind of landing. But if the tail falls off you are toast. Same with your bike. If the front skewer pops, you are probably going down. I actually had a fork blade come out of the crown (and this was on a frame built by a maker of some repute) but fortunately got the bike stopped before wiping out.
Your safety depends on some critical parts - tires, brakes, frame. If they fail in any substantive way, you could be badly hurt. So, I check the bike over every time I ride it. I have a bunch of bikes so they might not get ridden that frequently as I rotate thru the herd.
And I quit flying some years ago.
Mark Petry
Mark Petry
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Or just throw the phone into the woods.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
It's not too big a deal, unless you need to find hot coffee, while touring. 🤔😁
Bikes: 2 many
Liked 323 Times
Ha, I've had that frozen phone problem too, several times now. I can't say exactly what temp it goes wacky at, but somewhere in the 30s or 40s F. Usually, it starts up fine, but the battery reads like 10% or less, even if it's fully charged, then it shuts down. 🙁
