New Lectric One
Likes For cat0020:
Ride more, eat less
Liked 816 Times
New bike day:
Handlebar is a bit wide for rising between car mirrors, I may swap it our for something narrower or just take a pipe cutter to it.
Likes For cat0020:
Likes For cat0020:
The hub motor (no wear on drivetrain), belt drive (no chain maintenance), pinion trans (no cog wear), disc brakes (no rim abrasion), all point to a very low maintenance bike, even in wet climates. Truly greater than the sum of its parts.
The weight would be the only killer for me, I live in a walkup.
I guess the next evolution after the Lectric one is getting rid of the hub drive and switching to the Pinion MGU.
https://youtu.be/QtTJ8BaebN0?si=F6RspPabxFWfkUa0
Ride more, eat less
Liked 816 Times
I've put about 40 miles on the Lectric One this weekend;
after pedaling 50 miles on my regular bike FRI last week, my achy body welcomed the help of electric motor.
Lectric One is a very solid bike, no rattling, the belt drive really makes the bike very quiet.
I don't feel any more drag (or motor drag) on the drivetrain than a regular chain driven bike while pedaling without motor assist.
Because my butt still hurting from the 50 mile ride, I put a suspension seatpost on it right away.
The weight of the Lectric One is only felt when you're trying to lift the bike.
No significant feel of the weight while riding it.
I trimmed the handlebar about 1" from each side, added old Bontrager magnesium barends on for different riding positions, since the reach of the Lectric One is short.
Added bell & mirror the handlebar as necessary accessories.
Since Lectric One is not a folder that allows changing the bike's length, transporting it may require a larger vehicle or a hitch rack.
Taking off & putting in the (+/-10 lb.) battery needs to have the seatpost removed. Lectric One share the same battery as the Lectric Trike, same terminals allow usage on both.
I put a cheap pannier/tail bag on the rear rack so I can have some storage, a centerstand that lift the rear wheel would provide more stability while loading things into the panniers.
The most noticeable feature is how quiet the Lectric One rides, with or without the motor engaged. The belt drive certainly help to keep things quiet.
Shifting performance of the Pinion gearbox is similar to the Shimano Ultegra electronic shifting on my road bike, quick & precise.
I tried to play around with the self-shifting feature of Lectric One, but it's rather time consuming to determine the ideal cadence for the Pinion to shift itself.
I think I will save that when I get a chance to watch the Lectric setup video for the feature.
Overall, I feel that it's a well thought out package, offers components that no one else offer at this price point.
If you're looking to get into cycling with an ebike and don't like manual shifting,
Lectric One offers great performance in a compact package that's easy to maneuver and very good value.
But not many beginners are going to spend $2K for their first ebike.. or maybe they do?
Likes For cat0020:
I don't know.
Liked 1,041 Times
I am not an e-bike rider, but I talked a coworker into getting one of these. Sounds like he's going to like it.
Ride more, eat less
Liked 816 Times
I put a 25 mile shake down ride on the Lectric One.
I have to say it's a "solid" ebike. Solid as in sturdy, nice on paved road,
but after an hour in the saddle, I kinda wish there's a suspension fork.
I unlocked the top speed of 28 mph, that's plenty fast for my usage.
I may play around with the settings to adjust the power output for different speeds
I am very happy with the adjustable stem, I could change the handlebar reach & height without getting off the bike.
I rode two laps around the National Park near me,
which has plenty of elevation change between Mt. Joy & Mt. Misery, between 8% and 18% gradient.
The adjustable stem allowed me to lean forward for the uphills.
I have no problem going slow up the hills with lowest gear & higher cadence with PAS1.
Pinion gearbox acts up when I miss a shift and try to shift under heavy load uphill.
Most of my 25 mile ride was in PAS1.
After 25 miles, the battery was only down one bar from full charge.
I like how quiet the belt drive is.
Would I have a regular bike with a Pinion gearbox?
maybe not, but the combo of Pinion & belt drive make the bike very flexible in different types of cycling,
requiring little to no maintenance. I can see myself getting a gravel bike with Pinion & belt drive.
55+ Club,...
Bikes: 9+,...
Liked 985 Times
cat0020 Do you think you'll swap out the front fork for a suspension fork in the future? I'd love to see what it looks like, and how it improves ride quality. And thank you for the updates...
The pic with the cooling towers in the background is very futuristic. I can think of two captions; "As modern as tomorrow!", and "When petroleum runs out." A giant field of solar panels would also be great.
Ride more, eat less
Liked 816 Times
I think a carbon fork with QR front wheel would help with the dampening of harsh ride, also loss weight.
or
Custom titanium fork from China,with better dampening characteristic,
wide clearance and thru-axle dropouts, probably keep the OEM from wheel, that might lose some weight.
Suspension to me is that they offer to much spring action, add too much weight.. they maybe good for off-road riding, but not for mostly pavement, commuter.
One thought, the Lectric One is meant to be a low maintenance commuter, not a long distance touring bike, most commuter probably would not ride it for 25 miles in one sitting like I did. Lectric One shouldn't need a fork upgrade as a commuter.
No housing development, no shopping malls, plenty of space for cycling, on or off-road.
I also have solar panels in my backyard, with battery backup batteries in my basement could go totally off-grip if needed.
Cleaning the panels is much easier when they are not on the roof.
Likes For cat0020:
Ride more, eat less
Liked 816 Times
Lectric is currently offering extra long-range battery with the purchase of Lectric One
https://lectricebikes.com/products/l...ng-range-ebike
Likes For cat0020:
Fortunately I do not yet need electric. Because I need a folder, and weight that I can carry up stairs. But with a garage or ground floor bike storage, and elevators, one of those will do most folks great, at a small fraction of the price of a Tern GSD or HSD. But I think their prices have come down just a bit, due to competition.
