Tweaked Bianchi Professional meets my grubby little cold-setting hands
www.theheadbadge.com
Liked 4,527 Times
Well, I had success with this brute-force-and-massive-ignorance method -
The gory details are here. And cudak888's earlier photo displays exactly the right spot to pull on.
Also, I see you're living up to your name
![Stick Out Tongue](images/smilies/tongue.gif)
Haha...well I need to burn a few holes in some scrapola frames before I melt down an almost-good Paramount - you at least convinced me of that!
I gotta admit as soon as you mentioned that nickname, I got an image in my head...a very bad image in my head, of a plumbing reference![lol](images/smilies/lol.gif)
Given all the recreational smokeums in Colorado, "Crack Corrector" could have many other connotations
![Roflmao 2](images/smilies/roflmao2.gif)
-Kurt
SE Wis
Liked 3,428 Times
torsion bars as well.
https://gm.oempartsonline.com/oem-pa...hoCP3cQAvD_BwE
The Huffmeister
Bikes: 1965 dept store special, 1972 basket case, 1978 garden ornament, 1980 garbage heap, 1987 mutt, 1996 frankenstein
Liked 3,833 Times
Plenty of meanings depending on one's persuasion - hopefully the right one would be clear if we met face to face haha. In 6mo I'll probably be ready, and the Crack Corrector will be lighting up (a torch)
![Innocent](images/smilies/innocent.gif)
![Big Grin](images/smilies/biggrin.gif)
Likes For AdventureManCO:
Liked 4,527 Times
-Kurt
The Huffmeister
Liked 3,833 Times
![](https://farm5.staticflickr.com/4313/35119331183_a2af27af1e_b.jpg)
Sometimes you've just gotta caveman things.
Likes For himespau:
Liked 4,527 Times
Likes For cudak888:
I love threads like this. Moral of the story: Yes, lurker/noob/hobbyist/commuter/enthusiast, you can fix your own bicycle, and you should try it.
Sure, dedicated alignment tools in the right hands will always give more precise results, but that isn't always available to everyone, or at all times, increasingly less often with the old time bike shops disappearing. With a little ingenuity, maybe sometimes a bit of finesse, maybe sometimes a bit of brute force, you can get your bike back to an acceptable degree of performance and functionality.
Likes For BFisher:
Ride, Wrench, Swap, Race
Liked 1,337 Times
A solid barbell bar might also serve well.
EDIT: ...seeing that Schweinhund already alluded...
Bergz
I clamped a bent sideways frame to a wooden workbench and heaved on the unsupported part hanging over the edge, Got it straight (I think it had been backed into in a garage) Some DIY wooden frame blocks and a tiny amount of filler and you would never have known. Steel is so forgiving...
Likes For Bergz:
Bike Butcher of Portland
Bikes: It's complicated.
Liked 6,006 Times
Uh, yes, yes they are, unless my material science professor was lying to me 35 years ago.
Stiffness is the same on all steels (in case you don't believe me). Strength varies significantly within different steel alloys.
This is what my machine shop teacher taught us.
I think maybe you misunderstood your teacher.
blahblahblah chrome moly
Steel is an alloy made of iron and any number of different metals (chromium, manganise, molyebdenum, vanadium, etc..). iron is stiff, and has the highest shear strength of any metal. iron is also brittle with a tendency to shatter. alloying agents are broght in in differing percentages to change the characteristics of the finished metal.
Also your statement that iron is stiff is wrong. Young's modulus of gray cast iron is less than half that of steel.
Can you point out where gugie went wrong? If you are talking about his statement that all steels have the same stiffness, we can quibble about a few percent difference here and there, but as long as you add a "very nearly" in there, then it's true. The modulus does vary by about 10% among steels, but the difference is less than that among those commonly used on bicycles and most structures.
Stiffness doesn't change at all with cold-working or heat treating, and only a small amount with alloying or carbon content, excluding some weird or special-purpose steels. BTW stainless has a bit lower modulus, but it's generally considered a separate category among engineers and fabricators.
Do you disagree with that? If so, please try to show a reference.
Likes For bulgie:
Liked 4,527 Times
Word to the wise: Metallurgy and the science of materials is wonderful.
...but if you just need to straighten your gaspipe, just go for the first solid rod that doesn't bend on you, and you should be good.
(Edit: I just read that ^ again and I'm now trying to keep a straight face. But that's another story).
-Kurt
-Kurt
Likes For cudak888:
Liked 2,006 Times
Kurt,
If you think this is fun, just come on over to the carbon fiber discussions on the golf shaft forums. It doesn't compare to the ones about steel tubes and the way they are made today. Frinstance, does the weld line create a spine in the tube and can it affect the way the tube works as a spring constant due to the weld temperatures. CF discussions go along the same path and the engineers and designers are rarely asked for opinions. TBH I think steel tubes do have a spring constant and it can influence the way a bike frame flexes during riding, but that is again a theoretical discussion. Smiles, MH
Likes For Mad Honk:
BTW your statement that "steel is an alloy" is only true for alloy steel. Plain steel (which is most steel) has only iron and a small amount of carbon, no other metals needed.
Liked 6,006 Times
I'm 100% sure that I'll never be able to convince you that stiffness of steels is pretty much the same regardless of alloy, I'm just hoping that others that read this will have this is the takeaway.
Since you're not willing to have a reasonable argument outside of "my high school shop teacher told me so", the best option I think is just to put you on ignore.
Liked 6,006 Times
PSA - how to put someone on ignore
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/263x191/ignore_c600a50cdcb54fe67353aa01be27a94eeedbcbf3.gif)
Likes For gugie:
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Liked 325 Times
I'll go on the record and say Gugie is right about Young's Modulus. I studied it at school, I've looked it up, I've seen the charts. But Young's Modulus is pretty strictly defined - a coupon of material is put into the machine, tension is applied and the change in length measured. Young's modulus identifies the change in length from where the material will still return to the coupon's original length. It measures elasticity up to the point of yield. Yield can mean several things - the coupon can deform (not return to its original shape) or it may do very little of that and just snap - tensile failure.
Where folks, myself included, get confused is equating this measurement of elasticity with stiffness. Most of us think of stiffness as resistance to bending, but that is not what stress-strain testing reveals. When we bend something it is more complicated, part of the material is under tension and a similar amount is being compressed. The shape of the sample can have more to do with stiffness than the material - with the same mass of material, a tube will be much stiffer than a rod. With a piece of flat bar it will be much "stiffer" when stressed in the plane of one side vs. the other. Taken to a logical extreme, if you fold a piece of paper correctly it becomes rigid enough to support a brick. It is easy to reach a conclusion that one steel is "stiffer" than another.
To return to this thread on cold-setting, which in itself implies that Young's Modulus is not involved since we are deliberately deflecting the material beyond the point where it will return to its original shape, what we are really talking about here is the yield strength of steel - which, unlike Young's Modulus, varies a lot according to alloy and post-treatment. Introducing a permanent change in shape of a mild steel bike frame will require tangibly less force than performing the same ritual on a 531 frame. The yield and tensile strengths are way different. This would be even more evident if the tube sections were identical, which they seldom are. The whole purpose of using high-strength tubing is so that less material can be used for an equally robust frame and weight can be dramatically reduced.
I apologize to those of you who already understand this very well, but given part of the exchange above it appeared that a re-visit was needed
Last edited by daka; 01-15-23 at 05:23 PM. Reason: added "deliberately" for clarity
