The Cannondale Factory
having been given C'dale frames to race every year in the mid to late eighties to race, I have a mixed opinion of them. They were great crit axes. The quality was not great. The powder coating would bubble and then flake off in huge patches. The rear derailleur hangers creaked and required constant greasing. The ride was really harsh, especially the 3.0 with its huge downtube and super short chain stays. Back then the peloton referred to them as "Crack'n'fails". I'm not sure where that came from. None of the five I had cracked. Regardless, I've never wanted a C'dale since.
Saying "Crack'n'fail" made dumb bike racers and bike shop employees feel clever---there was nothing more to it than that.
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Liked 7,490 Times
https://www.cannondale.com/en-us/warranty
Length of Warranty
Every bicycle has a useful product lifespan. This limited warranty is not meant to suggest or imply that the frame or components can never be broken or will last forever. This limited warranty covers manufacturing defects that occur within the normal lifespan and use of the product.Cannondale bicycles must be registered on cannondale.com or in person by an Authorized Cannondale Retailer in order to activate the lifetime frame warranty described below.
Frames, excluding those listed below: Lifetime of the original owner.
Frames of Gravity, Freeride, Downhill, Dirt Jump and other ASTM Category Five Bicycles: Three years from original retail purchase.
Likes For cb400bill:
Liked 2,707 Times
the early Cannondale welds were smooth because they were finished
the welds were two pass (or something like that) with a lot of material - and then a sander / grinder was used to finish the welds
can’t recall the name of the sander that was used - saw one but can’t recall ... might have been roto something or another ...
early Cannondale frames did have some issues with frame alignment problems after heat treating ... cracks around the seat tube area would also surface - but that’s also not uncommon in other frames
Super Moderator
Liked 1,013 Times
Early frames were overly stiff because the head engineer was an idiot who only cared about stiffness...And he was always right.
Likes For Homebrew01:
Our Cannondale sales rep was embarrassed about the wavy frame tubes that were that way because they'd tried a different heat treating process, but he said that despite the appearance of the tubes, the frames were correctly aligned. I never saw a misaligned Cannondale frame in our shop.
A young materials engineer on YouTube posts (on his channel Peak Torque) frequent cut-to-the-chase videos reporting results of his analyses of bike stiffness and strength. One video from a while ago confirmed that, in practical terms, vertical stiffness and rider comfort are affected principally by the tires, the seatpost, and the handlebars and stem. Frame material was demonstrably a much, much smaller factor in vertical stiffness in comparison.
(The other important contributor to perceived stiffness and comfort---the biggest factor, in my experience---is, of course, the bike's wheelbase. As with cars, longer wheelbases promote comfort but adversely affect handling at speed.)
Cannondale's chief engineer was likely fully aware that an effectively two-dimensional, vertically rigid double-diamond truss structure like a bike frame will have about the same vertical stiffness regardless of the size of the frame tubes, so he would have been more interested in (i) reducing the frame weight and (ii) increasing the torsional stiffness. (The latter factor explains why so many tourists extol the handling of their Cannondale touring bikes, especially for out-of-the-saddle climbing, in comparison to the drunken wallowing of many steel touring frames.)
The Peak Torque videos are well worth exploring. Here's a more recent video where he demystifies various claims regarding the characteristics of carbon versus aluminum frames.
Liked 2,707 Times
noticed it was a challenge to ride without hands - compared to my 3.0 frame bike that was set up fairly similar ... so the bike was broken down and frame put on a frame jig / plate ... frame was out of alignment - and the fork was also out of alignment
but the worst part was one section of the head tube near the head tube / top tube junction ... the person that ground the weld got a little carried away and slightly ground into the top tube - this was the underside portion of the top tube so I did not spot this initially ... the wall thickness of those frames is very thin - so we decided it was not safe to ride ... did try to get another frame from Cannondale but the request was refused ...
the components were moved to a lugged Columbus SL frame so it all worked out in the end
I still have the 3.0 frame - and also have five other fairly current Cannondale bikes (including two hybrids and a Slate and a Topstone)
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam,1995Coppi(to be built),1993Grandis(to be built)
Liked 1,256 Times
Length of Warranty
